Menu View > Index Calculator > Sidebar > 3. Index Map > Index Map (Formula Editor) - PIX4Dmapper
Access: On the Menu bar, click View > Index Calculator (available once step 1 . Initial Processing has been completed). The Index Calculator sidebar is displayed on the right of the main window. In section 3. Index Map, click Edit to edit the selected index (available for user defined indices).
The Index Map pop-up is used to easily edit the formula associated to the user defined index. The name of the index that is edited is displayed in the window title.
It contains 3 sections:
And 3 action buttons:
  • OK: Confirms the changes.
  • Cancel: Does not save the changes.
Reflectance Map Band Selection
Displays information for each band of each group of images of the generated Reflectance Map(s).The following information is displayed:
  • Band: Name of the band . If more than one group exists and the same band name exists in different groups, the bands are displayed as "Groupname_band."
  • nm: Wavelength of the band in nano-meters.
  • Min: Minimum pixel value per band.
  • Avg: Average pixel value per band.
  • Max: Maximum pixel value per band.
  • Stdev: Standard deviation of pixel values per band.
  • Var: Variance of pixel values per band.
By clicking a band button, the band name will be automatically inserted in the Formula text box at the current cursor position.
Operations
Buttons that allow the user to automatically insert mathematical operations in the formula text box at the current cursor position.
The available operations are:
Symbol
Action
addition
subtraction
multiplication
division
exponentiation
open parenthesis
close parenthesis
Symbol
sqrt
log
sin
cos
tan
asin
acos
atan
Action
square root
natural logarithm
sine
cosine
tangent
arcsine
arcosine
arctangent
Formula
Text box to edit/write the formula associated to the index.
Under the text box a message appears indicating the formula validation status:
  • Valid formula.
  • Undefined "band_name" band.
  • Incomplete formula.
  • Syntax error.
Important: The formulas' expression is case sensitive: it distinguishes between upper and lower case.
