Mission Planner (Retiring end of July 2025)
  1. Pix4D Documentation
  2. PIX4Dcloud
  3. Mission Planner (Retiring end of July 2025)
Mission Management - Mission Planner - PIX4Dcloud
This article goes step by step through the process of Mission management using Mission Planner.
Warning: The application will be retired at the end of July 2025. More communications will come in the upcoming weeks.
Video: The following video tutorial explains step-by-step how to create a new mission with the Mission Planner feature in PIX4Dcloud.
Mission list
Missions are the essential components of the plans. The first view will display the list of missions available by entering a plan. The missions will also be represented on the map with the coverage of the flight.
The mission list contains all the different plans and some basic information, such as:
  1. Mission name: name of the mission.
  2. Type: the type of mission (Cylinder, Grid, or Orbit mission).
  3. Date creation: date of mission creation.
  4. Date update: date of the last modification of mission.
Create new mission
Clicking on the New mission button opens a new dialog to set the new mission creation options: mission name, drone model, camera model, and mission type. Once these options are set, the user will be redirected to the mission edition view (Mission edition - Mission Planner).
Options
Every row contains a section that enables the execution of different actions by clicking on themore_vertical.pngicon:
  1. Duplicate mission: by duplicating a mission it will be copied inside the current plan with the same parameters.
  2. Rename mission: rename the mission.
  3. Delete mission: deletes the mission.
  4. Link to PIX4DCloud: allows to assign a cloud dataset to the mission by copy and paste the dataset URL.
Edit Mission
Or the edit.pngicon:
  1. Edit mission: access to the mission edition view (Mission edition - Mission Planner).
Export a Mission to PIX4Dcapture Pro
Warning: Please note that missions created in Mission Planner cannot be exported to other software outside of Pix4D. Missions can only be exported to PIX4Dcapture Pro.
Important: An internet connection and a valid PIX4Dcloud license are required to download the plans into PIX4Dcapture Pro.
To download a plan from Mission Planner into PIX4Dcapture Pro, follow these steps:
  1. Design the data acquisition plan in Mission Planner.
  2. Launch PIX4Dcapture Pro app while connected to the internet.
  3. In the dashboard, select Plans.
  4. Tap on Import plans located at the bottom right of the screen.
  5. A new dialog box with the list of available Plans to download will appear.
  6. Select a Plan to download into the PIX4Dcapture Pro app and tap Download.
  7. The downloaded plan appears in the list of plans.
Note: Only the plans containing generic missions (corridor, cylinder, grid, orbit) can be downloaded into PIX4Dcapture Pro. The asset types such as Cell Tower and Transmission Tower can't be pre-planned in the Mission Planner.
