Supported drones, cameras, and controllers - PIX4Dcapture Pro
PIX4Dcapture Pro is compatible with iOS and Android tablets, mobile devices, and different DJI and Parrot controllers with built-in screens. The PIX4Dcapture Pro app requires iOS 13 / Android 7 or later. We recommend using the latest operating system.
PIX4Dcapture Pro has been tested with the following devices:
- iOS: iPad Mini 5th gen, iPad Pro 2nd gen, iPad 7th gen, iPad Air 2, iPhone 13 Pro Max.
- Android:
- Tablet: Samsung Galaxy Tab A7, Samsung Galaxy Tab S7, Samsung Tab Es 15, Xiaomi Redmi Note 9, Lenovo Tab M10 Fhd Plus.
- DJI Smart Controller Enterprise, DJI RC Pro Enterprise.
PIX4Dcapture Pro is compatible with the following drones, cameras, and controllers:
Warning: Since April 11, 2025, the DJI Mini 3 drone is not supported by PIX4Dcapture Pro anymore. If you are using this drone, please use another flight-planning app. You can find a list of apps in this article.
*1 - Network RTK corrections available.
*2 - Cell tower and transmission tower assets not available.
*3 - Compatible lens model for DJI Zenmuse X5S is DJI MFT 15mm/1.7 ASPH.
*4 - Compatible lens model is DJI DL 35mm F2.8 LS ASPH.
*5 - PIX4Dcapture Pro can be installed on an external iOS or Android mobile device (phone or tablet) mounted over the Smart Controller Enterprise (screen mounting bracket and appropriate USB cable required) or on the DJI Smart Controller Enterprise built-in screen (More info here: How to install the App on Remote Controllers with screens? (APK) - PIX4Dcapture Pro).
*6 - The DJI Mini 3 Pro only supports Grid Mission (Generic) inside the PIX4Dcapture Pro app. These drones don't support the Terrain Awareness feature either.
*7 - Compatible with Skycontroller USA above or equal to revision AD only.
Disclaimer: Pix4D publishes this information as a courtesy to its customers. Because this information may not be accurate, Pix4D makes no warranty of any kind, expressed or implied, with respect to its validity.
Note: Drones that are compatible only using the provided APK (DJI Mavic 3E, DJI Mavic 3T, DJI Mavic 3M, DJI Mini 3 Pro) cannot be selected from the app downloaded from the Apple App Store or Google Play Store, the drone won't appear in the list.
Please install the APK following the links in the table above or by visiting this page: How to install the app on Remote Controllers with Screens? (APK) - PIX4Dcapture Pro. The drone will then appear in PIX4Dcapture Pro when opened from the APK.
