PIX4Dcloud
The online platform for ground and drone mapping, progress tracking, and site documentation
Getting started
- Get the most out of PIX4Dcloud
- Best practices and capabilities for PIX4Dcloud
- PIX4Dcloud Starter vs PIX4Dcloud Pro: Feature Comparison
- My first PIX4Dcloud project from A to Z - PIX4Dcloud
- New dataset > Dataset creation > Upload images - PIX4Dcloud
- New dataset > Dataset creation > Upload outputs - PIX4Dcloud
- New dataset > Image selection > Credit balance system - PIX4Dcloud
- New dataset > Processing options > Output coordinate system - PIX4Dcloud
- Georeference of datasets, outputs and annotations - PIX4Dcloud
- New dataset > Processing options - PIX4Dcloud
- New dataset > GCPs automatization > Processing with GCPs/checkpoints - PIX4Dcloud
- New dataset > GCPs automatization > Processing without GCPs/checkpoints - PIX4Dcloud
- Quality report Help - PIX4Dcloud
- Video tutorials - PIX4Dcloud
Account, License & Organization
- Reconstruction Quality Survey in PIX4Dcloud
- Updates to PIX4Dcloud Plans for 2026
- PIX4Dcloud - External Communication and Third-Party Services
- Trial license – PIX4Dcloud Pro
- Sign-up, login and logout - PIX4Dcloud
- Proxy / firewall configuration - PIX4Dcloud
- PIX4Dcloud Retention and Storage Policy
- About - PIX4Dcloud
- Decommissioning Notice: PIX4Dmapper Legacy Processing Pipeline in Cloud Products
Features & Tools
- Drive Map View - PIX4Dcloud
- Folder in PIX4Dcloud
- Dataset in PIX4Dcloud
- Editor viewer in PIX4Dcloud
- Layers - Left Content Panel - PIX4Dcloud
- Details panel in PIX4Dcloud
- Annotations in PIX4Dcloud
- Inputs - PIX4Dcloud user interface
- Region of interest in PIX4Dcloud
- Dataset Details section on PIX4Dcloud
- Outputs - PIX4Dcloud
- Download/Export - PIX4Dcloud
- Measurement tools and view controls in 2D/3D viewer - PIX4Dcloud
- Export/import annotations in PIX4Dcloud
- Share functionality - PIX4Dcloud
- Virtual Inspector tool - PIX4Dcloud
- Volume calculation in PIX4Dcloud
- First person camera control view on PIX4Dcloud
- Field boundary tool in PIX4Dcloud
How to... (step-by-step instructions)
- How to verify that there is enough overlap between images - PIX4Dcloud
- How to verify that the image quality is sufficient - PIX4Dcloud
- How to define a project coordinate system in PIX4Dcloud
- How to verify coordinate systems in PIX4Dcloud projects
- How to use Ground Control Points (GCPs) for processing on PIX4Dcloud
- Working with Gaussian Splat Models in PIX4Dcloud
- Uploading Project Files from PIX4Dmapper to PIX4Dcloud for Processing - PIX4Dmapper
- How to check the upload status on PIX4Dcloud
- How to optimally visualize the Point Cloud in 3D on PIX4Dcloud
- How to visualize a project with Autotags in PIX4Dcloud
- How to visualize a site localization project on PIX4Dcloud
- How to download the results from PIX4Dcloud
- How to upload or replace results to PIX4Dcloud
- How to delete a line or polygon vertex on PIX4Dcloud
- Import IFC and DXF for AR Visualization in PIX4Dcloud Pro
- How to generate an Elevation profile on PIX4Dcloud
PIX4Dcloud Pro
- What are the extra features included in PIX4Dcloud Pro?
- AutoGCPs detection functionality - PIX4Dcloud Pro
- GCPs layer - PIX4Dcloud Pro
- Site - PIX4Dcloud Pro
- Timeline - PIX4Dcloud Pro
- 2D/3D Comparison - PIX4Dcloud Pro
- Compare volumes - PIX4Dcloud Pro
- Design Overlay (2D/3D)- PIX4Dcloud Pro
- Image attached to an annotation in PIX4Dcloud Pro
- Annotations report - PIX4Dcloud Pro
- Import and visualize an IFC file on PIX4Dcloud Pro
PIX4Dcloud Enterprise TAC - API - SSO
- PIX4Dcloud Enterprise features
- Team Access Control on licenses - PIX4Dcloud Enterprise
- Team Access Control on resources - PIX4Dcloud Enterprise
- PIX4Dcloud Enterprise - API documentation
- How to check the activity logs in PIX4Dcloud Enterprise with API access
- Privacy Filter in PIX4Dcloud
- Single Sign-On (SSO) in PIX4Dcloud Enterprise
Third-party integrations
Troubleshooting
- Troubleshooting PIX4Dcloud Processing Errors
- Error while processing a project - PIX4Dcloud
- 2D/3D output is missing / functionality is not available - PIX4Dcloud
- Detection of the GCPs failed - PIX4Dcloud
- Misalignment between images and GCPs in PIX4Dcloud Pro dataset creation wizard
- Incorrectly Oriented Reconstructions in PIX4Dcloud or PIX4Dmatic
- Common Output Upload Failures in PIX4Dcloud
- Lagging or poor visualization when viewing 3D models - PIX4Dcloud
- Annotations cannot be saved in PIX4Dcloud
- Web browser optimization for faster dataset upload speed - PIX4Dcloud
- Unable to Process Projects from PIX4Dmatic to PIX4Dcloud
- How to georeference, scale and rotate a DXF file using AutoCAD - PIX4Dcloud
FAQ
Technical release notes
- Technical release notes - PIX4Dcloud
- [2025] Technical release notes - PIX4Dcloud
- [2024] Technical release notes - PIX4Dcloud
- [2023] Technical release notes - PIX4Dcloud
- [2022] Technical release notes - PIX4Dcloud
- [2021] Technical release notes - PIX4Dcloud
- [2020] Technical release notes - PIX4Dcloud
