English
What are the processing options - PIX4Dcloud
This article describes the processing options available in PIX4Dcloud, depending on how a project is created and uploaded.
Licenses: This article is valid for PIX4Dcloud Starter and PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can upload and process datasets in PIX4Dcloud.
Upload directly to PIX4Dcloud
When images are imported using the New dataset workflow in PIX4Dcloud Starter or PIX4Dcloud Pro, the user can select one of the available processing templates.
Available processing templates
  • Nadir Flight (3D Maps)
    Designed for aerial RGB images acquired with a grid flight plan and high overlap, primarily oriented toward the ground. Typical use cases include quarries, cadastral mapping, and land surveying.
    • Flat Terrain
      Optimized for RGB aerial images acquired with high overlap over flat or low-texture areas, such as agricultural fields, deserts, and airports.
  • Oblique Flight (3D Models)
    Intended for RGB image sets with high overlap, including oblique or free-flight acquisitions. Typical applications include building reconstruction, object modeling, and inspections.
Note: For advanced customization of processing options, the project can be created in PIX4Dmatic and uploaded to PIX4Dcloud.
Upload from PIX4Dmapper
rojects can be created in PIX4Dmapper and uploaded to PIX4Dcloud Starter or PIX4Dcloud Pro for processing. In this case, the processing options defined in PIX4Dmapper are used.
This workflow requires:
  • A valid PIX4Dmapper license
  • A valid PIX4Dcloud or PIX4Dcloud Pro license
  • Sufficient processing credits
Starting in February 2026, note that datasets will be processed with the new pipeline using a nadir or oblique template.
The only inputs that are considered during processing are: Only input images, the CRS from the .p4d file, and potentially GCPs/Marks will be considered.
Warning: No Custom Settings Applied from the .p4d file starting February 2026. For more information Decommissioning Notice: PIX4Dmapper Legacy Processing Pipeline in Cloud Products.
Upload from PIX4Dcatch
Projects captured with PIX4Dcatch can be uploaded directly to PIX4Dcloud or PIX4Dcloud Pro for processing.
The following processing options can be selected:
  • Measure Volumes and Elevation Profiles: generates a DSM
  • 2D Map: generates an orthomosaic
For more information, Processing projects - PIX4Dcatch.
Upload from PIX4Dmatic
Projects can be created in PIX4Dmatic and uploaded to PIX4Dcloud Starter or PIX4Dcloud Pro for processing. In this workflow, the available processing options are the same as those described in following article: Processig in PIX4Dcloud- PIX4Dmatic.
