Unable to Process Projects from PIX4Dmatic to PIX4Dcloud
This article explains the most common causes of issues when processing projects from PIX4Dmatic to PIX4Dcloud, and provides guidance to troubleshoot and resolve them.
Licenses: This feature is available only to PIX4Dcloud Starter and PIX4Dcloud Pro licenses.
Roles:
  • Only Owners can buy licenses and credits
  • Only Owners, Managers and Editor can upload datasets from PIX4Dmatic to PIX4Dcloud.
Issue description / Cause
Users may be unable to process a project from PIX4Dmatic to PIX4Dcloud due to one or more of the following reasons:
  1. License issues:
    • A “License required” pop-up appears when attempting to process in PIX4Dcloud.
    • PIX4Dmatic and PIX4Dcloud licenses do not belong to the same Organization or the PIX4Dcloud license is expired or inactive.
  2. Dataset exceeds image limit:
    • PIX4Dcloud supports up to 4,000 images per project.
    • Projects exceeding this limit cannot be processed.
  3. Insufficient processing credits:
    • The Organization does not have enough PIX4Dcloud credits to process the dataset.
    • PIX4Dmatic does not notify users if credits are insufficient; the dataset will remain in “waiting for credits” status until more credits are available.
Possible solutions / Checks
  1. Check license validity:
    • Open your Organization Dashboard.
    • Confirm both PIX4Dmatic and PIX4Dcloud licenses belong to the same Organization.
    • Verify the PIX4Dcloud license is active and valid.
  2. Verify image limit:
    • Ensure the dataset contains 4,000 images or fewer.
    • If necessary, reduce the number of images or split the project into smaller datasets.
  3. Confirm credit availability:
