Pix4D Documentation
English
日本語
Contact us
日本語
PIX4Dmapper
General
Account and license
Organization management
Pix4D outputs
Photogrammetry knowledge
Practical knowledge
Other resources
Miscellaneous
Video tutorials
Artículos populares
PIX4Dmatic
Getting started
FAQ
General
Processing options
How to... (step-by-step instructions)
Troubleshooting
Release notes
PIX4Dsurvey
Troubleshooting
Getting started
FAQ
License
Settings & Tips
Release notes
Processes and tools
PIX4Dcloud
Getting started
FAQ
License
Settings & Tips
Technical release notes
Troubleshooting
PIX4Dcloud Advanced
Third-party integrations
Mission Planner
PIX4Dcatch
Getting started
General
Troubleshooting
FAQ
Scanning kit
RTK devices
PIX4Dmapper
A project from A to Z
Getting started
Quick links
Installation and login
Hardware and computer setup
Troubleshooting
Manual
PIX4Dfields
Getting started
FAQ
Supported drones and cameras
License
Use cases
General
Targeted Operations
Troubleshooting
PIX4Dreact
Getting started
FAQ
License
Advanced features
Troubleshooting
PIX4Dengine
PIX4Dengine SDK
PIX4Dengine Cloud
PIX4Dengine CLI - Obsolete
PIX4Dcapture Pro
Most viewed PIX4Dcapture Pro articles
Getting Started
General
FAQ
Troubleshooting
PIX4Dcapture
Getting Started / User Manuals / Special Install
Functionalities / How-to
Troubleshooting
General / FAQ / Release Notes
Translated content
ไทย
Video Tutorials
Back to home
Pix4D Documentation
PIX4Dmapper
General
Account and license
Pix4D outputs
Practical knowledge
Other resources
Miscellaneous
Video tutorials
Artículos populares
PIX4Dmatic
Getting started
FAQ
General
Processing options
Troubleshooting
Release notes
PIX4Dsurvey
Troubleshooting
Getting started
FAQ
License
Settings & Tips
Release notes
Processes and tools
PIX4Dcloud
Getting started
FAQ
License
Settings & Tips
Troubleshooting
PIX4Dcloud Advanced
Mission Planner
PIX4Dcatch
Getting started
General
Troubleshooting
FAQ
Scanning kit
RTK devices
PIX4Dmapper
Getting started
Quick links
Troubleshooting
Manual
PIX4Dfields
Getting started
FAQ
License
Use cases
General
Targeted Operations
Troubleshooting
PIX4Dreact
Getting started
FAQ
License
Advanced features
Troubleshooting
PIX4Dengine
PIX4Dengine SDK
PIX4Dengine Cloud
PIX4Dcapture Pro
Getting Started
General
FAQ
Troubleshooting
PIX4Dcapture
Troubleshooting
Translated content
ไทย
Video Tutorials
PIX4Dmapper
The leading photogrammetry software for professional drone mapping.
Getting Started Index - PIX4Dmapper
Step 1. Before Starting a Project - PIX4Dmapper
Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan - PIX4Dmapper
Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type - PIX4Dmapper
Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > b. Computing the Flight Height for a given GSD - PIX4Dmapper
Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > c. Computing the Image Rate for a given Frontal Overlap - PIX4Dmapper
Step 1. Before Starting a Project > 2. Configuring the Camera Settings - PIX4Dmapper
Step 1. Before Starting a Project > 3. Georeferencing the Images - PIX4Dmapper
Step 1. Before Starting a Project > 4. Getting GCPs on the field or through other sources (optional but recommended) - PIX4Dmapper
Step 2. Creating a Project - PIX4Dmapper
Step 3. Before Processing (optional) - PIX4Dmapper
Step 4. Processing - PIX4Dmapper
Step 5. After Processing (optional) - PIX4Dmapper
See more
Getting started
Computer requirements - PIX4Dmapper
New project in PIX4Dmapper
Software download and installation - PIX4Dmapper
Processing options - PIX4Dmapper
Image acquisition - PIX4Dmapper
Processing steps - PIX4Dmapper
Inputs and Outputs - PIX4Dmapper
Ground control points (GCPs) - PIX4Dmapper
Sign up - PIX4Dmapper
Get the most out of PIX4Dmapper
Video tutorials - PIX4Dmapper
How to get a trial of PIX4Dmapper
How to define Pix4D outputs with respect to a Geoid model
See more
Quick links
How to improve the outputs of dense vegetation areas using PIX4Dmapper?
When to use the Geoid Height Above the Ellipsoid Function? - PIX4Dmapper
Radiometric calibration target - PIX4Dmapper
Radiometric corrections - PIX4Dmapper
FAQ on the accurate geolocation pipeline - PIX4Dmapper
Using PIX4Dtagger - automatic target recognition - PIX4Dmapper
How to merge projects - PIX4Dmapper
How to process images taken at different Flight Heights / GSD? - PIX4Dmapper
How to modify the camera rig processing options - PIX4Dmapper
Quality report specifications - PIX4Dmapper
Using the rayCloud - PIX4Dmapper
Using GCPs - PIX4Dmapper
What does the Bingo File that is generated when clicking on Export Marks... contain? - PIX4Dmapper
Color and Number of Point Clouds / Orthomosaics depending on the used Camera(s) - PIX4Dmapper
What does the Output Params Folder contain? - PIX4Dmapper
Can PIX4Dmapper generate Outputs for 3D Printers?
Full Processing vs Rapid / Low Resolution - PIX4Dmapper
Input files -PIX4Dmapper
Can the Size of the Orthomosaic and DSM Tiles be defined? - PIX4Dmapper
Does a Project processed with PIX4Dmapper Discovery need to be reprocessed with PIX4Dmapper?
Merging multispectral projects in PIX4Dmapper
Image Correlation with PIX4Dmapper
Maximum number of images per project and processing time - PIX4Dmapper
Which Base Surface is recommended for the Volume Calculation? - PIX4Dmapper
What is Carve? - PIX4Dmapper
Specifications of xmp.camera tags - PIX4Dmapper
How to export the Automatic Tie Points? -PIX4Dmapper
Internal Camera Parameters Correlation - PIX4Dmapper
Projected 2D length and terrain 3D length of polylines - PIX4Dmapper
How to move a project from one machine to another? - PIX4Dmapper
Error estimation in volume calculation - PIX4Dmapper
Is it possible to obtain the DSM and / or Orthomosaic without processing Step 2. Point Cloud and Mesh? - PIX4Dmapper
Can the Resolution of the Point Cloud be controlled? - PIX4Dmapper
When is a GCP / Check Point highlighted with red color in the Quality Report? - PIX4Dmapper
Which Cameras exist in PIX4Dmapper Database and which Parameters are used?
Mosaic Editor Workflow - PIX4Dmapper
What is the difference between Automatic Tie Points and Manual Tie Points?
How to set the band weights for modified cameras (NIR,R,G and NIR,G,B) - PIX4Dmapper
How to use the rayCloud to improve the Accuracy? - PIX4Dmapper
Camera Requirements for Precision Agriculture - PIX4Dmapper
When to use Alternative Processing Mode in Initial Processing? - PIX4Dmapper
What is the bingo file generated during Initial Processing? - PIX4Dmapper
Difference between "Reoptimize" and "Rematch and Optimize" - PIX4Dmapper
How PIX4Dmapper calculates the Volume
How many Points are generated during step 2. Point Cloud and Mesh? - PIX4Dmapper
Manual Tie Points and GCPs in merged project - PIX4Dmapper
What do the Crosses and Squares mean when Marking a Point in the rayCloud? - PIX4Dmapper
Volume Difference of an Area Surveyed over different Time Periods - PIX4Dmapper
Is there a Limit in the Number of Points that can be displayed in the rayCloud? - PIX4Dmapper
What is the difference between theoretical error and the error to GCP initial position? - PIX4Dmapper
What does step 1. Initial Processing do? - PIX4Dmapper
How are the Internal and External Camera Parameters defined? -PIX4Dmapper
Processing Large Datasets - PIX4Dmapper
What affects the Quality of the DSM? - PIX4Dmapper
How to add Images to an Existing Project? - PIX4Dmapper
Project Folder Structure - PIX4Dmapper
How to import the Image Geolocation for Cameras without GPS? - PIX4Dmapper
Quality Report Help - PIX4Dmapper
How to select Camera Focal Length and Flight Altitude considering the desired Ground Sampling Distance and Terrain to map? - PIX4Dmapper
Using the Index Calculator - PIX4Dmapper
Using the Mosaic Editor - PIX4Dmappper
Best Processing Options for Processing subprojects before Merging - PIX4Dmapper
What are the output files after... -PIX4Dmapper
Processing Options Default Templates - PIX4Dmapper
How to convert .laz files into .las/.ascii files? - PIX4Dmapper
See more
PIX4Ddiscovery / Discovery mode - PIX4Dmapper
Step 3 processing option is not available: Discovery mode. - PIX4Dmapper
Error e0702a: "Could not authenticate. Invalid e-mail/password combination." - PIX4Dmapper
Server error, cannot login - PIX4Dmapper
Is an Internet connection needed? - PIX4Dmapper
Error: "Network error: Please check your internet connection. SSL handshake failed" - PIX4Dmapper
Remote device deactivation - PIX4Dmapper
How to move a PIX4Dmapper license to another computer - PIX4Dmapper
How to log out - PIX4Dmapper
Error e0703a: Could not retrieve list of licenses. Invalid credentials. - PIX4Dmapper
Error: "Maximum number of devices already activated. Deactivate one of the active devices and try again. " - PIX4Dmapper
Error: "There is a problem with this Windows Installer package.... A DLL required for this install to complete could not be run." - PIX4Dmapper
How to completely uninstall PIX4Dmapper - PIX4Dmapper
Error e0062: Server Communicatino problem. Please try again later. - PIX4Dmapper
How to log in - PIX4Dmapper
Error: "pix4dmapper.exe has stopped working" while installing the software - PIX4Dmapper
Error: "This installation package could not be opened. ...that this is a valid Windows Installer package." - PIX4Dmapper
Technical release notes - PIX4Dmapper
Can multiple users use the same or different licenses in one computer? - PIX4Dmapper
PIX4Dmapper installation for computer lab
Installer shows modify, repair, remove option - PIX4Dmapper
Error: "This installation package is not supported by this processor type..." - PIX4Dmapper
See more
Hardware FAQ - PIX4Dmapper
Error e0094: It was not possible to initialize OpenGL. - PIX4Dmapper
Hardware components usage during processing - PIX4Dmapper
macOS / Windows XP / Linux / Remote access / Parallel processing - PIX4Dmapper
What are the Advantages of the SLI Technology for Processing? - PIX4Dmapper
Processing speed - PIX4Dmapper
Error: "0xc0000005" PIX4Dmapper stopped working during processing
How to set up the Proxy Server Configuration - PIX4Dmapper
How to use PIX4Dmapper on Azure Virtual Machines - PIX4Dmapper
PIX4Dmapper MacOS Incompatibility: Error e0060
Hardware - PIX4Dmapper
Hardware case study - PIX4Dmapper
Long processing time with Xeon v3 processors - PIX4Dcloud
How to modify the resources (cores and RAM) assigned for processing - PIX4Dmapper
Long Processing Time for Step 3 with Quadro GPUs - PIX4Dmapper
How to verify the supported OpenGL versions of the graphics card - PIX4Dmapper
Error: "Unable to recover from a kernel exception." - PIX4Dmapper
Use of the GPU - PIX4Dmapper
How to find information about the GPU in Windows - PIX4Dmapper
PIX4Dmapper user interface does not display the texts properly
CUDA not detected - PIX4Dmapper
How to set the NVIDIA graphic card to maximize its resources? - PIX4Dmapper
See more
Troubleshooting
Display issues when using Windows Remote Access - PIX4Dmapper
Camera Optimization Error - PIX4Dmapper
PIX4Dmapper crash troubleshooting
Supported drones and cameras - PIX4Dmapper
Error e0400: "Cannot open project..." - PIX4Dmapper
Some Areas of the DSM have a lot of Noise - PIX4Dmapper
Some uncalibrated images - PIX4Dmapper
Error e9034: Problem uploading item to the cloud - PIX4Dmapper
Black screen - PIX4Dmapper
Corridor Project has Big Errors on the Edges - PIX4Dmapper
Color Discrepancy for Edited Regions in the Mosaic Editor - PIX4dmapper
Horizontal shift after a coordinate system transformation is applied - PIX4Dmapper
The 3D Textured Mesh does not cover the full area of the model - PIX4dmapper
Poisson Surface Reconstruction freezes at 40% while generating the 3D Textured Mesh - PIX4dmapper
Warning w0026: "Loading results failed: Incorrect coordinate system." - PIX4dmapper
Warning w0011: "The loaded .prj file does not contain the TOWGS84 parameter. This may lead to incorrect georeferencement." - PIX4dmapper
Error e0067: "Detected camera name_focal_resolution. This camera is not supported by this edition of PIX4Dmapper. To process more cameras, contact Pix4D."
Orthomosaic too big for Autodesk Civil 3D - PIX4Dmapper
Inconsistent Lighting / Striping - PIX4Dmapper
Big triangles generated in the DSM - PIX4dmapper
Error e0049: Error in the point cloud densification - PIX4Dmapper
Error e0050: "Orthomosaic generation stopped" - PIX4Dmapper
Cannot purchase or renew a license - PIX4Dmapper
Error: The rayCloud does not display all / some layers, appears black / white or display artifacts - PIX4Dmapper
Windows 11 and PIX4Dmapper
Error e0200a: Cannot start processing - PIX4Dmapper
Error e9013: Could not save subprojects - PIX4Dmapper
Error e0203a: Cannot generate DTM - PIX4Dmapper
Error e9027: The coordinate sytem in file is not valid - PIX4Dmapper
Error e9019: cannot extract EXIF info from image data - PIX4Dmapper
Error e0013: Cannot import image location file - PIX4Dmapper
High georeferencing errors in the quality report - PIX4Dmapper
No calibrated images - PIX4Dmapper
Multiple blocks / Vertical Inaccuracies - PIX4Dmapper
Warped or curved model - PIX4Dmapper
Vertical shift between the model and the GCPs / Cannot mark the GCPs in the rayCloud - PIX4Dmapper
Errors processing a Large Dataset - PIX4Dmapper
Images and/or GCPs are not positioned correctly on the Map View - PIX4Dmapper
Error e0046: "Processing failed." - PIX4Dmapper
"This app has been blocked for your protection" - PIX4Dmapper
How to correct for wrong image altitude without GCP - PIX4Dmapper
Rename images to place in same file directory - PIX4Dmapper
Error: There is a significant difference between the Initial and Optimized Focal Length - PIX4Dmapper
Exif/Xmp tags required for radiometric correction for multispectral camera - PIX4Dmapper
Error: Black Holes in the Point Cloud - green, orange and yellow Rectangles in the Overlap Map in the Quality Report - PIX4Dmapper
Distortions and Artifacts in the Orthomosaic - PIX4Dmapper
Error: "Error with the server" while uploading to Pix4D Cloud - PIX4Dmapper
Error: merged projects create more than one block and / or they do not adjust - PIX4Dmapper
PIX4Dmapper shuts down when the Quality Report is displayed
"File Corrupted! This program has been manipulated and maybe it's infected by a Virus or cracked. This file won't work anymore" error - PIX4Dmapper
List of troubleshooting articles for PIX4Dmapper
Volume tab turns black - PIX4Dmapper
How to export the quality report and log file -PIX4Dmapper
See more
Manual
Floating license - PIX4Dmapper
Upload Project Files... - PIX4Dmapper
Menu Process > Generate DTM - PIX4Dmapper
Select Image / GCP / Output Coordinate System - PIX4Dmapper
Displaying bars - PIX4Dmapper
Select Geolocation File - PIX4Dmapper
Export Image Geolocation/ Ground Control Points - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Processing Area - PIX4Dmapper
Menu Process > Processing Options - PIX4Dmapper
Menu Process > Processing Options... > 2. Point Cloud and Mesh > 3D Textured Mesh - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Point Clouds - PIX4Dmapper
Menu View > Mosaic Editor > Visualization - PIX4Dmapper
Menu Process - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP / MTP Table > Import / Export Marks - PIX4Dmapper
Menu View > rayCloud > Right sidebar > GCPs and Manual Tie Points - PIX4Dmapper
Menu Project > Basic GCP / MTP Editor - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Processing Area - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 3. Index Map > Index List - PIX4Dmapper
Menu View > Home - PIX4Dmapper
Menu View > Mosaic Editor > Mosaic Editing - PIX4Dmapper
Menu View > Volumes > Sidebar > Layers - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 3. Index Map - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Objects - PIX4Dmapper
Menu Project > Image Properties Editor... > Images Table - PIX4Dmapper
Menu Process > Import Point Cloud for DSM Generation - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 3. Index Map > Index Map (Formula Editor) - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Objects - PIX4Dmapper
Menu View > rayCloud > 3D View - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Create - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Triangle Meshes - PIX4Dmapper
Menu Project > Image Properties Editor... > Selected Camera Model - PIX4Dmapper
Menu Project > GCP / MTP Manager... - PIX4Dmapper
Menu Project - PIX4Dmapper
Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP / MTP Table > Import GCPs... - PIX4Dmapper
Software Manual > Index View - PIX4Dmapper
Menu Project > Image Properties Editor... > Image Geolocation - PIX4Dmapper
Menu View > Map View > Processing Area - PIX4Dmapper
Menu View > Log Output - PIX4Dmapper
Software Manual > Table View - PIX4Dmapper
PIX4Dmapper Software Manual > Blocks View - PIX4Dmapper
Menu View > Volumes > Sidebar > Objects - PIX4Dmapper
Offline Getting Started and Manual (pdf) - PIX4Dmapper
Menu Help - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP / MTP Table - PIX4Dmapper
Menu Project > Image Properties Editor... > Selected Camera Model > Edit Camera Model - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP Coordinate System - PIX4Dmapper
Interface - PIX4Dmapper
Menu Project > Image Properties Editor... - PIX4Dmapper
Menu View > Volumes - PIX4Dmapper
Menu View > Volumes > 3D View - PIX4Dmapper
Menu View > Index Calculator - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP / MTP Editor - PIX4Dmapper
Menu View > rayCloud > Menu Bar -PIX4Dmapper
Menu View > Map View > 2D View - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP / MTP Table > Add Point - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Automatic Tie Points - PIX4Dmapper
Menu Process > Generate Contour Lines - PIX4Dmapper
Menu View > Volumes > Menu Bar - PIX4Dmapper
Menu Process > Generate 3D Textured Mesh - PIX4Dmapper
Menu View > rayCloud > Left Sidebar > Layers > Point Groups - PIX4Dmapper
Menu Process > Send Map to eMotion - PIX4Dmapper
Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Point Clouds - PIX4Dmapper
Menu Process > Run Point Cloud Classification - PIX4Dmapper
Menu View > Mosaic Editor > View - PIX4Dmapper
Menu Process > Processing Options... > 1. Initial Processing > Matching - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Cameras - PIX4Dmapper
Menu Process > Processing Options... > Resources and Notifications - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Rays - PIX4Dmapper
Menu View - PIX4Dmapper
Menu Process > Send Elevation Data (DSM) to eMotion - PIX4Dmapper
Menu Process > Processing Options... > Templates - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 2. Regions - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Cameras - PIX4Dmapper
Menu Process > Reoptimize - PIX4Dmapper
Menu Process > Rematch and Optimize - PIX4Dmapper
Menu Process > Generate Quality Report - PIX4Dmapper
Menu Process > Save Undistorted Images - PIX4Dmapper
Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator - PIX4Dmapper
Menu Process > Processing Options... > 1. Initial Processing > Calibration - PIX4Dmapper
Menu View > rayCloud > Left sidebar > Layers > Tie Points - PIX4Dmapper
Menu Process > Quality Report... - PIX4Dmapper
Menu View > Map View - PIX4Dmapper
Menu View > rayCloud > Toolbar - PIX4Dmapper
Menu Process > Open Results Folder - PIX4Dmapper
Menu View > rayCloud - PIX4Dmapper
Menu View > Volumes > Sidebar - PIX4Dmapper
Menu Process > Processing Options... > 1. Initial Processing > General - PIX4Dmapper
Menu View > Mosaic Editor - PIX4Dmapper
Menu Project > Basic GCP / MTP Editor > Preview - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Clipping Box - PIX4Dmapper
Menu Project > Basic GCP / MTP Editor > GCP / MTP Table - PIX4Dmapper
Menu Project > Select Output Coordinate System... - PIX4Dmapper
Menu Project > Basic GCP / MTP Editor > Images - PIX4Dmapper
Menu Process > Output Status... - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 1. Reflectance Map - PIX4Dmapper
Menu View > rayCloud > Right sidebar - PIX4Dmapper
Menu Process > Processing Options... > 2. Point Cloud and Mesh > Advanced - PIX4Dmapper
Menu Project > GCP / MTP Manager... > GCP / MTP Table > Remove Points - PIX4Dmapper
Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Additional Outputs - PIX4Dmapper
Menu View > rayCloud > Left sidebar - PIX4Dmapper
Menu View > Index Calculator > Sidebar - PIX4Dmapper
Menu View > Processing - PIX4Dmapper
Keyboard shortcuts - PIX4Dmapper
Read-only Mode During Processing - PIX4Dmapper
Index Database List - PIX4Dmapper
Menu View > rayCloud > Right sidebar > Images section - PIX4Dmapper
GCP / Manual Tie Point Table - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 5. Export - PIX4Dmapper
Menu View > Index Calculator > Sidebar > 4. Color Maps and Prescription - PIX4Dmapper
See more
How to compute a Site Calibration file - PIX4Dmapper
How to edit Objects in the rayCloud - PIX4Dmapper
How to improve the Outputs of PIX4Dmapper
How to model small objects - PIX4Dmapper
How to download / open a previously uploaded PIX4Dcloud project - PIX4Dmapper
How to edit a Volume - PIX4Dmapper
How to import and mark ground control points (GCPs) - PIX4Dmapper
How to calibrate a Fisheye Lens Camera - PIX4Dmapper
How to process Images with different Spectral Signature (RGB, NIRGB, etc) - PIX4Dmapper
How to import a Point Cloud delivered by an External Source into PIX4Dmapper for processing
How to filter Images for the Texture Generation of the 3D Textured Mesh - PIX4Dmapper
How to generate the 3D Textured Mesh from a portion of the Point Cloud - PIX4Dmapper
How to merge Images with different Spectral Signatures (RGB, NIRGB, etc) - PIX4Dmapper
How to import an Animation Trajectory to the rayCloud - PIX4Dmapper
How to mark GCPs in the rayCloud - PIX4Dmapper
How to geolocate the Images so that the Geolocation is imported - PIX4Dmapper
How to capture and process data with Parrot ANAFI Thermal - PIX4Dmapper
How to process Images with 4 or more Bands - PIX4Dmapper
How to import a Processing Options Template - PIX4Dmapper
How to get the PIX4Dmapper Measurements in feet - PIX4Dmapper
How to process a Tetracam dataset - PIX4Dmapper
How to process Sequoia imagery - PIX4Dmapper
How to visualize a Triangle Mesh in the rayCloud - PIX4Dmapper
How to include GCPs in the project - PIX4Dmapper
How to automatically generate a Digital Terrain Model (DTM) - PIX4Dmapper
How to add / import GCPs in the GCP/MTP Manager - PIX4Dmapper
How to change the Processing Options to generate fewer 3D Points - PIX4Dmapper
How to verify that the Image Quality is sufficient - PIX4Dmapper
How to calculate a Volume from a specific Base Altitude - PIX4Dmapper
How to generate the point cloud classification - PIX4Dmapper
How to import and mark Manual Tie Points (MTPs) - PIX4Dmapper
How to remove Objects from a Stockpile for the Volume Computation - PIX4Dmapper
How to remove the Sky from the Point Cloud using the Annotation Tool - PIX4Dmapper
How to process a single step - PIX4Dmapper
How to navigate in the 3D View in the rayCloud and the Volumes View - PIX4Dmapper
How to visualize a Point Cloud in the rayCloud - PIX4Dmapper
How to verify that the GCP Geolocation is Correct - PIX4Dmapper
How to do a Rapid Check of the Dataset while still being in the Field - PIX4Dmapper
How to generate the Google Maps Tiles and KML - PIX4Dmapper
How to remove the Background of the Orthoplane using the Annotation Tool - PIX4Dmapper
How to create a User Processing Options Template - PIX4Dmapper
How to verify that the Image Geolocation and the Image Coordinate System are correct - PIX4Dmapper
How to add / import and mark manual tie points (MTPs) in the Basic GCP / MTP Manager - PIX4Dmapper
How to create a Processing Options Template .tmpl File - PIX4Dmapper
How to georeference a Project without Image Geolocation, only with 2D GCPs - PIX4Dmapper
How to generate contour lines - PIX4Dmapper
How to export the 3D textured mesh - PIX4Dmapper
How to split a project into subprojects - PIX4Dmapper
How to geolocate Images using a GPX File with GeoSetter - PIX4Dmapper
How to export the marks of tie points in the GCP/MTP Manager - PIX4Dmapper
How to delete Object Vertices - PIX4Dmapper
How to verify that at least 75% of the Images have good Geolocation - PIX4Dmapper
How to calibrate a Perspective Lens Camera - PIX4Dmapper
How to import the marks of GCPs/MTPs with the GCP/MTP Manager - PIX4Dmapper
How to use the Site Calibration Parameters - PIX4Dmapper
How to remove obstacles from the point cloud in the rayCloud using the Annotation Tool - PIX4Dmapper
How to use the Clipping Box in the rayCloud - PIX4Dmapper
How to edit the point cloud in the rayCloud - PIX4Dmapper
How to generate the 3D Textured Mesh - PIX4Dmapper
How to process images of a spherical camera - PIX4Dmapper
How to convert the Camera Model Internal Parameters from Brown 1964/ Heikkila 1997/ Fraser 1997 to Pix4D Camera Model Definition - PIX4Dmapper
How to export Volumes - PIX4Dmapper
How to update a Volume after editing the Point Cloud - PIX4Dmapper
How to measure Distances, Areas or Volumes - PIX4Dmapper
How to correct for the Rolling Shutter Effect - PIX4Dmapper
How to align projects - PIX4Dmapper
How to assign images to two Camera Models - PIX4Dmapper
How to create a Region with the Index Calculator - PIX4Dmapper
How to verify that there is enough overlap between the images - PIX4Dmapper
How to export an Animation Trajectory with the rayCloud - PIX4Dmapper
How to create a Video Animation Trajectory in the rayCloud - PIX4Dmapper
How to improve the 3D Textured Mesh - PIX4Dmapper
How to verify that the GCP Geolocation and the GCP Coordinate System are Correct - PIX4Dmapper
How to import a volume into Volumes - PIX4Dmapper
How to export the Point Cloud - PIX4Dmapper
How to verify that the Camera Model associated to the Camera is Correct - PIX4Dmapper
How to merge the Tiles of the Point Cloud - PIX4Dmapper
How to verify that the GCP Coordinate System can be transformed to the Output Coordinate System - PIX4Dmapper
How to create the orthomosaic of a facade - PIX4Dmapper
Edit, Add, and Delete Indices and Formulas in the Index Calculator - PIX4Dmapper
How to obtain or create a .prj coordinate system syntax file - PIX4Dmapper
How to draw a Surface in the rayCloud - PIX4Dmapper
How to manually calibrate uncalibrated Cameras in the rayCloud - PIX4Dmapper
How to orient a project - PIX4Dmapper
How to draw a Polyline in the rayCloud - PIX4Dmapper
How to improve the Visual Aspect of Buildings in the Orthomosaic with the Mosaic Editor - PIX4Dmapper
How to generate a Colored Index Map in the Index Calculator - PIX4Dmapper
How to generate an Index Map / Index Grid in the Index Calculator - PIX4Dmapper
How to correct Building Artifacts in the DSM and Orthomosaic - PIX4Dmapper
How to obtain the georeference using 2D or 3D GCPs taken from a Web Map Service - PIX4Dmapper
How to draw a new orthoplane - PIX4Dmapper
How to reduce the Size of the Orthomosaic - PIX4Dmapper
How to change the processing options - PIX4Dmapper
How to correct Building Artifacts in the DSM and Orthomosaic with the rayCloud - PIX4Dmapper
How to improve the Visual Aspect of Bridges in the Orthomosaic with the Mosaic Editor - PIX4Dmapper
How to map and measure Pole and Tower Structures - PIX4Dmapper
How to scale a project - PIX4Dmapper
How to Annotate Images in the rayCloud - PIX4Dmapper
How to add / import GCPs using the Basic GCP/MTP Editor - PIX4Dmapper
How to edit the Color Mapping in the Index Calculator - PIX4Dmapper
How to select / change the Image / GCP / Output Coordinates System - PIX4Dmapper
How to export Manual Tie Points and/or GCPs in the rayCloud - PIX4Dmapper
How to draw a Volume - PIX4Dmapper
How to use Videos for Processing - PIX4Dmapper
How to import/export the images geolocation and orientation - PIX4Dmapper
How to use the Editing Camera Model Options - PIX4Dmapper
How to change the Camera Initial Values to the Optimized Values - PIX4Dmapper
How to edit the Orthomosaic - PIX4Dmapper
How to use a Processing Area - PIX4Dmapper
How to remove Images from a Project - PIX4Dmapper
How to export objects in the rayCloud - PIX4Dmapper
How to add / import and mark manual tie points (MTPs) in the rayCloud - PIX4Dmapper
How to import and mark GCPs in the rayCloud - PIX4Dmapper
See more
