Using the Index Calculator - PIX4Dmapper
The use of the Index Calculator is optional and it can be used to:
  • Generate an Index Map / Index Grid where the color of each pixel is computed using a formula that combines different bands of the Reflectance Map(s).
  • Provide information about the bands of the Reflectance Map(s) and Index Map.
  • Visualize the Index Map as a Colored Index Map by applying a color mapping to it.
  • Export a georeferenced Colored Index Map.
  • Annotate the classes of the Index Map to generate an Application Map.
  • Export an Application Map as a shape file to be imported in any Tractors Consoles.
More information:
  • Index Calculator Manual: Full description of the different features: Menu View > Index Calculator.
  • Video Academy: Index Calculator:
  • Webinar: Index Calculator. Precision Agriculture:
Articles about how to use the Index Calculator:
