How to visualize a Point Cloud in the rayCloud - PIX4Dmapper
In some circumstances, it might be needed to display an external point cloud, for example for comparison purposes. PIX4Dmapper can display an external point cloud for visualization.
To use the external Point Cloud for processing please switch to this other article: How to import a Point Cloud delivered by an External Source into PIX4Dmapper.
  Info:
- Before proceeding with the import of the point cloud, you need to create a project and process Step 1. Initial Processing.
 - The imported point cloud cannot be used for measurements and further processing (3D textured mesh generation, step 3. DSM, Orthomosaic and Index) and cannot be edited using the rayCloud. It will only be displayed in the rayCloud for visualization purposes.
  Important:
- The Point Cloud has to be in one of these formats: .ply, .xyz, .las or .laz.
 - To open a georeferenced .las or .laz Point Cloud, the project needs to have a known coordinate system, not an arbitrary one.
 - The .ply, .xyz, and non georeferenced .las and .laz Point Clouds need to be centered around zero and have the same units as the project.
To visualize an external Point Cloud in the rayCloud:
1. Open the project.
2. On the Menu bar, click View > rayCloud.
3. Open Windows Explorer and navigate to the external Point Cloud.
4. Drag and drop the Point Cloud file into the left sidebar, in the section Layers, in the layer Point Clouds.
  Warning:
 - DO NOT drag and drop the Point Cloud while a project is processing: Processing may stop.
 - DO NOT use PIX4Dmapper as an administrator.
For more information about the layer Point Clouds: Menu View > rayCloud > Left sidebar > Layers > Point Clouds .
