AutoGCPs detection functionality - PIX4Dcloud Pro
The AutoGCPs detection functionality in PIX4Dcloud Pro allows automatic detection of Ground Control Points (GCPs) and Check Points (CPs) within a dataset. This feature simplifies georeferencing and improves project accuracy by analyzing GCPs/CPs directly during processing.
Image and GCPs/CPs requirements
Upload the GCPs/CPs file
Defining the GCPs/CPs coordinate system
Viewing and editing the defined control points
Start processing
Licenses: This article is only valid for PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can process a dataset using the AutoGCPs in PIX4Dcloud.
Image and GCP requirements
Images:
Must be high quality; blurry or low-contrast images may cause detection failure.
Geolocated in WGS84 (EPSG:4326).
Geolocation accuracy: ≤5 m horizontal, ≤10 m vertical.
Captured at nadir or slightly oblique angles.
GCPs/CPs:
Supported target types: squared, diagonal, and Aeropoints.
Recommended size: ≥20× average GSD of the project.
Example: GSD = 2.5 cm → target ≥50 cm.
Black and white targets preferred; other colors may work under specific conditions.
Minimum distance between points: 15 m.
Must have a projected coordinate system.
Warnings:
At least 3 GCPs must be detected.
AutoGCPs can search within a 5×5 m range of the coordinates specified in the CSV; large inaccuracies may prevent detection.
If detection fails, GCPs/CPs will not be considered during processing.
Create a new dataset and navigate to Step 4: GCPs automation.
Click Upload file and select the CSV containing GCP/CP details.
Optional:
Replace the file: Replace file.
Delete the file: Delete.
CSV format file
| Column | Required | Description |
| 1 | Yes | Label |
| 2 | No | Type (GCP or CHECKPOINT, default: GCP) |
| 3 | Yes | X coordinate |
| 4 | Yes | Y coordinate |
| 5 | Yes | Z coordinate |
| 6 | No | XY accuracy |
| 7 | Cond. | Z accuracy (required if column 6 defined) |
001_,GCP,4392829.089,5386534.037,424.524
002_,GCP,4392772.823,5386545.0894,424.582
003_,GCP,4392732.981,5386516.197,424.723
004_,CHECKPOINT,4392761.505,5386468.789,422.646
005_,GCP,4392755.707,5386431.546,426.298
006_,GCP,4392832.252,5386456.906,427.001
Upload a PRJ file ,or
Search for a coordinate system by EPSG code or name.
- Only projected coordinate systems are supported.
- For more information see,
New dataset > Processing options > Output coordinate system - PIX4Dcloud
Warning: The GCP/CP coordinate system must match the output coordinate system. Selecting a different coordinate system will overwrite the previously defined output system.
Viewing and editing control points
Click See and edit control points to open the Control Points Table (Step 5: GCP automation).
Control Points Table Features:
Verify imported coordinates.
Change the type of a point (GCP ↔ Checkpoint).
Swap Easting and Northing if values are inverted.
Control Points Map:
Displays GCPs and CPs on a background map.
Verify that points are at expected locations. Incorrect positioning indicates coordinate or CSV issues.
Optional: switch a point between GCP and CP.
Save changes as needed.
| Images and GCPs are in the same coordinate system | Images and GCPs are not in the same coordinate system |
Warning: GCP/CP detection fails if the output and GCP coordinate systems differ.
Start processing
Click Process to upload input files and start processing.
AutoGCPs detection runs automatically.
If GCPs are not found, an email is sent notifying the user that processing will continue without them.
Upon completion, a Quality Report is emailed.
In Files > GCPs, successfully detected points are displayed with their details.
For more information, see New dataset > GCPs automatization > Processing with GCPs/checkpoints - PIX4Dcloud
