Your first PIX4Dcatch project from A-Z
This article provides step-by-step instructions for using PIX4Dcatch, covering everything from initial setup to capturing and processing your 3D scanned projects.
Requirements
Download and install PIX4Dcatch
Log in
PIX4Dcatch Overview
Capture a project
Processing
Professional Features
PIX4Dcatch is a mobile application designed for terrestrial 3D scanning. It uses your mobile device's integrated sensors (camera, LiDAR, IMU, and GPS) to capture high-quality spatial data, which can then be processed into accurate 3D models using photogrammetry.
Requirements
- A mobile device compatible with PIX4Dcatch. See the list of recommended devices here.
- The PIX4Dcatch application.
- A valid PIX4D license. For more information regarding which licenses enable PIX4Dcatch, please consult the PIX4Dcatch licensing page.
- An internet or data connection.
.png?width=24&height=14&name=Avatar%20(1).png)
Follow the next steps to get started:
1. Download and install PIX4Dcatch
To download the latest version of PIX4Dcatch, visit the Apple Store
For more information on downloading and installing click here.
2. Log in
It is necessary to have a valid license or obtain a trial license to log into PIX4Dcatch.
For information about the trial license, click here and for detailed instructions on logging in, click here.
3. PIX4Dcatch Overview
The PIX4Dcatch interface is designed with ease-of-use in mind.
To navigate and understand the PIX4Dcatch interface, click here.
4. Capture a project
To capture a project using the device's built-in GPS location, select Integrated GPS Sensor. Note that the accuracy of this method is typically within a few meters. For more information on how to capture a project, click here.
Recommended Capture Practices:
- Maintain a slow and steady pace.
- Tilt the device to ensure all surface details are captured.
- Avoid capturing in low-light environments.
- Avoid retracing identical paths.
For more information on best practices, consult How to capture a PIX4Dcatch project.
5. Process the images
Once the project is saved, the images can be processed in PIX4Dcloud or exported for local processing with PIX4Dmatic.
PIX4Dcloud
Use the upload button
to upload your project for fast, shareable reconstructions. For more information on how to process, click here.
Important: A PIX4Dcloud license is required. For more information on license types, click here.
PIX4Dmatic
PIX4Dmatic Standard or PIX4Dmatic Pro allows local processing of PIX4Dcatch projects.
Important: A PIX4Dmatic license is required for processing locally PIX4Dcatch projects, more information here.
How to process in PIX4Dmatic
- Tap the Export icon
and select Export All Data - PIX4Dmatic (OPF). For more information, consult Using OPF from PIX4Dcatch to PIX4Dmatic - Double-click on the project.opf
file. - PIX4Dmatic will launch automatically, displaying the project name and file path.
- Click Start.
Users with a PIX4Dcatch Professional License gain access to the following premium features:
