Working with Gaussian Splat Models in PIX4Dcloud
Gaussian splat models can be generated, visualized, and downloaded in PIX4Dcloud. This article provides an overview of the available workflows, from model creation to visualization and file export.
How to Generate a Gaussian Splat Model
How to Visualize a Gaussian Splat Model in the 3D Viewer
How to Download the Gaussian Splat Model
Licenses: This article is valid for PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can create and process datasets in PIX4Dcloud.
Gaussian splat models are supported in PIX4Dcloud and PIX4Dcloud Pro for projects created using one of the following methods:
- Terrestrial Dataset
- Via PIX4Dcatch:
- Capture a terrestrial dataset using the PIX4Dcatch application.
- During the processing setup, ensure the Gaussian Splatting option is enabled.
- Upload the project directly to PIX4Dcloud or PIX4Dcloud Pro.
For detailed instructions, see Creating a project via PIX4Dcatch.
- Via PIX4Dmatic:
- Export the dataset to your local desktop and create a project in PIX4Dmatic.
- Create a template with following workflow:
- Upload the dataset for processing with the option Process in PIX4Dcloud.
- Via PIX4Dcatch:
- Aerial Dataset
- Via PIX4Dcloud Pro project wizard:
- Begin setting up a new aerial dataset within the PIX4Dcloud Pro user interface.
- Select Gaussian Splat within the processing options to initiate its generation.
- (*This option is exclusive to the PIX4Dcloud Pro plan).
For more information, see Processing options in PIX4Dcloud
- Via PIX4Dmatic:
- Capture a aerial dataset.
- Create a template with following workflow: Create a project - PIX4Dmatic
Note:
The availability of Gaussian splat models depends on the license type and project source. Datasets created with PIX4Dcatch and PIX4Dmatic supports Gaussian splat generation with both PIX4Dcloud and PIX4Dcloud Pro licenses. In contrast, datasets created directly through the cloud project wizard require a PIX4Dcloud Pro license to access Gaussian splat outputs.
- When processing a terrestrial dataset via PIX4Dcatch and PIX4Dmatic, 5 extra credits are charged to the processing. For more information, Credit balance system - FAQ - PIX4Dcloud.
- The Gaussian splat models generated are georeferenced outputs.
- Fisheye camera lenses are not supported with Gaussian splats processing
Once the Gaussian splat output is generated, it becomes available under the Layer menu of the project. To view the model:
Open the project in PIX4Dcloud/or PIX4Dcloud Pro.
Activate the 3D viewer in the interface.
[optional] Enable, if it is needed it, the Gaussian splat layer to display the model.
To download the Gaussian splat model file:
Open the project in PIX4Dcloud.
Navigate to the Files & Reports section.
- Under Gaussian splat, click Download to retrieve the file.
Information: Using PIX4Dcatch to generate a Gaussian Splat model.
