Supported drones and cameras
 This article outlines the compatibility of PIX4D software with different drones, cameras, and devices. It does not provide a complete list of all supported drones.
All Pix4D software—such as PIX4Dmatic, PIX4Dcloud, PIX4Dmapper, and PIX4Dfields—is drone-agnostic, meaning it can process images from almost any drone or camera, provided the data is high quality and captured with sufficient overlap.
Supported drones
Drone Processing
PIX4D
mapper
PIX4D
matic
PIX4D
fields
PIX4D
react
PIX4D
cloud
Inspire 1/2  ✓  ✓
Mavic Air  ✓  ✓  ✓  ✓
Mavic Air 2   ✓  ✓  ✓  ✓  ✓
Air 2S  ✓  ✓  ✓  ✓
Air 3  ✓  ✓  ✓  ✓
Mavic Mini/Mini 2  ✓
Mini 3  ✓
Mini 3 Pro  ✓
Mini 4 Pro  ✓
Mavic Pro
Mavic 2 Pro
Mavic 2 Zoom
Mavic 2E Dual RGB RGB RGB RGB
Mavic 2E Adv. RGB RGB RGB RGB
Mavic 3 Pro/ Classic  ✓  ✓  ✓  ✓  ✓
Mavic 3M  ✓ RGB  ✓ RGB  RGB
Mavic 3E  ✓    ✓  ✓  ✓
Mavic 3T  ✓ RGB  ✓  ✓  ✓
Phantom 3/Adv.  ✓    ✓  ✓  ✓
Phantom 3 Pro
Phantom 4/Pro/Pro V2
Phantom 4 RTK  ✓  ✓  ✓  ✓  ✓
Phantom 4 M
Spark
Matrice 100
Matrice 200/ 200 V2
Matrice 210/210 RTK
Matrice 210 V2 /210 V2 RTK
Matrice 300 RTK
Matrice 30T RGB RGB RGB RGB RGB
Matrice 600
Matrice 4/4T   RGB RGB RGB RGB RGB
Anafi / AI
Anafi USA
Anafi Thermal RGB RGB RGB RGB
Yuneec
AgEagle eBee series
Albris
Sentera
AeroVironment Quantix
Autel Evo I
Autel Evo II 8K
Autel Evo II Pro 6K
Autel Evo II V3/Dual/Enterprise
Skydio 2 / 2+
Skydio X2/X10 RGB RGB RGB
Wingtra
Delair UX11
ACSL Soten
MAPIR
XAG M500
Freefly
Supported cameras
Camera Processing software
  PIX4Dmapper PIX4Dmatic PIX4Dfields PIX4Dreact PIX4Dcloud
Any camera ** *** **** °
Agrowing      °
Zenmuse X3
Zenmuse X4S
Zenmuse X5/X5R
Zenmuse X5S
Zenmuse X7
Zenmuse XT/XT2        °
Zenmuse H20T RGB RGB RGB RGB
Zenmuse P1
Yuneec E90
S.O.D.A. series
Albris
Aeria X
S110 RGB/NIR/RE    °
Sequoia / Sequoia+      °
Altum /PT      °
RedEdge /P/M/MX      °
SlantRange-3P      °
Sentera 6X      °
Sentera 65R  °
La Quinta DB2-Vision      °
Sony Alpha 7R IV
Sony Alpha ILX-LR1
Sony Cyber-shot DSC-RX1RM2
Sony Cyber-shot DSC-WX220
Sony UMC-R10C
Sony
Canon
Nikon
Delair
Hasselblad
Olympus
Panasonic
Pentax
Pioneer
Ricoh
Tetracam
Fujifilm GFX100S II
Fujifilm
GoPro cameras
Other brands
* PIX4Dmapper has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal) that includes the required metadata. For cameras that do not exist in PIX4Dmapper's camera database, the optimal internal camera parameters can be computed in the software while processing a good dataset. For more information:
Requests to add new camera models to the database can be sent to Technical Support.
** PIX4Dmatic has an internal camera database with precalibrated models but can process images from any camera model (RGB) as long as the images contain the necessary EXIF/XMP (metadata) tags. Requests to add new camera models to the database can be sent to Technical Support.
*** PIX4Dfields has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal) that includes the required metadata.
If your camera is not listed, you can still process images using PIX4Dfields. With the release of version 2.9 and later, PIX4Dfields can handle images from unsupported cameras by utilizing the internal image metadata.
For users of PIX4Dfields version 2.8.5 or earlier, processing is still possible for drone images not included on the list, but you will need to follow the instructions provided in: Your camera is not supported at this time - PIX4Dfields
**** PIX4Dreact has an extensive internal camera database but can process nadir images from any camera model (RGB) that includes the required metadata.
For camera models and resolutions that don't exist in the PIX4Dreact's database, it is still possible to process a dataset if a file with the internal camera parameters is provided. For more information: Your camera is not supported at this time - PIX4Dreact. Requests to add new camera models to the database can be sent to Technical Support.
° PIX4Dcloud has an internal camera database but can process images from any RGB camera that includes the required metadata. Currently, it also supports thermal and multispectral images when uploaded through PIX4Dmapper. For more information visit, What are the processing options - PIX4Dcloud.
⚠️ Important Notice: After February 28, 2026, PIX4Dcloud will no longer support the processing of multispectral or thermal images, even if uploaded via PIX4Dmapper. For more information visit Decommissioning Notice: PIX4Dmapper Legacy Processing Pipeline in Cloud Products
