Supported drones and cameras
 This article outlines the compatibility of PIX4D software with different drones, cameras, and devices. It does not provide a complete list of all supported drones.
All PIX4D software—such as PIX4Dmatic, PIX4Dcloud, PIX4Dmapper, and PIX4Dfields—is drone-agnostic, meaning it can process images from almost any drone or camera, provided the data is high quality and captured with sufficient overlap.
Note: In the tables below, a blue checkmark indicates link to a footnote providing more details about the specific drone/software combination. Click on it to see the footnote immediately.
Supported drones
Drone Processing
PIX4D
mapper
PIX4D
matic
PIX4D
fields
PIX4D
react
PIX4D
cloud
Inspire 1/2  ✓ ✓ ✓ ✓  ✓
Mavic Air  ✓ ✓  ✓  ✓  ✓
Mavic Air 2   ✓  ✓  ✓  ✓  ✓
Air 2S  ✓ ✓  ✓  ✓  ✓
Air 3  ✓ ✓  ✓  ✓  ✓
Mavic Mini/Mini 2 ✓ ✓ ✓ ✓  ✓
Mini 3 ✓ ✓ ✓ ✓  ✓
Mini 3 Pro ✓ ✓ ✓ ✓  ✓
Mini 4 Pro ✓ ✓ ✓ ✓  ✓
Mavic Pro ✓ ✓ ✓ ✓ ✓
Mavic 2 Pro ✓ ✓ ✓ ✓ ✓
Mavic 2 Zoom ✓ ✓ ✓ ✓ ✓
Mavic 2E Dual ✓ RGB RGB RGB RGB
Mavic 2E Adv. ✓ RGB RGB RGB RGB
Mavic 3 Pro/ Classic  ✓  ✓  ✓  ✓  ✓
Mavic 3M  ✓ RGB  ✓ RGB  RGB
Mavic 3E  ✓  ✓  ✓  ✓  ✓
Mavic 3T  ✓ RGB  ✓  ✓  ✓
Phantom 3/Adv.  ✓  ✓  ✓  ✓  ✓
Phantom 3 Pro
Phantom 4/Pro/Pro V2
Phantom 4 RTK  ✓  ✓  ✓  ✓  ✓
Phantom 4 M ✓   ✓
Spark ✓ ✓ ✓ ✓ ✓
Matrice 100 ✓ ✓ ✓ ✓ ✓
Matrice 200/ 200 V2 ✓ ✓ ✓ ✓ ✓
Matrice 210/210 RTK ✓ ✓ ✓ ✓ ✓
Matrice 210 V2 /210 V2 RTK ✓ ✓ ✓ ✓ ✓
Matrice 300 RTK ✓ ✓ ✓ ✓ ✓
Matrice 30T RGB RGB RGB RGB RGB
Matrice 600 ✓ ✓ ✓ ✓ ✓
Matrice 4/4T   RGB RGB RGB RGB RGB
Anafi / AI ✓ ✓ ✓ ✓ ✓
Anafi USA ✓ ✓ ✓ ✓ ✓
Anafi Thermal ✓ RGB RGB RGB RGB
Yuneec ✓ ✓ ✓ ✓ ✓
AgEagle eBee series ✓ ✓ ✓ ✓ ✓
Albris ✓ ✓ ✓ ✓ ✓
Sentera ✓   ✓
AeroVironment Quantix ✓ ✓ ✓ ✓ ✓
Autel Evo I ✓ ✓ ✓ ✓ ✓
Autel Evo II 8K ✓ ✓ ✓ ✓ ✓
Autel Evo II Pro 6K ✓ ✓ ✓ ✓ ✓
Autel Evo II V3/Dual/Enterprise ✓ ✓ ✓ ✓ ✓
Skydio 2 / 2+ ✓ ✓ ✓ ✓ ✓
Skydio X2/X10 ✓ ✓ RGB RGB RGB
Wingtra ✓ ✓ ✓ ✓ ✓
Delair UX11 ✓ ✓ ✓ ✓ ✓
ACSL Soten ✓ ✓ ✓ ✓ ✓
MAPIR ✓ ✓ ✓ ✓ ✓
XAG M500 ✓ ✓ ✓ ✓ ✓
Freefly ✓ ✓ ✓ ✓ ✓
Supported cameras
Camera Processing software
  PIX4Dmapper PIX4Dmatic PIX4Dfields PIX4Dreact PIX4Dcloud
Any camera ✓ ** *** **** °
Agrowing ✓   ✓    °
Zenmuse X3 ✓ ✓ ✓ ✓ ✓
Zenmuse X4S ✓ ✓ ✓ ✓ ✓
Zenmuse X5/X5R ✓ ✓ ✓ ✓ ✓
Zenmuse X5S ✓ ✓ ✓ ✓ ✓
Zenmuse X7 ✓ ✓ ✓ ✓ ✓
Zenmuse XT/XT2 ✓        °
Zenmuse H20T ✓ RGB RGB RGB RGB
Zenmuse P1 ✓ ✓ ✓ ✓ ✓
Yuneec E90 ✓ ✓ ✓ ✓ ✓
S.O.D.A. series ✓ ✓ ✓ ✓ ✓
Albris ✓ ✓ ✓ ✓ ✓
Aeria X ✓ ✓ ✓ ✓ ✓
S110 RGB/NIR/RE ✓ ✓ ✓    °
Sequoia / Sequoia+ ✓   ✓    °
Altum /PT ✓   ✓    °
RedEdge /P/M/MX ✓   ✓    °
SlantRange-3P ✓   ✓    °
Sentera 6X ✓   ✓    °
Sentera 65R ✓ ✓ ✓ ✓  °
La Quinta DB2-Vision ✓   ✓    °
Sony Alpha 7R IV ✓ ✓ ✓ ✓ ✓
Sony Alpha ILX-LR1 ✓ ✓ ✓ ✓ ✓
Sony Cyber-shot DSC-RX1RM2 ✓ ✓ ✓ ✓ ✓
Sony Cyber-shot DSC-WX220 ✓ ✓ ✓ ✓ ✓
Sony UMC-R10C ✓ ✓ ✓ ✓ ✓
Sony ✓ ✓ ✓ ✓ ✓
Canon ✓ ✓ ✓ ✓ ✓
Nikon ✓ ✓ ✓ ✓ ✓
Delair ✓ ✓ ✓ ✓ ✓
Hasselblad ✓ ✓ ✓ ✓ ✓
Olympus ✓ ✓ ✓ ✓ ✓
Panasonic ✓ ✓ ✓ ✓ ✓
Pentax ✓ ✓ ✓ ✓ ✓
Pioneer ✓ ✓ ✓ ✓ ✓
Ricoh ✓ ✓ ✓ ✓ ✓
Tetracam ✓ ✓ ✓ ✓ ✓
Fujifilm GFX100S II ✓ ✓
Fujifilm ✓ ✓ ✓ ✓ ✓
GoPro cameras ✓   ✓ ✓ ✓
Other brands ✓ ✓ ✓ ✓ ✓
* PIX4Dmapper has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal) that includes the required metadata. For cameras that do not exist in PIX4Dmapper's camera database, the optimal internal camera parameters can be computed in the software while processing a good dataset. For more information:
Requests to add new camera models to the database can be sent to Technical Support.
** PIX4Dmatic has an internal camera database with precalibrated models but can process images from any camera model (RGB) as long as the images contain the necessary EXIF/XMP (metadata) tags. Requests to add new camera models to the database can be sent to Technical Support.
*** PIX4Dfields has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal) that includes the required metadata.
If your camera is not listed, you can still process images using PIX4Dfields. With the release of version 2.9 and later, PIX4Dfields can handle images from unsupported cameras by utilizing the internal image metadata.
For users of PIX4Dfields version 2.8.5 or earlier, processing is still possible for drone images not included on the list, but you will need to follow the instructions provided in: Your camera is not supported at this time - PIX4Dfields
**** PIX4Dreact has an extensive internal camera database but can process nadir images from any camera model (RGB) that includes the required metadata.
For camera models and resolutions that don't exist in the PIX4Dreact's database, it is still possible to process a dataset if a file with the internal camera parameters is provided. For more information: Your camera is not supported at this time - PIX4Dreact. Requests to add new camera models to the database can be sent to Technical Support.
° PIX4Dcloud has an internal camera database but can process images from any RGB camera that includes the required metadata. Currently, it also supports thermal and multispectral images when uploaded through PIX4Dmapper. For more information visit, What are the processing options - PIX4Dcloud.
⚠️ Important Notice: After February 28, 2026, PIX4Dcloud will no longer support the processing of multispectral or thermal images, even if uploaded via PIX4Dmapper. For more information visit Decommissioning Notice: PIX4Dmapper Legacy Processing Pipeline in Cloud Products
