English
Your camera is not supported at this time - PIX4Dfields
This article explains what to do when a camera or resolution is not supported in PIX4Dfields.
In PIX4Dfields 2.9 and newer, this can occur for cameras that don't have the required tags to be processed.
For previous versions, PIX4Dfields will display the message "Your camera is not supported at this time" when a camera is not in the database. It happens with recently released cameras, less popular cameras, or images with a resolution that is not supported. In this case, a custom camera parameters file (.xml) will be required to process the unsupported imagery. This .xml file acts as an amendment to the camera database and will allow PIX4Dfields to begin processing.
This is an example of what PIX4Dfields displays when a camera is not supported:
  • FC7303= Camera model
  • 4000x2250=Image resolution
  • 4.5= Focal length
Important: It is still possible to process imagery from cameras not in the database.
What to do if your camera is not supported
Pix4D updates the database with every new release of PIX4fields to ensure the latest camera models are supported. In cases of currently unsupported cameras, a custom camera parameter file is available for download. Please click on the download link and follow the steps below to import the file into PIX4Dfields.
 🚦Click here to download a Camera Parameter File for PIX4Dfields
To use the file, perform the following steps:
  1. On the dashboard, go to settings.jpg SETTINGS on the top-right and click Camera parameters file.Notsupported
  2. Click Select file and select the .xml file in the file dialog.
  3. Exit the settings and create a project to process the dataset. The camera parameters file is used automatically.
The file can be unlinked by clicking Remove on the Camera parameters file page of the settings. The parameters will then no longer be used. If a camera parameter file is provided for a specific camera, its values override any corresponding values in the image Exif data or the internal database.
If the downloaded file still does not enable the processing, or the orthomosaic is not of good quality, and you have a valid Support and Upgrades license, please contact Pix4D support, sending your complete dataset, so we can send an updated .xml file that will work for your images.
Important: It is recommended that imagery be acquired at a resolution that matches the one supported by PIX4Dfields. Changing the image aspect ratio will change the image resolution, which may prevent PIX4Dfields from supporting the imagery and require a custom camera parameter file.
Which cameras are supported in PIX4Dfields
Check our supported cameras and resolutions here: Supported cameras - PIX4Dfields.
Error in camera parameters file
  1. Ensure the provided XML has the correct format:Correct_XML_
  2. Ensure there are no empty tags:Wrong_XML_
  3. Ensure there are no incomplete tags like <rigs/> at the beginning or <mappings/> at the end.
The XML file is not imported
If after selecting the file, it is not importing correctly to PIX4Dfields, please update to PIX4Dfields 2.9.6 https://account.pix4d.com/download-software
