Download/Export - PIX4Dcloud
PIX4Dcloud allows exporting/downloading inputs, outputs, and reports.
Licenses: This article is valid for all PIX4Dcloud licenses.
Roles: Only Owners, Managers, and Editors can download outputs from a datasets in PIX4Dcloud.
Information:
To export the files:
  1. Open an already created dataset.
  2. Go to Files & Exports > Download. The list of downloadable items is displayed.
  3. Follow the specific workflow for the download according to the needed outputs.
Important:
  • The download does not start immediately for the Input files and the results folder, but an email with the downloadable folder is sent when this one is ready.
  • Refer to the following article to determine which outputs are available for download based on the license type, upload method, and selected processing options: Outputs - PIX4Dcloud
  • Outputs are downloaded per dataset (Files & Exports > Download). PIX4Dcloud does not offer a bulk download of several datasets, folders or sites at once, and PIX4D does not provide a data-export service. To keep a local copy before a license expires, download the outputs of each dataset; see Storage policy – PIX4Dcloud.
The file is downloaded on the local device and can be opened in third-party software.
Warning: It is possible that trying to unzip the results with the default Windows unzip program does not let you perform this action, as is present in some project names. In that case, it is recommended to install the 7zip tool and try again.
Continue a PIX4Dcloud project in PIX4Dmatic: datasets processed on PIX4Dcloud (created in the web interface, uploaded from PIX4Dcatch, uploaded from PIX4Dmatic via PIX4Dcloud > Process, or uploaded from PIX4Dmapper since March 2026) can be opened in PIX4Dmatic 2.4.0 or later with File > Download from PIX4Dcloud... Only the calibration and dense point cloud results are downloaded into the PIX4Dmatic project. More information: Download from PIX4Dcloud – PIX4Dmatic.
