Uploading Project Files from PIX4Dmapper to PIX4Dcloud for Processing - PIX4Dmapper
This article explains how to upload project files from PIX4Dmapper to be processed on PIX4Dcloud
Warning:
- Starting in February 2026, the workflow for uploading project files from PIX4Dmapper to PIX4Dcloud is enhanced with significant updates for existing Organization with PIX4Dcloud and PIX4Dmapper license. Further information on these improvements and their impact is available in the following article: Decommissioning Notice: PIX4Dmapper Legacy Processing Pipeline in Cloud Products.
- Starting October 14th, 2025, all new organizations created on or after this date with PIX4Dcloud and PIX4Dmapper licenses benefit from processing datasets using the new, improved pipeline.
Access: To upload project files from PIX4Dmapper to PIX4Dcloud, both a valid PIX4Dmapper and a valid PIX4Dcloud license are needed.
Important:
- Uploading project files from PIX4Dmapper to PIX4Dcloud for processing differs from the Share to cloud option available in PIX4Dmatic and PIX4Dfields. In PIX4Dmatic and PIX4Dfields, the Share to PIX4Dcloud option allows users to upload locally processed files to PIX4Dcloud for sharing purposes. However, this feature is not available in PIX4Dmapper. From PIx4Dmapper, the project can be uploaded for processing. In order to upload processed files, it is necesary to go to PIX4Dcloud user interfacce and import them there.
- When uploading from PIX4Dmapper to PIX4Dcloud for processing, credits or allowance will be consumed.
Tips
- You can modify your project's processing options before uploading the project to PIX4Dcloud. For more information: How to customize the options for processing on PIX4Dcloud.
- You can upload GCPs to PIX4Dcloud via project files upload. More information in: How to use GCPs for processing on the Cloud platform.
- You can add a processing area before uploading a project to PIX4Dcloud. More information in How to use a processing area in PIX4Dmapper.
- For advanced outputs and editing, process the project locally following: Getting Started Index.
To upload the project files:
1. In PIX4Dmapper, on the menu bar, click View > Processing.
2. On the processing bar at the bottom, check the three boxes for all the steps. For more information: Menu View > Processing.
3. On the menu bar, click Project > Upload Project Files...
4. In the File Upload window, check the box Start Processing.
Note: The option Start processing is not available for PIX4Dmapper version 3.0.18. To start the processing, open the uploaded project on PIX4Dcloud and, in the Images section, click Start processing.
5. Click Upload.
6. An email is sent shortly to inform the user of the project status.
Information: If the Point Cloud needs to be edited, after the processing on PIX4Dcloud is completed, download the Point Cloud and open it locally to edit it. Then replace the Point Cloud previously generated on PIX4Dcloud with the edited one. To do so, under the project processed on PIX4Dcloud, in the upper right corner, click Files & Reports > Results, and in the corresponding Point Cloud box, Replace File.
Important: Before uploading images to PIX4Dcloud, make sure that all images have unique filenames, even if they are in different folders.
Pix4D cares about your privacy and does not claim any ownership of your data. Find more information in our Terms of use.
