FAQ - PIX4Dcloud
This article provides an overview of PIX4Dcloud and PIX4Dcloud Pro (formerly PIX4Dcloud Advanced), including licensing, requirements, supported workflows, and data management information.
Licenses: This article is valid for all PIX4Dcloud licenses.
General
What is PIX4Dcloud?
PIX4Dcloud is a cloud-based platform for drone mapping, progress tracking, and site documentation. It enables users to process, visualize, and share 2D and 3D models easily for efficient collaboration. Learn more.
PIX4Dcloud can be used in essentially any web browser. Google Chrome is recommended.
What are the differences between PIX4Dmapper/PIX4Dmatic and PIX4Dcloud?
PIX4Dmapper and PIX4Dmatic are desktop applications that offer full control over projects, including editing point clouds, adding Ground Control Points (GCPs), and fine-tuning processing settings.
PIX4Dcloud simplifies the workflow with predefined processing templates and online sharing options for quick and collaborative analysis.
What are the differences between PIX4Dcloud and PIX4Dcloud Pro?
PIX4Dcloud Pro includes all PIX4Dcloud features plus:
  • Timeline and project grouping for monitoring site progress.
  • AutoGCPs for automated ground control point detection.
  • Design map and plan overlay.
  • Volume and 2D/3D comparison tools.
  • IFC file import and visualization.
    Feature comparison table
Is Single Sign-On (SSO) supported?
SSO is not available by default in PIX4Dcloud or PIX4Dcloud Pro. It is included in the Enterprise solution. Contact sales
License and Subscription
How to try PIX4Dcloud Pro?
You can explore demo projects at cloud.pix4d.com/demo without a PIX4D account or license.
To process your own datasets, request a PIX4Dcloud Pro trial.
How to buy a subscription?
Subscriptions for PIX4Dcloud and PIX4Dcloud Pro can be purchased online from the PIX4D Store.
Existing PIX4D users can add products via Manage my subscription plan.
  • Accounts created before June 1, 2023: Small, Medium, or Large allowances are available.
  • Accounts created after June 1, 2023: Credits can be purchased in packages (e.g., +100, +500, +1000, +2500, +10,000).
    Learn more about the credit system
How to purchase credits?
(Owners and Managers only)
  1. Log in at https://cloud.pix4d.com/login.
  2. Open Account Settings.
  3. Select Home to view all Organizations.
  4. Click Dashboard next to the Organization.
  5. Open Credit History.
  6. Select a credit package.
  7. (Optional) Enable auto top-up.
Information:
  • Credits can only be purchased with an active PIX4Dcloud license.
  • In the case of PIX4Dcatch individual licenses (specifically designed for licenses for RTK kits) extra credit packages can be purchased.
How many images can I process in a single project?
Each project can include up to 4000 images. The number of images and total projects depends on the active subscription or credits.
How to buy more projects, image allowance, or credits?
During the trial, users can upgrade by purchasing a subscription from the PIX4D Store.
  • Allowance-based accounts: Upgrade via Manage my subscription plan.
  • Credit-based accounts: Follow How to purchase credits? for instructions.
If the subscription was acquired through a reseller, contact PIX4D Sales or your reseller to purchase additional allowances.
How to cancel a subscription plan?
Subscriptions can be canceled at any time.
How to upgrade from PIX4Dcloud Starter to PIX4Dcloud Pro?
A direct upgrade option is unavailable. To upgrade:
  1. Cancel the current license.
  2. Purchase a new PIX4Dcloud Pro license.
Purchasing before cancellation may result in overlapping invoices. Credits remain unaffected unless the account is inactive for more than two months.
Note: Upgrading the PIX4Dcloud license does not affect credits.
Credits will be deleted only when the system detects that the user account has not had a valid license for more than two months.
How to downgrade from PIX4Dcloud Pro to PIX4Dcloud Starter?
Downgrading follows the same procedure as upgrading:
  2. Purchase a new PIX4Dcloud license.
How many users can share the same license?
There is no user limit under Organization Management.
  • Owner, Manager, and Editor roles: Full access to create, edit, and delete resources.
  • Reader and Member roles: Limited access.
    Learn more about roles
How to download an invoice from my Organization?
Only the Owner can download the invoice from an Organization.
The steps for downloading the invoice are described in the Billing & Payment section of the Organization settings article.
Can I manually mark GCPs directly in PIX4Dcloud if my targets are not detected by the AutoGCP algorithm?
Manual marking of Ground Control Points (GCPs) is not directly available inside the PIX4Dcloud web interface, as the cloud platform relies on the automated AutoGCP algorithm (which requires specific black and white diagonal targets).
If you are using alternative target designs or need to manually mark your GCPs, you can easily achieve this workflow using PIX4D desktop products (PIX4Dmatic or PIX4Dmapper) by following these steps:
  1. Import your project images into the desktop software (PIX4Dmatic or PIX4Dmapper).
  2. Manually mark the GCPs within the desktop interface and tie them to your images.
  3. Upload to Cloud: Instead of processing locally, use the built-in desktop option to "Upload to PIX4Dcloud" to handle the heavy processing on the cloud while retaining your manually marked GCP configurations. For more information, Upload to PIX4Dcloud - PIX4Dmatic & Uploading project files from PIX4Dmapper to PIX4Dcloud.
What is Organization Management?
Organization Management enables centralized control of licenses, projects, and access permissions. Administrators can assign roles and manage resources securely.
More information
Cloud products within an Organization
PIX4Dcloud and PIX4Dcloud Pro can be managed under the same organization.
Learn more
Can I transfer projects to another user?
Yes, project transfer is supported within Organizations. Conditions:
  • Both accounts must belong to an Organization.
  • Only Owners or Managers can transfer projects.
  • Both Organizations must have valid PIX4Dcloud licenses.
  • Only Processed projects can be moved.
Multiple processed projects can be transferred simultaneously.
Transfer folders, sites, and projects
Requirements
Supported browsers and operating systems
PIX4Dcloud supports the latest versions of the following browsers on Windows 10+ and macOS:
  • Google Chrome (the most recommended on this list)
  • Mozilla Firefox
  • Microsoft Edge
  • Safari
For large projects, use 64-bit browsers.
Hardware and software requirements
As a cloud solution, no dedicated hardware is required. Ensure:
  • GPU and browser are up to date.
  • A stable, high-speed internet connection.
Proxy or firewall configuration
If a proxy or firewall is used, configure exceptions as described in
Proxy/firewall configuration when working with PIX4Dcloud.
How to download PIX4Dcloud?
No installation is required. Access PIX4Dcloud directly at cloud.pix4d.com.
Inputs and Outputs
Inputs
PIX4Dcloud supports:
  • Images for processing and visualization.
  • Existing results (orthomosaic, DSM, 3D mesh, point cloud).
  • PRJ files defining output coordinate systems.
PIX4Dcloud Pro additionally supports:
  • Ground Control Points (GCPs) and Checkpoints (CPs).
Full list of inputs
Warning: Multispectral and thermal imagery is not supported for processing in PIX4Dcloud.
Outputs
Processed outputs may include:
  • Geoferenced Gaussian splat model (PIX4Dcatch/PIX4Dcloud Pro only).
  • Dense point cloud.
  • 3D textured mesh.
  • Digital Surface Model (DSM).
  • Orthomosaic.
  • User-created annotations.
Full list of outputs
Is PPK workflow supported?
No, the PPK workflow is not supported in PIX4Dcloud.
Is there a limit to the number of datasets (projects) I can process?
There is no limit to the number of datasets (projects) that can be created in PIX4Dcloud/PIX4Dcloud Pro. However, note that no more than 4000 images can be processed per dataset.
Processing results
Typical results include:
Supported drones and cameras
Pix4D supports a wide range of drones and cameras for aerial and terrestrial image acquisition.
Supported drones and cameras list
Note: Unsupported cameras can still produce usable results if the images meet photogrammetric requirements.
Maximum number of images
PIX4Dcloud supports projects with up to 4000 images. Success depends on project complexity and desired outputs.
More information
Uploading local results
Locally processed outputs can be uploaded and shared on PIX4Dcloud.
How to upload results and outputs
Downloading projects
Input images and outputs can be downloaded from the Files section of a project.
Only project Owners can download project files.
How to download results from PIX4Dcloud
Gaussian splat model availability
  • Projects created with PIX4Dcatch: Supported with all licenses.
  • Projects created directly on PIX4Dcloud: Requires PIX4Dcloud Pro.
    Learn more about Gaussian splats
Can I generate a Digital Terrain Model (DTM) or Contour Lines directly in PIX4Dcloud?
No. DTMs and contour lines cannot be directly calculated or generated within the PIX4Dcloud platform environment. PIX4Dcloud processes photogrammetric data to generate standard cloud outputs such as 3D point clouds (.laz/.las), 3D textured meshes (.obj/.slpk), DSMs (.tif), and orthomosaics (.tif).
If your project requires a DTM or contour lines, generate these deliverables usingPIX4Dmatic / PIX4Dsurvey.
Functionalities
How to process images on PIX4Dcloud
Create a project and upload images directly in PIX4Dcloud.
Alternative workflows:
  • Upload from PIX4Dmapper (requires both licenses).
  • Upload from PIX4Dmatic.
  • Upload from PIX4Dcatch.
    New dataset workflow
Processing options
Select a predefined processing template when creating a new dataset.
Templates and processing options
Sharing results
Projects and results can be shared with external collaborators via a public or private link.
Share projects
Analysis tools
PIX4Dcloud provides tools to:
  • Measure distances, areas, and volumes.
  • Add markers and annotations.
  • Create elevation profiles.
  • Inspect images.
PIX4Dcloud Pro adds:
  • Volume and 2D comparisons for progress tracking.
  • Design overlay tools to compare as-built vs. as-designed.
    Analysis tools overview
Using GCPs
  • PIX4Dcloud: GCPs can be used through PIX4Dmapper.
  • PIX4Dcloud Pro: Supports AutoGCP detection directly.
    Using AutoGCP detection
Can I add images or change processing options after processing?
No, projects cannot be modified once processed. To apply changes, create a new project.
Can I edit the outputs or results generated in PIX4Dcloud?
No, once the outputs (gaussian splat ,point cloud, 3D mesh, DSM, or orthomosiac) are generated cannot be modified on PIX4Dcloud.
Processing area / region of interest
A defined processing area can be used to limit computation to specific regions.
Processing area guide
Output coordinate system
The horizontal and vertical coordinate systems can be selected before processing.
For projects using AutoGCPs, the output coordinate system matches the GCP system.
Output coordinate system settings
Changing measurement units
Measurement units depend on the output coordinate system. Units can be switched (metric, imperial, US imperial) via the toggle at the bottom of the 2D/3D viewer.
Available languages
PIX4Dcloud and PIX4Dcloud Pro are available in:
English, French, Italian, Portuguese (Brazilian), Spanish, Thai, Japanese, German, and Korean.
Change the language under User Settings > Language.
Site Localization file
PIX4Dmatic and PIX4Dcloud accept WKT site calibration files. To obtain one, contact PIX4D Technical Support.
How to obtain a Site Localization file
Data Management
Is my data protected?
PIX4D does not claim ownership of user data. Data protection and privacy are outlined in the Terms of Use.
Data processing and storage location
Each account is assigned a processing and storage server cluster, configurable in Account Settings.
Where are my datasets processed and stored?
What happens when a license expires?
Projects remain stored according to the PIX4Dcloud retention policy.
Contacts
Product feedback and feature requests
PIX4D products evolve based on user feedback. Submit requests via the PIX4D Community.
Technical support
