PIX4Dmapper
The leading photogrammetry software for professional drone mapping.
A project from A to Z
- Getting Started Index - PIX4Dmapper
- Step 1. Before Starting a Project - PIX4Dmapper
- Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan - PIX4Dmapper
- Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type - PIX4Dmapper
- Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > b. Computing the Flight Height for a given GSD - PIX4Dmapper
- Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > c. Computing the Image Rate for a given Frontal Overlap - PIX4Dmapper
- Step 1. Before Starting a Project > 2. Configuring the Camera Settings - PIX4Dmapper
- Step 1. Before Starting a Project > 3. Georeferencing the Images - PIX4Dmapper
- Step 1. Before Starting a Project > 4. Getting GCPs on the field or through other sources (optional but recommended) - PIX4Dmapper
- Step 2. Creating a Project - PIX4Dmapper
- Step 3. Before Processing (optional) - PIX4Dmapper
- Step 4. Processing - PIX4Dmapper
- Step 5. After Processing (optional) - PIX4Dmapper
Getting started
- How to get a trial of PIX4Dmapper
- How to define Pix4D outputs with respect to a Geoid model
- Sign up - PIX4Dmapper
- Computer requirements - PIX4Dmapper
- Get the most out of PIX4Dmapper
- Image acquisition - PIX4Dmapper
- Video tutorials - PIX4Dmapper
- New project in PIX4Dmapper
- Inputs and Outputs - PIX4Dmapper
- Processing options - PIX4Dmapper
- Processing steps - PIX4Dmapper
- Software download and installation - PIX4Dmapper
- Ground control points (GCPs) - PIX4Dmapper
Quick links
- Which Base Surface is recommended for the Volume Calculation? - PIX4Dmapper
- Merging multispectral projects in PIX4Dmapper
- FAQ on the accurate geolocation pipeline - PIX4Dmapper
- What is Carve? - PIX4Dmapper
- When to use the Geoid Height Above the Ellipsoid Function? - PIX4Dmapper
- How to modify the camera rig processing options - PIX4Dmapper
- Specifications of xmp.camera tags - PIX4Dmapper
- How to export the Automatic Tie Points? -PIX4Dmapper
- Input files -PIX4Dmapper
- Internal Camera Parameters Correlation - PIX4Dmapper
- Projected 2D length and terrain 3D length of polylines - PIX4Dmapper
- Using PIX4Dtagger - automatic target recognition - PIX4Dmapper
- Radiometric calibration target - PIX4Dmapper
- Can the Size of the Orthomosaic and DSM Tiles be defined? - PIX4Dmapper
- Radiometric corrections - PIX4Dmapper
- How to move a project from one machine to another? - PIX4Dmapper
- Error estimation in volume calculation - PIX4Dmapper
- Is it possible to obtain the DSM and / or Orthomosaic without processing Step 2. Point Cloud and Mesh? - PIX4Dmapper
- Can the Resolution of the Point Cloud be controlled? - PIX4Dmapper
- When is a GCP / Check Point highlighted with red color in the Quality Report? - PIX4Dmapper
- Which Cameras exist in PIX4Dmapper Database and which Parameters are used?
- Mosaic Editor Workflow - PIX4Dmapper
- Can PIX4Dmapper generate Outputs for 3D Printers?
- What is the difference between Automatic Tie Points and Manual Tie Points?
- How to set the band weights for modified cameras (NIR,R,G and NIR,G,B) - PIX4Dmapper
- How to use the rayCloud to improve the Accuracy? - PIX4Dmapper
- Camera Requirements for Precision Agriculture - PIX4Dmapper
- What does the Output Params Folder contain? - PIX4Dmapper
- When to use Alternative Processing Mode in Initial Processing? - PIX4Dmapper
- What is the bingo file generated during Initial Processing? - PIX4Dmapper
- Difference between "Reoptimize" and "Rematch and Optimize" - PIX4Dmapper
- How PIX4Dmapper calculates the Volume
- How many Points are generated during step 2. Point Cloud and Mesh? - PIX4Dmapper
- Manual Tie Points and GCPs in merged project - PIX4Dmapper
- What do the Crosses and Squares mean when Marking a Point in the rayCloud? - PIX4Dmapper
- Volume Difference of an Area Surveyed over different Time Periods - PIX4Dmapper
- Is there a Limit in the Number of Points that can be displayed in the rayCloud? - PIX4Dmapper
- What is the difference between theoretical error and the error to GCP initial position? - PIX4Dmapper
- What does step 1. Initial Processing do? - PIX4Dmapper
- Color and Number of Point Clouds / Orthomosaics depending on the used Camera(s) - PIX4Dmapper
- Image Correlation with PIX4Dmapper
- How are the Internal and External Camera Parameters defined? -PIX4Dmapper
- What does the Bingo File that is generated when clicking on Export Marks... contain? - PIX4Dmapper
- Does a Project processed with PIX4Dmapper Discovery need to be reprocessed with PIX4Dmapper?
- Processing Large Datasets - PIX4Dmapper
- What affects the Quality of the DSM? - PIX4Dmapper
- How to add Images to an Existing Project? - PIX4Dmapper
- Using GCPs - PIX4Dmapper
- Project Folder Structure - PIX4Dmapper
- How to import the Image Geolocation for Cameras without GPS? - PIX4Dmapper
- Quality Report Help - PIX4Dmapper
- How to process images taken at different Flight Heights / GSD? - PIX4Dmapper
- How to select Camera Focal Length and Flight Altitude considering the desired Ground Sampling Distance and Terrain to map? - PIX4Dmapper
- Maximum number of images per project and processing time - PIX4Dmapper
- Using the Index Calculator - PIX4Dmapper
- Using the Mosaic Editor - PIX4Dmappper
- How to merge projects - PIX4Dmapper
- Best Processing Options for Processing subprojects before Merging - PIX4Dmapper
- How to improve the outputs of dense vegetation areas using PIX4Dmapper?
- What are the output files after... -PIX4Dmapper
- Processing Options Default Templates - PIX4Dmapper
- Quality report specifications - PIX4Dmapper
- Full Processing vs Rapid / Low Resolution - PIX4Dmapper
- How to convert .laz files into .las/.ascii files? - PIX4Dmapper
- Using the rayCloud - PIX4Dmapper
Installation and login
- How to log in - PIX4Dmapper
- Technical release notes - PIX4Dmapper
- How to log out - PIX4Dmapper
- How to move a PIX4Dmapper license to another computer - PIX4Dmapper
- Step 3 processing option is not available: Discovery mode. - PIX4Dmapper
- Error e0062: Server Communicatino problem. Please try again later. - PIX4Dmapper
- Server error, cannot login - PIX4Dmapper
- PIX4Ddiscovery / Discovery mode - PIX4Dmapper
- Is an Internet connection needed? - PIX4Dmapper
- Can multiple users use the same or different licenses in one computer? - PIX4Dmapper
- PIX4Dmapper installation for computer lab
- Error: "pix4dmapper.exe has stopped working" while installing the software - PIX4Dmapper
- Error: "This installation package could not be opened. ...that this is a valid Windows Installer package." - PIX4Dmapper
- Remote device deactivation - PIX4Dmapper
- Error e0703a: Could not retrieve list of licenses. Invalid credentials. - PIX4Dmapper
- Installer shows modify, repair, remove option - PIX4Dmapper
- How to completely uninstall PIX4Dmapper - PIX4Dmapper
- Error: "There is a problem with this Windows Installer package.... A DLL required for this install to complete could not be run." - PIX4Dmapper
- Error: "Maximum number of devices already activated. Deactivate one of the active devices and try again. " - PIX4Dmapper
- Error: "Network error: Please check your internet connection. SSL handshake failed" - PIX4Dmapper
- Error: "This installation package is not supported by this processor type..." - PIX4Dmapper
- Error e0702a: "Could not authenticate. Invalid e-mail/password combination." - PIX4Dmapper
Hardware and computer setup
- PIX4Dmapper MacOS Incompatibility: Error e0060
- Hardware - PIX4Dmapper
- Hardware case study - PIX4Dmapper
- Hardware FAQ - PIX4Dmapper
- Long processing time with Xeon v3 processors - PIX4Dcloud
- How to modify the resources (cores and RAM) assigned for processing - PIX4Dmapper
- Long Processing Time for Step 3 with Quadro GPUs - PIX4Dmapper
- Processing speed - PIX4Dmapper
- Error e0094: It was not possible to initialize OpenGL. - PIX4Dmapper
- How to set up the Proxy Server Configuration - PIX4Dmapper
- How to verify the supported OpenGL versions of the graphics card - PIX4Dmapper
- Error: "Unable to recover from a kernel exception." - PIX4Dmapper
- Use of the GPU - PIX4Dmapper
- How to find information about the GPU in Windows - PIX4Dmapper
- PIX4Dmapper user interface does not display the texts properly
- What are the Advantages of the SLI Technology for Processing? - PIX4Dmapper
- CUDA not detected - PIX4Dmapper
- Hardware components usage during processing - PIX4Dmapper
- macOS / Windows XP / Linux / Remote access / Parallel processing - PIX4Dmapper
- How to use PIX4Dmapper on Azure Virtual Machines - PIX4Dmapper
- How to set the NVIDIA graphic card to maximize its resources? - PIX4Dmapper
- Error: "0xc0000005" PIX4Dmapper stopped working during processing
Troubleshooting
- Error e0200a: Cannot start processing - PIX4Dmapper
- "File Corrupted! This program has been manipulated and maybe it's infected by a Virus or cracked. This file won't work anymore" error - PIX4Dmapper
- Cannot purchase or renew a license - PIX4Dmapper
- List of troubleshooting articles for PIX4Dmapper
- Windows 11 and PIX4Dmapper
- Volume tab turns black - PIX4Dmapper
- Error e9013: Could not save subprojects - PIX4Dmapper
- How to export the quality report and log file -PIX4Dmapper
- Supported drones and cameras - PIX4Dmapper
- Error e0203a: Cannot generate DTM - PIX4Dmapper
- Error e9027: The coordinate sytem in file is not valid - PIX4Dmapper
- Black screen - PIX4Dmapper
- Error e9019: cannot extract EXIF info from image data - PIX4Dmapper
- Error e0013: Cannot import image location file - PIX4Dmapper
- Inconsistent Lighting / Striping - PIX4Dmapper
- High georeferencing errors in the quality report - PIX4Dmapper
- No calibrated images - PIX4Dmapper
- Camera Optimization Error - PIX4Dmapper
- Multiple blocks / Vertical Inaccuracies - PIX4Dmapper
- Display issues when using Windows Remote Access - PIX4Dmapper
- Warped or curved model - PIX4Dmapper
- Some uncalibrated images - PIX4Dmapper
- Orthomosaic too big for Autodesk Civil 3D - PIX4Dmapper
- PIX4Dmapper crash troubleshooting
- Error e0067: "Detected camera name_focal_resolution. This camera is not supported by this edition of PIX4Dmapper. To process more cameras, contact Pix4D."
- Error e0049: Error in the point cloud densification - PIX4Dmapper
- Big triangles generated in the DSM - PIX4dmapper
- Vertical shift between the model and the GCPs / Cannot mark the GCPs in the rayCloud - PIX4Dmapper
- Errors processing a Large Dataset - PIX4Dmapper
- Images and/or GCPs are not positioned correctly on the Map View - PIX4Dmapper
- Error e0046: "Processing failed." - PIX4Dmapper
- "This app has been blocked for your protection" - PIX4Dmapper
- Warning w0011: "The loaded .prj file does not contain the TOWGS84 parameter. This may lead to incorrect georeferencement." - PIX4dmapper
- How to correct for wrong image altitude without GCP - PIX4Dmapper
- Warning w0026: "Loading results failed: Incorrect coordinate system." - PIX4dmapper
- Rename images to place in same file directory - PIX4Dmapper
- Error: There is a significant difference between the Initial and Optimized Focal Length - PIX4Dmapper
- Exif/Xmp tags required for radiometric correction for multispectral camera - PIX4Dmapper
- Poisson Surface Reconstruction freezes at 40% while generating the 3D Textured Mesh - PIX4dmapper
- Error: Black Holes in the Point Cloud - green, orange and yellow Rectangles in the Overlap Map in the Quality Report - PIX4Dmapper
- Distortions and Artifacts in the Orthomosaic - PIX4Dmapper
- Error: "Error with the server" while uploading to Pix4D Cloud - PIX4Dmapper
- The 3D Textured Mesh does not cover the full area of the model - PIX4dmapper
- Some Areas of the DSM have a lot of Noise - PIX4Dmapper
- Error: The rayCloud does not display all / some layers, appears black / white or display artifacts - PIX4Dmapper
- Horizontal shift after a coordinate system transformation is applied - PIX4Dmapper
- Error: merged projects create more than one block and / or they do not adjust - PIX4Dmapper
- Color Discrepancy for Edited Regions in the Mosaic Editor - PIX4dmapper
- PIX4Dmapper shuts down when the Quality Report is displayed
- Corridor Project has Big Errors on the Edges - PIX4Dmapper
- Error e9034: Problem uploading item to the cloud - PIX4Dmapper
- Error e0050: "Orthomosaic generation stopped" - PIX4Dmapper
- Error e0400: "Cannot open project..." - PIX4Dmapper
Manual
- Software Manual > Table View - PIX4Dmapper
- PIX4Dmapper Software Manual > Blocks View - PIX4Dmapper
- Offline Getting Started and Manual (pdf) - PIX4Dmapper
- Software Manual > Index View - PIX4Dmapper
- Menu Project > GCP / MTP Manager... - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP / MTP Table - PIX4Dmapper
- Menu Project > Image Properties Editor... > Selected Camera Model - PIX4Dmapper
- Upload Project Files... - PIX4Dmapper
- Menu Project - PIX4Dmapper
- Menu Project > Image Properties Editor... > Selected Camera Model > Edit Camera Model - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP Coordinate System - PIX4Dmapper
- Interface - PIX4Dmapper
- Menu Project > Image Properties Editor... - PIX4Dmapper
- Menu View > Volumes - PIX4Dmapper
- Menu View > Volumes > 3D View - PIX4Dmapper
- Menu View > Index Calculator - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP / MTP Editor - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Triangle Meshes - PIX4Dmapper
- Menu View > rayCloud > Menu Bar -PIX4Dmapper
- Menu View > Map View > 2D View - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP / MTP Table > Add Point - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Automatic Tie Points - PIX4Dmapper
- Menu Process > Generate Contour Lines - PIX4Dmapper
- Menu View > Volumes > Menu Bar - PIX4Dmapper
- Menu Process > Generate 3D Textured Mesh - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers - PIX4Dmapper
- Menu View > rayCloud > Left Sidebar > Layers > Point Groups - PIX4Dmapper
- Menu Process > Send Map to eMotion - PIX4Dmapper
- Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud - PIX4Dmapper
- Menu Process > Generate DTM - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Create - PIX4Dmapper
- Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic - PIX4Dmapper
- Menu View > rayCloud > 3D View - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Point Clouds - PIX4Dmapper
- Menu Process > Run Point Cloud Classification - PIX4Dmapper
- Menu View > Mosaic Editor > View - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Objects - PIX4Dmapper
- Menu Process > Processing Options... > 1. Initial Processing > Matching - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Cameras - PIX4Dmapper
- Menu Process > Processing Options... > Resources and Notifications - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Rays - PIX4Dmapper
- Menu View - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 3. Index Map > Index Map (Formula Editor) - PIX4Dmapper
- Menu Process > Send Elevation Data (DSM) to eMotion - PIX4Dmapper
- Menu Process > Processing Options... > Templates - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 2. Regions - PIX4Dmapper
- Menu Process > Import Point Cloud for DSM Generation - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Cameras - PIX4Dmapper
- Menu Process > Reoptimize - PIX4Dmapper
- Menu Project > Image Properties Editor... > Images Table - PIX4Dmapper
- Menu Project > Image Properties Editor... > Image Geolocation - PIX4Dmapper
- Menu Process > Rematch and Optimize - PIX4Dmapper
- Menu View > Map View > Processing Area - PIX4Dmapper
- Menu Process > Generate Quality Report - PIX4Dmapper
- Menu Process > Save Undistorted Images - PIX4Dmapper
- Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Objects - PIX4Dmapper
- Menu Process > Processing Options... > 1. Initial Processing > Calibration - PIX4Dmapper
- Menu View > Volumes > Sidebar > Objects - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Tie Points - PIX4Dmapper
- Menu Process > Quality Report... - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 3. Index Map - PIX4Dmapper
- Menu View > Volumes > Sidebar > Layers - PIX4Dmapper
- Menu View > Map View - PIX4Dmapper
- Menu View > rayCloud > Toolbar - PIX4Dmapper
- Menu Process > Open Results Folder - PIX4Dmapper
- Menu View > rayCloud - PIX4Dmapper
- Menu View > Mosaic Editor > Mosaic Editing - PIX4Dmapper
- Menu Process > Processing Options... > 1. Initial Processing > General - PIX4Dmapper
- Menu View > Volumes > Sidebar - PIX4Dmapper
- Menu View > Mosaic Editor - PIX4Dmapper
- Menu View > Home - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 3. Index Map > Index List - PIX4Dmapper
- Menu Project > Basic GCP / MTP Editor > Preview - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Clipping Box - PIX4Dmapper
- Menu Project > Basic GCP / MTP Editor > GCP / MTP Table - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP / MTP Table > Import GCPs... - PIX4Dmapper
- Menu Project > Select Output Coordinate System... - PIX4Dmapper
- Menu Project > Basic GCP / MTP Editor > Images - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Processing Area - PIX4Dmapper
- Menu Project > Basic GCP / MTP Editor - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > GCPs and Manual Tie Points - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP / MTP Table > Import / Export Marks - PIX4Dmapper
- Menu Process > Output Status... - PIX4Dmapper
- Menu Process - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 1. Reflectance Map - PIX4Dmapper
- Menu View > Mosaic Editor > Visualization - PIX4Dmapper
- Menu View > rayCloud > Left sidebar > Layers > Point Clouds - PIX4Dmapper
- Menu Process > Processing Options... > 2. Point Cloud and Mesh > 3D Textured Mesh - PIX4Dmapper
- Menu View > rayCloud > Right sidebar - PIX4Dmapper
- Menu Process > Processing Options - PIX4Dmapper
- Menu Process > Processing Options... > 2. Point Cloud and Mesh > Advanced - PIX4Dmapper
- Menu Project > GCP / MTP Manager... > GCP / MTP Table > Remove Points - PIX4Dmapper
- Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Additional Outputs - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Processing Area - PIX4Dmapper
- Menu View > rayCloud > Left sidebar - PIX4Dmapper
- Menu View > Index Calculator > Sidebar - PIX4Dmapper
- Export Image Geolocation/ Ground Control Points - PIX4Dmapper
- Menu View > Processing - PIX4Dmapper
- Keyboard shortcuts - PIX4Dmapper
- Select Geolocation File - PIX4Dmapper
- Menu View > Log Output - PIX4Dmapper
- Floating license - PIX4Dmapper
- Read-only Mode During Processing - PIX4Dmapper
- Index Database List - PIX4Dmapper
- Menu View > rayCloud > Right sidebar > Images section - PIX4Dmapper
- Displaying bars - PIX4Dmapper
- Menu Help - PIX4Dmapper
- GCP / Manual Tie Point Table - PIX4Dmapper
- Select Image / GCP / Output Coordinate System - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 5. Export - PIX4Dmapper
- Menu View > Index Calculator > Sidebar > 4. Color Maps and Prescription - PIX4Dmapper
How to... (step-by-step instructions)
- How to calculate a Volume from a specific Base Altitude - PIX4Dmapper
- How to capture and process data with Parrot ANAFI Thermal - PIX4Dmapper
- How to import and mark ground control points (GCPs) - PIX4Dmapper
- How to generate the point cloud classification - PIX4Dmapper
- How to improve the Outputs of PIX4Dmapper
- How to geolocate the Images so that the Geolocation is imported - PIX4Dmapper
- How to import and mark Manual Tie Points (MTPs) - PIX4Dmapper
- How to remove Objects from a Stockpile for the Volume Computation - PIX4Dmapper
- How to remove the Sky from the Point Cloud using the Annotation Tool - PIX4Dmapper
- How to process a single step - PIX4Dmapper
- How to mark GCPs in the rayCloud - PIX4Dmapper
- How to navigate in the 3D View in the rayCloud and the Volumes View - PIX4Dmapper
- How to visualize a Point Cloud in the rayCloud - PIX4Dmapper
- How to verify that the GCP Geolocation is Correct - PIX4Dmapper
- How to do a Rapid Check of the Dataset while still being in the Field - PIX4Dmapper
- How to generate the Google Maps Tiles and KML - PIX4Dmapper
- How to remove the Background of the Orthoplane using the Annotation Tool - PIX4Dmapper
- How to create a User Processing Options Template - PIX4Dmapper
- How to verify that the Image Geolocation and the Image Coordinate System are correct - PIX4Dmapper
- How to automatically generate a Digital Terrain Model (DTM) - PIX4Dmapper
- How to add / import and mark manual tie points (MTPs) in the Basic GCP / MTP Manager - PIX4Dmapper
- How to edit a Volume - PIX4Dmapper
- How to create a Processing Options Template .tmpl File - PIX4Dmapper
- How to georeference a Project without Image Geolocation, only with 2D GCPs - PIX4Dmapper
- How to generate contour lines - PIX4Dmapper
- How to export the 3D textured mesh - PIX4Dmapper
- How to edit Objects in the rayCloud - PIX4Dmapper
- How to split a project into subprojects - PIX4Dmapper
- How to verify that the Image Quality is sufficient - PIX4Dmapper
- How to process Sequoia imagery - PIX4Dmapper
- How to geolocate Images using a GPX File with GeoSetter - PIX4Dmapper
- How to compute a Site Calibration file - PIX4Dmapper
- How to export the marks of tie points in the GCP/MTP Manager - PIX4Dmapper
- How to delete Object Vertices - PIX4Dmapper
- How to model small objects - PIX4Dmapper
- How to process a Tetracam dataset - PIX4Dmapper
- How to verify that at least 75% of the Images have good Geolocation - PIX4Dmapper
- How to import a Processing Options Template - PIX4Dmapper
- How to import an Animation Trajectory to the rayCloud - PIX4Dmapper
- How to calibrate a Perspective Lens Camera - PIX4Dmapper
- How to import the marks of GCPs/MTPs with the GCP/MTP Manager - PIX4Dmapper
- How to use the Site Calibration Parameters - PIX4Dmapper
- How to remove obstacles from the point cloud in the rayCloud using the Annotation Tool - PIX4Dmapper
- How to use the Clipping Box in the rayCloud - PIX4Dmapper
- How to edit the point cloud in the rayCloud - PIX4Dmapper
- How to generate the 3D Textured Mesh - PIX4Dmapper
- How to process images of a spherical camera - PIX4Dmapper
- How to convert the Camera Model Internal Parameters from Brown 1964/ Heikkila 1997/ Fraser 1997 to Pix4D Camera Model Definition - PIX4Dmapper
- How to export Volumes - PIX4Dmapper
- How to update a Volume after editing the Point Cloud - PIX4Dmapper
- How to measure Distances, Areas or Volumes - PIX4Dmapper
- How to correct for the Rolling Shutter Effect - PIX4Dmapper
- How to align projects - PIX4Dmapper
- How to assign images to two Camera Models - PIX4Dmapper
- How to create a Region with the Index Calculator - PIX4Dmapper
- How to merge Images with different Spectral Signatures (RGB, NIRGB, etc) - PIX4Dmapper
- How to download / open a previously uploaded PIX4Dcloud project - PIX4Dmapper
- How to export an Animation Trajectory with the rayCloud - PIX4Dmapper
- How to generate the 3D Textured Mesh from a portion of the Point Cloud - PIX4Dmapper
- How to create a Video Animation Trajectory in the rayCloud - PIX4Dmapper
- How to improve the 3D Textured Mesh - PIX4Dmapper
- How to verify that the GCP Geolocation and the GCP Coordinate System are Correct - PIX4Dmapper
- How to import a volume into Volumes - PIX4Dmapper
- How to filter Images for the Texture Generation of the 3D Textured Mesh - PIX4Dmapper
- How to export the Point Cloud - PIX4Dmapper
- How to verify that the Camera Model associated to the Camera is Correct - PIX4Dmapper
- How to merge the Tiles of the Point Cloud - PIX4Dmapper
- How to verify that the GCP Coordinate System can be transformed to the Output Coordinate System - PIX4Dmapper
- How to process Images with 4 or more Bands - PIX4Dmapper
- How to import a Point Cloud delivered by an External Source into PIX4Dmapper for processing
- How to create the orthomosaic of a facade - PIX4Dmapper
- Edit, Add, and Delete Indices and Formulas in the Index Calculator - PIX4Dmapper
- How to obtain or create a .prj coordinate system syntax file - PIX4Dmapper
- How to draw a Surface in the rayCloud - PIX4Dmapper
- How to manually calibrate uncalibrated Cameras in the rayCloud - PIX4Dmapper
- How to orient a project - PIX4Dmapper
- How to draw a Polyline in the rayCloud - PIX4Dmapper
- How to improve the Visual Aspect of Buildings in the Orthomosaic with the Mosaic Editor - PIX4Dmapper
- How to generate a Colored Index Map in the Index Calculator - PIX4Dmapper
- How to generate an Index Map / Index Grid in the Index Calculator - PIX4Dmapper
- How to correct Building Artifacts in the DSM and Orthomosaic - PIX4Dmapper
- How to obtain the georeference using 2D or 3D GCPs taken from a Web Map Service - PIX4Dmapper
- How to draw a new orthoplane - PIX4Dmapper
- How to reduce the Size of the Orthomosaic - PIX4Dmapper
- How to change the processing options - PIX4Dmapper
- How to correct Building Artifacts in the DSM and Orthomosaic with the rayCloud - PIX4Dmapper
- How to improve the Visual Aspect of Bridges in the Orthomosaic with the Mosaic Editor - PIX4Dmapper
- How to map and measure Pole and Tower Structures - PIX4Dmapper
- How to scale a project - PIX4Dmapper
- How to Annotate Images in the rayCloud - PIX4Dmapper
- How to process Images with different Spectral Signature (RGB, NIRGB, etc) - PIX4Dmapper
- How to add / import GCPs using the Basic GCP/MTP Editor - PIX4Dmapper
- How to edit the Color Mapping in the Index Calculator - PIX4Dmapper
- How to select / change the Image / GCP / Output Coordinates System - PIX4Dmapper
- How to visualize a Triangle Mesh in the rayCloud - PIX4Dmapper
- How to get the PIX4Dmapper Measurements in feet - PIX4Dmapper
- How to include GCPs in the project - PIX4Dmapper
- How to export Manual Tie Points and/or GCPs in the rayCloud - PIX4Dmapper
- How to draw a Volume - PIX4Dmapper
- How to change the Processing Options to generate fewer 3D Points - PIX4Dmapper
- How to calibrate a Fisheye Lens Camera - PIX4Dmapper
- How to use Videos for Processing - PIX4Dmapper
- How to use the Editing Camera Model Options - PIX4Dmapper
- How to import/export the images geolocation and orientation - PIX4Dmapper
- How to change the Camera Initial Values to the Optimized Values - PIX4Dmapper
- How to edit the Orthomosaic - PIX4Dmapper
- How to use a Processing Area - PIX4Dmapper
- How to add / import GCPs in the GCP/MTP Manager - PIX4Dmapper
- How to remove Images from a Project - PIX4Dmapper
- How to export objects in the rayCloud - PIX4Dmapper
- How to add / import and mark manual tie points (MTPs) in the rayCloud - PIX4Dmapper
- How to import and mark GCPs in the rayCloud - PIX4Dmapper
