Software download and installation - PIX4Dmapper
This article explains how to download, install, change the language settings, access upgrades, and enable remote device deactivation when using PIX4Dmapper.
Information about the content of the versions can be found here in the Technical release notes - PIX4Dmapper.
Download
To download the software:
  1. Go to the download page and click Download.
    PIX4Dmapper_Download
  2. Log in with your PIX4D account and select the organization holding your PIX4Dmapper license.
  3. Scroll through your products until you find PIX4Dmapper and click Download.
Note: The download button is appearing only to valid license holders.
Installation
Once the software has been downloaded, install it by the steps below:
  1. Double-click the downloaded file. The PIX4Dmapper Setup wizard starts.
  2. (optional) If the pop-up Open file - Security Warning appears, click Run.
  3. In the pop-up PIX4Dmapper Setup, in the screen Welcome to the PIX4Dmapper Setup Wizard, click Next.
  4. (optional) Click Change... to change the destination path for the installation and click Next.
  5. Click Install.
  6. (optional) In the software information window: "Do you want to allow this app to make changes to your device?", click Yes.
  7. Click Finish.
  8. A shortcut is created on the desktop and the software opens automatically once the installation is completed.
  9. The first time the software opens, the window PIX4Dmapper Login appears:
    PIX4Dmapper Login window
  10. Read the End-User License Agreement, select I accept the terms in the License Agreement, and click Next.
  11. Type the Email and Password of the account and click Login
  12. Select one of these options:
    1. Use PIX4Ddiscovery to activate the limited version.
    2. Available licenses to select among existing licenses on the account.
13. Click OK.
PIX4Dmapper is now ready for processing.
Tip: To request a trial license for PIX4Dmapper, please follow the procedure described in this article: How to get a trial of PIX4Dmapper.
Language settings
The language setting on PIX4Dmapper can be changed at any time:
  1. Start PIX4Dmapper.
  2. On the menu bar, click Help > Settings...
    PIX4Dmapper settings
  3. In the window Settings, select the tab Language
    PIX4Dmapper language
  4. Click OK.
The changes will take effect when the software is restarted.
Upgrades
The most recent PIX4Dmapper version is always available for download from the download page and PIX4Dmapper technical release notes. Additionally, if a new version of PIX4Dmapper is available, a pop-up Software Upgrades with three options is displayed when the software is opened:
PIX4Dmapper Software Update Window
  • Download and Install Now: To download and install the latest version available.
  • Remind Me Later : To postpone the download or installation of the latest version. The pop-up will appear again in 10 days.
Note: If you have a One-Time Charge license (OTC), make sure you have an active Maintenance Plan. If the Maintenance Plan has expired, please download the latest version available for you by following this procedure.
If you have an active subscription or a rental license, you can always download and use the last version available supported by your Operating System.
Enabling remote device deactivation
In order to deactivate a device remotely, remote device deactivation needs to be enabled first.
For more information: Enable remote device deactivation for deactivating a device remotely - PIX4Dmapper.
