Supported drones and cameras - PIX4Dreact
This article contains all the drones and cameras supported by PIX4Dreact.
PIX4Dreact adds new supported drones and cameras with every release.
The following table contains all the drones and cameras supported by PIX4Dreact:
  • The table is structured by Brand, Drone/Camera, and Syntax.
  • Syntax is composed of Camera model + Focal Length + Image Resolution.
Register for a trial version to test your images.
Important: If your camera is not listed, you can still process images using PIX4Dreact. With the release of version 1.6 and later, PIX4Dreact can handle images from unsupported cameras by utilizing the internal image metadata.
For users of PIX4Dreact version 1.5.1 or earlier, processing is still possible for drone images not included on the list, but you will need to follow the instructions provided in: Your camera is not supported at this time - PIX4Dreact
Brand Drone/Camera Syntax
Parrot AnafiAi ANAFIAi_5.3_4000x3000
ANAFIAi_5.3_8000x6000
Anafi/AnafiUSA Anafi_4.0_4608x3456
Anafi_4.0_5344x4016
senseFly  albris albris_8.0_4488x3368
albris_8.0_7152x5368
albris_8.0_7728x5368
S.O.D.A. S.O.D.A._10.2_5472x3648
S.O.D.A._10.2_5472x3648_fw_1.1.0
S.O.D.A._10.6_5472x3648
DJI
Spark FC1102_4.5_3968x2976
Mini FC7203_4.5_4000x2250
Mini 2 FC7303_4.5_4000x2250
FC7303_4.5_4000x3000
Mini 3 FC3682_6.7_4000x3000
FC3682_6.7_4000x2250
Mini 3 Pro FC3582_6.7_4032x3024
Mini 4 Pro FC8482_6.7_4032x2268
Mavic Air FC2103_4.5_4056x3040
Mavic Air 2 FC3170_4.5_4000x3000
Mavic Air 2S FC3411_8.4_5472x3648
Air 3 FC8282_6.7_4032x2268
FC8282_6.7_8064x6048
Mavic Pro FC220_4.7_2000x1500
FC220_4.7_4000x2250
FC220_4.7_4000x3000
Mavic Enterprise Dual FC2403_4.5_4056x3040
FC2403_4.5_4056x2280
Mavic 2 Pro L1D-20c_10.3_5472x3648
Mavic 2 Enterprise FC2220_4.4_4000x3000
Mavic 2 Enterprise Advanced MAVIC2-ENTERPRISE-ADVANCED_4.5_8000x6000 (RGB)
MAVIC2-ENTERPRISE-ADVANCED_0.0_640x512 (Thermal)*
Mavic 3
Mavic 3 Classic
Mavic 3 Pro
L2D-20c_12.3_5280x3956
Mavic 3 Enterprise M3E_12.3_5280x3956
Mavic 3 Thermal M3T_4.4_4000x3000 (12 MP RGB)
M3T_4.4_8000x6000 (48 MP RGB)
M3T_9.1_640x512 (Thermal)*
Mavic 3 Multispectral M3M_12.3_5280x3956
Matrice 30 (M30) M30_4.4_4000x3000 (RGB - Wide)
Matrice 30T (M30T) M30T_4.4_4000x3000 (RGB - Wide)
Matrice 4 Thermal  (M4T) M4T_6.7_4032x3024
Matrice 4 Enterprise (M4E) M4E_12.3_5280x3956
Phantom 3 FC300C_3.6_2000x1500
FC300C_3.6_4000x3000
Phantom 3 Adv FC300S_3.6_4000x2250
FC300S_3.6_4000x3000
Phantom 3 Pro FC300X_3.6_4000x2250
FC300X_3.6_4000x3000
Phantom 4 FC330_3.6_2000x1500
FC330_3.6_4000x2250
FC330_3.6_4000x3000
Phantom 4 Pro V2 FC6310S_8.8_5472x3648
FC6310S_8.8_4864x3648
Phantom 4 Pro FC6310_8.8_4864x3648
FC6310_8.8_5472x3648
Phantom 4 RTK FC6310R_8.8_4864x3648
FC6310R_8.8_5472x3648
Zenmuse P1 ZenmuseP1_35.0_8192x5460
Zenmuse H20T ZH20T_4.5_4056x3040 (RGB)
ZH20T_13.5_640x512 (Thermal)*
Zenmuse X3 FC350_3.6_4000x2250
FC350_3.6_4000x3000
Zenmuse X5 FC550_15.0_4608x3456
FC550_DJIMFT15mmF1.7ASPH_15.0_4608x3456
FC550_OLYMPUSM.12mmF2.0_12.0_4608x3456
Zenmuse X5RAW FC550RAW_DJIMFT15mmF1.7ASPH_15.0_4608x3456
Zenmuse X4S FC6510_8.8_4864x3648
FC6510_8.8_5472x3078
FC6510_8.8_5472x3648
Zenmuse X5S FC6520_DJIMFT15mmF1.7ASPH_15.0_5280x3956
Zenmuse X7 FC6540_DJIDL24mmF2.8LSASPH_24.0_6016x4008
FC6540_DJIDL35mmF2.8LSASPH_35.0_6016x3376
Zenmuze L1  EP800_8.8_5472x3648 (RGB)
Wingtra
A6100 ILCE-6100_E20mmF2.8_20.0_6000x4000
Sony RGB61 RGB61_FE24mmF2.8G_24.0_9504x6336
Sentera
65R 21030-01_65MP-GS-0001_27.4_9344x7000
6X Thermal Pro
(RGB and Thermal)
21216-03_3.2MP-GS-0001_8.0_2048x1536
AeroVironment  Quantix Quantix_2.6_2432x1824
Quantix_5.2_4864x3648
Quantix_5.4_4864x3648
Quantix_5.4_2432x1824
AutelEvo  Autel Evo I XB015_3.2_4000x3000
Autel Evo II 8K XT701_4.7_7680x4320
Autel Evo II Pro 6K  XT705_10.6_5472x3648
XL705_10.3_5472x3648
Autel Evo II V3 XL705_10.2_5472x3648
Autel Evo II Dual XT706_4.7_4000x3000
Autel Evo Enterprise XT709_4.7_7680x4320
XT709_13.0_640x512
Sony
Sony Alpha 7R IV ILCE-7RM4_FE24mmF2.8G_24.0_9504x6336
Sony Alpha 7R V ILCE-7RM5_FE35mmF2.8ZA_35.0_9504x6336
ILCE-7RM5_FE24mmF2.8G_24.0_9504x6336
Sony ILX-LR1 ILX-R1_24mmF3.5D|Contemporary021_24.0_9504x633
ILX-LR1_17mmF4D|Contemporary023_17.0_9504x633
LX-LR1_SAMYANGAF75mmF1.8_75.0_9504x6336
ILX-LR1_FE50mmF1.8_50.0_9504x6336
ILX-LR1_FE35mmF2.8ZA_35.0_9504x6336
Yuneec  E90 E90_8.3_5472x3648
MAPIR  Survey 3W Survey 3W RGB
XAG  XAG M500 XAG M500 RGB
Freefly Sony Alpha ILX-L
Sentera 65R
Skydio  Skydio2/2+ 2_3.7_4056x3040
Skydio X2  X2_3.7_4056x3040 (RGB)
X2Wide_3.7_4056x304 (RGB)
X2Narrow_3.7_4056x3040(RGB)
Skydio X10/X10D  VT300-Z_50_9.8_9248x6944
VT300-Z_50_9.8_4624x3472
VT300-L_50_9.8_4624x3472
VT300-L_93_7.7_8192x6144
VT300-L_93_7.7_4096x3072
ACSL Soten CX-GB100_10.2_5448x3632
Other cameras   Remaining supported cameras
*: PIX4Dreact can process .jpg thermal imagery, but they will be treated as RGB images, and the resulting orthomosaic is colored-mapped of temperatures and contains only a visual representation of the temperature. This allows the detection of areas with high and low temperatures relative to the scene. It will not be possible to extract the temperature value of a particular object or pixel from the resulting map.
