How to add Images to an Existing Project? - PIX4Dmapper
It is not possible to add images to an existing project in PIX4Dmapper.
In order to add additional images:
  • If the number of new images can cover certain areas with good overlap between them and on their own, they can produce results:
It is possible to process the new images as a new project and then once completed the step 1. Initial Processing, merge the sub project with the original project following. For more information: Merging projects.
Note: When merging projects, the steps 2. Point Cloud Densification and 3. DSM and Orthomosaic Generation need to be processed again for the merged project.
  • If the number of new images cannot cover certain area with good overlap between them and on their own they can produce results:
It will be needed to create a new project with all the images. For more information: Getting Started Index.
