English
Technical release notes - PIX4Dcloud / PIX4Dcloud Advanced
September 17th, 2025 - Improved Processing Success Rate with Complex or Large Datasets
Improvements:
  • Improved processing success rate when processing relatively complex or large datasets.
Bug fixes:
  • Fixed the issue where the 2D editor was sometimes unresponsive when opening a site with DXF design overlays.
  • Fixed the issue where the Gaussian splats sometimes flickered in the 3D editor when specular reflections was enabled.
  • Fixed the issue where the region of interest was ignored when generating Gaussian splats.
  • Fixed the issue where 3D editor navigation was sometimes unstable when rendering Gaussian splats.
  • Fixed the issue where the 2D editor displayed JPEG-compressed orthomosaic GeoTIFFs as opaque when they were uploaded with the dataset creation wizard.
  • Fixed the issue where processing failed when a tie point was marked in one image.
August 19th, 2025 - PIX4Dcloud Drive's Search Gets a Major Upgrade
Improvements:
  • PIX4Dcloud drive’s search also searches in PIX4Dcloud datasets' notes.
Changes:
  • PIX4Dcloud dataset creation wizard no longer allows uploading multispectral TIFF or SIG images for processing.
  • PIX4Dcloud’s 3D editor and PIX4Dcatch’s PIX4Dcloud AR render Gaussian splats without spherical harmonics or specular reflections by default. They can be enabled in the Gaussian splat layer’s display settings.
Bug fixes:
  • Fixed the issue where the region of interest and requested outputs were ignored when requesting an SLPK point cloud or 3D textured mesh with a compound output coordinate reference system.
  • Fixed the issue where one or more layers would disappear from the 2D editor in some web browsers when more than 16 design overlays were enabled at the same time.
  • Fixed the issue where the 3D editor rendered Gaussian splats with the wrong color in web browsers on Android mobile devices.
  • Fixed the issue where the 3D editor in web browsers on mobile devices and PIX4Dcatch’s PIX4Dcloud AR did not render the point cloud or 3D textured mesh.
  • Fixed the issue where annotations sometimes do not snap to the center or a point in the point cloud.
  • Fixed the issue where Gaussian splats appeared to flicker in the 3D editor or PIX4Dcatch’s PIX4Dcloud AR when they were rendered out of order.
  • Fixed the issue where Gaussian splats appeared to flicker or reload continuously in web browsers on mobile devices and PIX4Dcatch’s PIX4Dcloud AR when the point cloud was enabled.
  • Fixed the issue where the point cloud appeared to flicker or reload continuously in web browsers on mobile devices and PIX4Dcatch’s PIX4Dcloud AR when the Gaussian splats were enabled.
  • Fixed the issue where navigation was sometimes unstable or the camera sometimes moved unexpectedly at short distances from the Gaussian splats.
  • Fixed the issue where the 2D editor sometimes did not render the orthomosaic.
July 24th, 2025 - Enhanced 3D Editor: SLPK Export, Better Design Overlay Visualization, and Annotation Snapping
What's new:
Improvements:
  • Request either an LAS or LAZ point cloud with the dataset creation wizard.
  • Gaussian splats load faster in 3D editor.
Bug fixes:
  • Fixed the issue where a duplicate PIX4Dcloud dataset was created when the organization had zero credits.
  • Fixed the issue where annotations were created in the 3D editor when the Gaussian splat layer was enabled and the cursor did not intersect with any layer.
  • Fixed the issue where an OBJ 3D textured mesh sometimes could not be downloaded when the PIX4Dcloud dataset was created with PIX4Dmatic’s Share to PIX4Dcloud
  • Fixed the issue where web browsers on iOS mobile devices sometimes automatically refreshed the web page when the 3D editor loaded Gaussian splats.
July 18th, 2025 - Download and Overlay upload issue fixed in PIX4Dcloud
Bug fixes:
  • Fixed the issue where some outputs could not be downloaded without a valid PIX4Dcloud license.
  • Fixed the issue where a PDF, JPEG, JPG, or PNG file design overlay sometimes failed to upload.
July 4th, 2025 - The coordinate reference system picker supports TXT files
Improvements:
Bug fixes:
  • Fixed the issue where the web UI’s 3D editor sometimes snapped annotations to the following layers when they were disabled or hidden: IFC, Gaussian Splat, and Point cloud.
  • Fixed the issue where the opaque orthomosaic ZIP was sometimes not available for download.
  • Fixed the issue where the region of interest was not used when processing datasets with a left-handed coordinate reference system.
  • Fixed the issue where the design overlay wizard sometimes took more time than expected to upload PDF, JPEG, JPG, and PNG files.
Information: Before starting your project, carefully review our guide on the best practices and capabilities of PIX4Dcloud.
June 20th, 2025 - Live Camera Feed Now Visible in PIX4Dcatch’s AR View
Bug fixes:
  • Fixed the issue where the live camera feed was hidden by an opaque background in PIX4Dcatch’s PIX4Dcloud AR.
June 13th, 2025 - Improvements to the annotation report
Improvements:
  • The annotations report now includes 3D length for relevant annotations.
Bug fixes:
  • Fixed the issue where processing sometimes failed when AutoGCP detected only one or two GCPs in images
May 30th, 2025 - Improvements to the images attached to annotations
Improvements:
  • Add, replace, and delete images that are attached to annotations with the web UI.
  • All accounts have access to Organization management.
  • Autotag markers are perpendicular to the target when displayed in the 3D editor.
Bug fixes:
  • Fixed the issue where the creation of an opaque copy of the orthomosaic sometimes failed.
  • Fixed the issue where someone could sometimes continue to access some information and resources after they were removed from an Organization.
May 16th, 2025 - Improvements to the names of files downloaded from a dataset
Improvements:
  • When downloading inputs, outputs, and reconstructions with PIX4Dcloud's web UI, the default file name includes the current name of the PIX4Dcloud dataset and site.
Bug fixes:
  • Fixed the issue where an account failed to join an organization when it was a member of an organization.
  • Fixed the issue where the elevation computed for an annotation created with the 2D editor sometimes was less accurate than expected.
  • Fixed the issue where the horizontal position of an annotation created with the 2D editor sometimes moved when it was created or edited for datasets with a compound or vertical coordinate reference system.
  • Fixed the issue where the dataset creation wizard sometimes crashed or froze when uploading a larger number of images.
  • Fixed the issue where the “Buy now” button was sometimes unexpectedly displayed or missing.
  • Fixed the issue where the Gaussian splat layer sometimes remained visible in the 3D editor after it was disabled.
  • Fixed the issue where the design overlay wizard sometimes froze when uploading an image or PDF design overlay.
  • Fixed the issue where calibration processing time was sometimes longer than expected for the Oblique processing options and larger datasets, and processing sometimes failed.
  • Fixed the issue where a 3D textured mesh was sometimes not generated.
  • Fixed the issue where the 3D editor sometimes failed to focus on the 3D textured mesh.
  • Fixed the issue where the 3D editor sometimes failed to center the view on the project area.
May 9th, 2025 - Improvements in Gaussian splatting
Improvements:
April 30th, 2025 - Improvements and bug fixes
What is new:
  • Support for geoid model JPGEO2024 from Japan, EPSG:6695 "JGD2011 (vertical) height".
Improvements:
Bug fixes:
  • Fixed issue where the dataset creation wizard included unnecessary steps and did not close when uploading Parrot Sequoia multispectral images.
  • Fixed issue where the dataset creation wizard could not progress after .tiff images were added to a dataset.
  • Fixed issue where compare mode sometimes did not display 2D layers.
  • Fixed issue where the dataset creation wizard could get stuck after selecting a step when uploading processed outputs to an empty dataset.
  • Fixed issue where some elements were not translated or translated incorrectly.
  • Fixed issue where custom base surface elevation for volume measurement disappeared when it was set to zero.
  • Fixed issue where it was not possible to import control points when the dataset coordinate reference system’s geoid height was set to zero.
  • Fixed the issue where the annotations report sometimes included the same detailed image for multiple annotations.
April 1st, 2025 - Attach images to an annotation in PIX4Dcatch
What is new:
Changes:
Improvements:
  • The projects uploaded from PIX4Dcatch using the Gaussian Splatting technique for processing have the following improvements:
    • Processing time has been reduced.
    • Quality of the outputs has been improved.
    • Splats are now available for annotating and measuring.
    • Focus on or zoom to Gaussian Splat layer in 3D editor.
  • The web UI’s 3D editor remains responsive while loading any type of layer.
Bug fixes:
  • Fixed the issue where the camera in the 3D editor moved to a different position when the Gaussian Splat layer was enabled.
  • Fixed the issue where the 3D editor failed to display the Gaussian Splat layer when the dataset’s name included spaces.
  • Fixed the issue where the 3D editor sometimes displayed the Gaussian Splat layer with unexpected colors.
February 10th, 2025 - Gaussian Splatting technique for projects uploaded from PIX4Dcatch
What is new:
Bug fixes:
  • Fixed the issue where sometimes the edges of the orthomosaics had significant artifacts.
  • Fixed the issue where the NDVI layer could not be deleted.
  • Fixed the issue where orthomosaics in WGS84 were not displayed
Improvements:
  • The format of an orthophoto and DSM processed from the PIX4Dcloud user interface is now Cloud Optimized Geotiff.
January 13th, 2025 - Region of interest for processing
What is new:
Bug fixes:
  • Fixed the problem of an orthomosaic not being displayed when the coordinate system is WGS84.
  • Fixed the issue with the NDVI layer that could not be deleted.
December 16th, 2024 - Support for new geoids, Austrian and New Zealand
What is new:
  • New Geoid models supported:
    • Austria: “Austrian Geoid 2008 | GHA” for EPSG:5778
    • New Zealand:
      • EPSG:5759, “NZVD2016 | Auckland 1946”
      • EPSG:5760, “NZVD2016 | Bluff 1955”
      • EPSG:4458, “NZVD2016 | Dunedin-Bluff 1960”
      • EPSG:5761, “NZVD2016 | Dunedin 1958”
      • EPSG:5762, “NZVD2016 | Gisborne 1926”
      • EPSG:5763, “NZVD2016 | Lyttelton 1937”
      • EPSG:5764, “NZVD2016 | Moturiki 1953”
      • EPSG:5765, “NZVD2016 | Napier 1962”
      • EPSG:5766, “NZVD2016 | Nelson 1955”
      • EPSG:5767, “NZVD2016 | One Tree Point 1964”
      • EPSG:5772, “NZVD2016 | Stewart Island 1977”
      • EPSG:5769, “NZVD2016 | Taranaki 1970”
      • EPSG:5770, “NZVD2016 | Wellington 1953”
Changes:
  • Camera support:
    • Changed DJI ZH20T, DJI ZH20T, DJI FC6310R, DJI FC6540, and DJI Mavic 2 Enterprise Advanced default vertical coordinate reference system to ellipsoidal height
Improvements:
  • Improved readability and wording in dataset creation wizard
Bug fixes:
  • Compare mode:
    • Fixed the issue where the compare mode always displayed the second dataset on both sides.
    • Fixed the issue where the compare mode did not display the expected outputs.
  • Fixed the issue where the web UI 2D editor sometimes failed to display the corresponding level of detail of the DSM and orthomosaic when zoomed in.
  • Fixed the issue where the web UI sometimes took too long to display annotations
  • Fixed the issue where the 3D textured mesh generated by PIX4Dcloud could not be opened in some third-party applications.
  • Fixed the issue where the web UI sometimes failed to save annotations.
  • Fixed the issue where the inspection matches were loading unnecessarily in the background.
  • Fixed the issue where the annotation export incorrectly formatted the contents of the CSV.
  • Fixed the issue where the site localization coordinate reference system sometimes was not used for PIX4Dcatch datasets.
  • Fixed the issue where the PDF quality report sometimes did not include the dataset’s processing options.
  • Fixed the issue where processing sometimes failed when AutoGCP did not find enough targets in enough images.
  • Fixed the issue where the web UI 2D editor sometimes displayed the DSM with the wong color and an empty histogram.
  • Fixed the issue where the web UI 2D editor sometimes did not display the entire DSM or orthomosaic.
  • Fixed the issue where the DSM and orthomosaic borders did not align with each other in the web UI 2D editor
October 11th, 2024 - Improvements
Improvements
  • Projects uploaded from PIX4Dmatic can use the embedded view.
Changes
  • The filling color is the same as the border color in polygon and volume annotations.
  • Open action for folders from the three dots has been removed.
Bug fixes
  • Fixed the issue where the naming and order of the overlays were not kept.
  •  Fixed the issue of showing the letters “COG” in the layers hierarchy when an orthomosaic or a DSM was uploaded from PIX4Dmatic.
  • Fixed the issue where the output file format shown in the download section was not correct.
September 18th, 2024 - Improvements
Improvements
  • The project wizard notifies about missing images before processing the dataset.
  • Switcher to go from map to satellite and vice versa and zoom controls in the map where images are displayed.
  • The Autotag layer can be moved up and down in the hierarchy.
  • ESRI CRS are supported in PIX4Dcloud as an output coordinate system and can be selected
  • Quality Report now includes the initial coordinates of the GCPs and the computed ones of the MTPs
  • The processing wizard informs that DSM is needed to use the virtual inspector, and there is a warning in the cases where there is no DSM
Changes
  • The Autotag label that used to be displayed on the right corner of the viewer is not displayed any more.
  • The extensions prj / tfw are now included in the orthomosaic and DSM download from the Web user interface.
Bug fixes
  • Fixed the issue of having a duplicated 3D mesh layer.
  • The Black circle around orthomosaic and DSM is no longer there when uploading to the cloud via the Share to Cloud feature using the latest PIX4Dmatic release.
  •  Fixed the issue of not being able to download the opaque orthomosaic.
  • Fixed the issue of the email not being sent when the AutoGCP feature fails.
  • Fixed the issue where the background color could not be changed on the 3D view.
August 28th, 2024 - Visualization of Autotags in PIX4DCloud
What's new
  • The Autotags used in the computation of projects uploaded from PIX4Dcatch are now displayed in the PIX4Dcloud user interface (both in 2D and 3D).
Improvements
  • The resolution of the 3D textured mesh’s texture has been increased from 8192x8192 to 16384x16384.
  • Mission Planner supports mission planning in imperial units.
Bug fixes
  • Fixed the issue with the virtual inspector not working when the 3DMesh was not selected as output.
August 15th, 2024 - Images and GCPs are displayed on a map before processing
What's new
Improvements
  • Added support for the following camera models and changed camera model shutter type from global to rolling:
    • DJI Air 2S 19.9-megapixel RGB image with 8.4 mm focal length.
    • DJI MIni 2 9-megapixel RGB image with 4.5 mm focal length.
    • DJI Mavic Pro 12-megapixel RGB image with 4.7 mm focal length.
Changes
  • The orthomosaic and DSM are exported in Cloud Optimized GeoTIFF format when the dataset was created with PIX4Dcloud’s user interface.
  • The background map provider is now MapTiler.
  • Images without geolocation must be deleted before processing.
Bug fixes
  • Fixed the issue of sometimes not being able to replace the CSV file containing GCPs in the AutoGCP feature.
  • Fixed the issue of some point clouds processed with PIX4Dmapper were not displayed.
  • Fixed the issue of an inspection annotation marker placed at the wrong position in the annotations report image for portrait images.
July 17th, 2024 - New processing wizard
What's new
  • New processing wizard including:
    • New processing pipeline for oblique flights.
    • New processing pipeline for flights over flat areas (e.g. crop fields, airports…).
    • Output selection.
Improvements
  • Web user interface no longer displays 2D outputs, including orthomosaic, DSM, and NDVI with interpolated pixels.
  • All images with no geolocation can be deleted at once.
  • Mission Planner maintains the current map zoom level when creating a new mission.
  • Streamlined rendering of Map view dashboard with a large number of projects.
Changes
  • Download to Mapper desktop is no longer available for datasets created with the PIX4Dcloud’s user interface.
  • Color of some elements has been changed in Mission Planner to improve usability and be consistent with PIX4Dcapture Pro.
Bugs
  • For datasets uploaded from PIX4Dcatch:
    • Fixed issue when 3D textured mesh generation could sometimes take a very long time to process.
  • Fixed the issue when 2D annotations were sometimes not displayed.
  • Fixed the issue of zoom changing constantly in the Map View when many projects were displayed.
  • Fixed the issue of DXF files not being displayed when the bounding box is very big.
  • Fixed the issue where reconstructions were at the wrong absolute elevation when the dataset did not include GCPs because the centimeter-grade RTK geotags' elevations were considered to be relative to geoid model EGM96 instead of the ellipsoid with the following cameras:
    • DJI Mavic 2 Enterprise Advanced's 48-megapixel RGB image with 4.5 mm focal length.
    • DJI Mavic 3 Multispectral 20.8-megapixel RGB image with 12.3 mm focal length.
June 26th, 2024 - Map view
What's new
Improvements
  • Images without geolocation are highlighted after they are imported.
June 19th, 2024 - Back-face culling for 3D mesh
What's new
Improvements
  • For projects processed with the new 3D maps pipeline or projects uploaded from PIX4Dcatch for processing:
    • New geoid models:
      • Singapore SGeoid09 for EPSG:6916 “SHD height”.
      • Czech Republic CR-2005 for EPSG:8357 “Baltic 1957 height”.
      • Portugal GeodPT08 for EPSG:5780 “Cascais height”.
      • Corsica RAC23 for EPSG:5721 “NGF-IGN78 height”.
    • Extent of EPSG:5713 “CGVD28 height” increased to cover Newfoundland, Canada
    • Updated model files for Danish geoid model DVR90.
    • Faster processing time for calibration for larger projects.
    • Faster processing time for 3D textured meshes.
Changes
  • The new 3D maps pipeline produces LAZ as default format for the point cloud instead of LAS.
  • The outputs produced with the new 3D maps pipeline include the name of the project or the site when they are downloaded.
Bugs
  • Fixed the issue of the new 3D maps processing pipeline failing to generate a quality report when the images did not have any XMP tags.
  • Fixed the issue of the new 3D maps processing pipeline failing during point cloud densification of especially large datasets.
  • Fixed the issue of processing failing when projects uploaded from PIX4Dcatch are missing depth data.
  • Fixed the issue of having the wrong icon for annotation groups.
  • Fixed the issue of the quality report sometimes not containing the calibration and reoptimization settings.
  • Fixed the issue of the change capture date of dataset not working.
  • Fixed the issue of third-party applications not being able to display the 3D textured mesh generated with the new 3D maps pipeline.
  • Fixed the issue of processing failing when projects uploaded from PIX4Dcatch include corrupted confidence maps or depth maps.
April 30th, 2024 - Improvements
Improvements
  • Choose the unit of measurement for volume comparison CSV with the unit of measurement switcher in the web UI.
  • PIX4Dcloud tutorial videos have been updated.
Changes
  • Measurements for relatively short distances or small areas are displayed in decimal feet instead of decimal inches.
  • An error message is shown if DXF cannot be displayed in either the 2D or 3D viewer.
Bugs
  • Ground control point targets are consistently detected when the dataset's unit of measurement is feet and the images’ geotags are meter-grade.
  • EGM96 is not applied by default for images’ vertical coordinate systems.
  • Processing finishes successfully when generating DSMs and orthomosaics that, due to their size or shape, cover an especially large geographic area.
  • The DXF is not shifted when using the take screenshot feature.
  • PIX4Dcloud did not display an error message when an account activation email was sent successfully.
April 8th, 2024 - Project coordinate system manual definition
What's new
Improvements
March 27th, 2024 - SHP export enhancements
Improvements
Changes
  • Polygon's color setting defines the perimeter color instead of the fill color.
  • SHP export is not available for share links.
Bug fixes
  • Profile View axes are now correct.
  • Custom base surface altitude is now used in the volume comparison feature.
March 5th, 2024 - Credits auto top-up feature.
Improvements
  • Projects processed from PIX4Dcatch include the project name in the output files.
  • Overlays include a button to download the files.
  • Overlays include a focus-on button to center the view on the overlay.
  • [Credits] The Auto top-up option is now accessible after the second purchase from the user account.
Changes
  • DXF export is not available for share links.
  • New button design includes access to the New folder function.
January 22nd, 2024 - DXF improvements
Improvements
Changes
December 7th, 2023 - New 3D maps template
What's new
  • New 3D maps processing pipeline with the following advantages:
    • Vertical coordinate system and geoid model support.
    • Faster processing.
    • Supports larger datasets.
    • Higher quality of point cloud and 3D textured mesh.
Improvements
Changes
November 21st, 2023 - Improvements
Improvements
  • (Only for PIX4Dcloud Advanced users) In the PDF annotations report, it is possible to:
    • Preview and delete an automatic annotation screenshot.
    • Create a new screenshot manually.
    • Screenshots of inspections are now included in the PDF report.
  • (Only for PIX4Dcloud Advanced users) Importing overlay in projects processed with a WKT2 file from PIX4Dcatch site localization is now possible.
  • Vertical system and geoid are displayed in the lower left corner in projects coming from PIX4Dcatch.
Bug fixes
  • The markers are now displayed in the screenshot of the PDF Annotations report.
  • The position of the marker on the map is displayed, which was previously not updated when changing the coordinates in the details panel.
September 19th, 2023 - Improvements
What's new
  • Annotations report in PDF format, including all types of annotations. This feature is only available for PIX4Dcloud Advanced.
  • Mission planner:
    • Corridor mission: Create, edit, and delete corridor missions.
      • Ideal for linear mapping.
      • Split big corridors into small sections for an organized data acquisition.
    • Link to PIX4Dcloud projects: link missions to your PIX4Dcloud projects to organize your processing results.
  • Organization Support and user management:
June 29th, 2023 - Improvements
What's new
  • Mission planner:
    • Cut direction setting in grid mission split.
    • Flight time estimation: Indicates the estimated total flight time of the mission.
    • Split missions by time: grid missions can now be split based on flight time.
    • Updated mission summary panel: better visibility of the different values.
    • Improved user interface: multiple improvements.
Improvements
  • DXF is now included in the take screenshot feature.
  • Timeline improvements:
    • Clustering for dates that are closer together.
    • Zooming in up to minutes.
  • IFC can be deleted from the hierarchy.
May 16th, 2023 - Export annotations in DXF
What's new
May 4th, 2023 - Mission planner feature
What's new
  • Access to Mission Planner. A web-based application that allows drone flight planning. It can be accessed from PIX4Dcloud and synchronized with the PIX4Dcapture PRO for mission execution.
    • Main features:
      • Plan management: create, edit, and delete flight plans.
      • Mission management: create, edit, and delete missions.
      • Mission types: Grid, Cylinder, and Orbit missions.
      • Import flight plans from external files: import CSV and KML files to create custom missions.
      • Mission split: automatically divide big missions into smaller ones to better organize your data acquisition for extensive areas.
      • Synchronization with PIX4Dcapture PRO app: access your plans and missions from PIX4Dcapture PRO to execute them in the field.
    • Support documentation: Mission Planner - PIX4Dcapture pro.
Improvements
  • New user account login page.
March 9th, 2023 - Display DXF Design Overlay in 3D
What's new
Improvements
  • Available Focus on feature for point cloud, 3D mesh, IFC, and DXF.
  • The Localization Points layer now displays the correct name of each point in projects uploaded and processed with PIX4Dcatch using a custom coordinate system.
January 26th, 2023 - Improvements
What's new
  • Projects processed from PIX4Dcloud User Interface are using PIX4Dmapper version 4.8.3.
Improvements
  • Projects uploaded and processed with PIX4Dcatch using a custom coordinate system show the ortho and DSM with the Mapbox background.
  • DXF files can be organized by groups inside the Design Overlay layer.
December 22nd, 2022 - Improvements
What's new
  • Visualization of the projects computed in a custom coordinate system (Site localization).
Improvements
November 15th, 2022 - Improvements
What's new
  • Toggle annotation visibility by dragging and sliding through the checkboxes for an easier and faster experience.
Improvements
  • DXF layer visibility persists, meaning that it is now possible to hide or show that a part of a DXF layer will remain in that view even after a browser refresh.
Bug fixes
  • DXF duplication in a site is now fixed when moving from one project to another.
October 13th, 2022 - Import DXF
What's new
  • DXF file import as Design Overlay.
Improvements
  • PIX4Dcloud and PIX4Dcloud Advanced process using PIX4Dmapper version 4.8.2 (most recent PIX4Dmapper version available).
Changes
  • New coordinate system transformation database.
  • X is now named Easting, and Y is named Northing.
September 28th, 2022 - Improvements
What's new
  • A Detail tab is available in all projects to show the project metadata.
Improvements
  • A new Building reconstruction option is available on the 3D model template to improve the results for building projects with homogeneous facades.
  • .LAZ point cloud format is now supported.
Changes
September 14th, 2022 - Improvements
Improvements
  • New language available: German.
Improvements
  • AutoGCP algorithm no longer requires a diameter size as input in the project creation wizard.
  • The status of the IFC layers is kept when the project is re-opened.
Bug fixes
  • Fixed the issue where the snapping from/to the IFC was not working properly in some cases.
  • Fixed zooming in and out not working properly when navigating in 3D in projects with IFC files.
August 4th, 2022 - 2D/3D compare and transfer data to Trimble Connect
What's new
  • 3D compare view (Only for PIX4Dcloud Advanced users).
  • Transfer data from PIX4Dcloud or PIX4Dcloud Advanced to Trimble Connect.
  • A new cluster of servers is available in Canada.
  • Download several outputs at the same time.
  • Standard templates are modified when images are taken by ANAFI AI drones. The best internal parameters are applied to calibrate all the cameras and generate quality outputs.
  • North indicator icon in 2D/3D view.
Improvements
  • Online measurements always display precise values.
  • The index layer is displayed on top of the orthomsaic and DSM outputs on the Layer menu by default. This visualization is shown when a project is uploaded from PIX4Dfields to PIX4Dcloud.
  • Subscription plan and License Management are merged into Plans and products under the User account menu.
June 20th, 2022 - Import/Visualize IFC file
What's new
  • Import and visualize an IFC file (Only for PIX4Dcloud Advanced and PIX4engine Cloud users).
Improvements
May 31st, 2022 - Import/Export CSV file in project coordinate system
What's new
Improvements
  • Better image selection for the visual inspector functionality.
  • For projects uploaded from PIX4Dcatch:
    • New geoids supported (South Africa and Mexico).
April 19th, 2022 - Improvements
Improvements
  • PIX4Dcloud and PIX4Dcloud Advanced process using PIX4Dmapper version 4.8.0 (most recent PIX4Dmapper version available).
  • Display status of the project in the timeline.
Bug fixes
  • Fixed bug where the output coordinate system selected by the user was sometimes ignored.
March 17th, 2022 - Improvements
Improvements
  • Texture mesh resolution of 16k x 16k is now supported.
  • The name of the site and the dataset is displayed in the tab of the browser.
  • The project creation wizard now displays the total number of images selected for processing.
Bug fixes
  • Fixed bug related to the Orthomosaic/DSM not being displayed when the projects were processed with some particular coordinate systems.
February 16th, 2022 - Improvements
Improvements
  • PIx4Dcloud and PIX4Dcloud Advanced process using PIX4Dmapper version 4.7.5 (which is the most recent PIX4Dmapper stable release) by default.
February 2nd, 2022 - Limit size increase for orthomosaic, DSM and Index
Improvements
January 17th, 2022 - Multiselect tool for moving and deleting items
What's new
  • Multiselect tool to move several elements to a folder or delete them.
Improvements
  • The histogram of an index is displayed by default.
Changes
  • The units in which a project is displayed by default are the same as those in which it was processed.
December 21st, 2021 - Improvements
Improvements
  • PIX4Dcatch projects:
    • Improved 3D reconstructions when processing projects uploaded from PIX4Dcatch to PIX4Dcloud.
    • Improved point cloud visualization.
    • New geoids supported.
  • The state of layers in the hierarchy is kept when reopening the project.
Changes
  • PIX4Dcloud and PIX4Dcloud Advanced are now processing using PIX4Dmapper version 4.6.4 by default.
Bug fixes
  • Fixed the issue where the georeferencing was not properly taken from some images.
December 8th, 2021 - First person camera control and improvements
What's new
Changes
  • Plant Health (NDVI) layer is now named Index.
  • Index layer hangs from Outputs in the hierarchy of the 2D/3D view.
November 1st, 2021 - Output coordinate system selection
What's new
Improvements
October 4th, 2021 - Circle annotation, bug fixes and improvements
What's new
Improvements
  • Exporting an image from the virtual inspector adds the inspection name at the end.
  • Annotation import in SHP format allows both a ZIP file but also individual files.
  • PIX4Dcatch projects show the 3D view by default.
Bug fixes
  • Fixed the issue with the overlay naming not being persistent from one site to another
  • Fixed the issue when some selected layers were not displayed
  • Fixed the issue where the cloud user interface was always open in dark mode even if the user selected bright the last time
  • Fixed the issue where the drawing boxes were not working for the first inspection
  • Fixed the issue where the unit selector did not change the displayed units in the editor sometimes.
August 13th, 2021 - Improvements
Improvements
  • The name of the annotations are displayed when hovering over them with the mouse for all types of annotations both in the 2D and the 3D view. More information here.
August 2nd, 2021 - Bug fixes and improvements
Improvements
Changes
  • The name of the annotations which is displayed when hovering (both in 2D and 3D) has a different format
Bug fixes
  • Some bugs in the Virtual Inspector have been fixed:
    • Images did not display when full mode was selected
    • The export button did not work in full mode
    • It was not possible to add a box in full mode
  • Fixed the issue with the images taken in portrait mode which were rotated in the thumbnails in the virtual inspector and files section
  • Fixed the issue which displayed the type of the GCP wrongly in the right panel
June 29th, 2021 - Improved integration with PIX4Dcatch
What's new
Projects uploaded from PIX4Dcatch and processed with depth data have several important improvements:
  • Sky segmentation: improved point cloud generation to have less noise from sky and water in the 3D reconstructed model
  • Quality report: a quality report is available for new projects processed with depth data
  • Better performance: in terms of processing speed and number of images to be processed
Improvements
  • When exporting a screenshot from the UI, the name of the file is now the name of the project.
Bug fixes
  • Fixed the issue where the orthomosaics produced with PIX4Dfields which were uploaded to PIX4Dcloud did not have a transparent background
  • A vertex could not be deleted in a polygon and or in a line
  • The profile view did not show the cursor in the editor when hovering with the mouse over the profile
May 11th, 2021 - New live measurement computation
Changes
  • New live measurement computation. More information here.
Bug fixes
  • Fixed the issue where, in some projects, line and polygon annotations were slightly moving away from the original coordinates (only while drawing them).
April 27th, 2021 - Italian and Spanish translations
What's new
  • PIX4Dcloud and PIX4Dcloud Advanced are now available also in Italian and Spanish. For more information about supported languages: PIX4Dcloud - FAQs.
April 15th, 2021 - Bug fixes and improvements
Improvements
  • Display the name of markers when hovering over them. More information here.
Changes
  • By default, the project coordinate system is selected in the coordinate system selector
Bug fixes
  • Fixed the issue which made the editor freeze in projects with arbitrary coordinate systems.
  • Fixed the issue with the zoom when a double click relocated the project in the wrong position.
March 22nd, 2021 - Improved orthomosaic and DSM tiler, bug fixes and improvements
Improvements
  • New and improved orthomosaic and DSM tiler. For more information: Improved Ortho and DSM tiler on the cloud.
  • Added feedback message for upload limits (7 GB for the GeoTIFF orthomosaic and 1 GB for the 3D Mesh OBJ).
Bug fixes
  • GCPs layer and lower bar coordinates are kept in the base unit (not converted from meters to kilometers or feet to miles).
  • Improved usability of the Virtual Inspector on small screens.
February 10th, 2021 - GCPs layer, bug fixes and improvements
What's new
  • [PIX4Dcloud Advanced] GCPs layer display. When a project is processed with AutoGCPs on the cloud, there is a new layer in the hierarchy which contains the GCPs and check points that have been automatically detected (more information in GCPs layer). This applies to projects created from the release date.
  • Unit selector: New selector for defining the units used in the project when displayed in the 2D/3D view. For more information: Improved units display in PIX4Dcloud.
  • Support of overlays for arbitrary (user-defined) systems: You can find more information in How to work with arbitrary systems on PIX4Dcloud.
Improvements
Bug fixes
  • Fixed the issue with the Virtual Inspector not working properly with some cameras
  • Fixed the issue where in rare occasions a Point Cloud was completely colored in purple while in elevation color mode. Now it should always display elevation color mode properly
  • Fixed the issue with the volume computation using custom as the base surface. The custom elevation previously could not be typed in feet
December 8th, 2020 - Bug fixes and improvements
Improvements
  • Mobile device improvements (more information here)
    • Changes in the 2D/3D user interface
    • Improved mobile support for editing points, lines and polygons so that they can be selected more easily on touch screens
  • Projects uploaded from PIX4Dmapper 4.6 version can be processed
  • Sub-cm precision for measurements and annotations: especially for PIX4Dcatch projects where images are taken very close to the object and the GSD (Ground Sample Distance) can be very small
Bug fixes
  • Fixed the issue where an Overlay was not displayed properly when the site had projects with different coordinate systems. (Note: For existing Overlays which have already been imported and are not displayed for this reason, they should be imported again)
  • Fixed the issue where the Show my current position icon was hidden by the orthomosaic layer. Now it is always displayed on top of the orthomosaic and DSM
November 5th, 2020 - Bug fixes and improvements
Improvements
  • The volume annotation is disabled when the project has no DSM and therefore the volume cannot be calculated
  • [PIX4Dcloud Advanced] New messages warn the user when using the AutoGCPs detection functionality if:
    • The wrong GCP file has been imported
    • The wrong coordinate system file has been imported
  • [PIX4Dcloud Advanced] Improvements to handle larger overlays
Bug fixes
  • Fixed the issue for when zooming in very quickly meant PIX4Dcloud did not display the highest ortho resolution
  • Fixed the issue for when sometimes the red and blue marks of the import overlay feature were not displayed
  • Fixed the issue when creating a field in the NDVI layer. Sometimes the '+' button was gone
October 22nd, 2020 - Bug fixes and improvements
Improvements
  • [PIX4Dcloud Advanced] New project group card in a stacked style
  • Search functionality includes folders. A project can be searched for even if it is inside a folder
  • New NDVI and DSM icons visible in editor during tiling
  • [PIX4Dcloud Advanced] Messages in the comparison mode inform users about the alignment of the project
  • The GCP tab is not available if the project does not contain GCPs automatically detected by the AutoGCPs detection functionality
  • Improved performance while uploading images
Bug fixes
  • Fixed the issue which made the NDVI layer disappear when drawing a boundary. Now it is displayed and the user can better adjust the boundary
  • Corrected text and inconsistencies in the user interface
September 28th, 2020 - Processing templates step and Crane Camera projects AutoGCPs alignment
What's new
  • Different type of computations via a template selection step
  • [PIX4Dcloud Advanced + CraneCamera] AutoGCP alignment for Pix4D CraneCamera projects
  • [PIX4Dcloud Advanced + CraneCamera] Message informing about the type of alignment used
Improvements
  • [PIX4Dcloud Advanced] Pop up message when the GCP target size has weird values. When the GCP target size is lower than 20 cm or larger than 2 meters, a message is displayed to verify that the value is correct.
  • New icon for projects which have been shared but have no outputs
Bug fixes
  • Fixed the issue when the altitude was not properly computed in some projects until the user refreshed the browser. The right value is now displayed from the beginning
  • Fixed the issue with the 3D embeds not working for anonymous users
August 19th, 2020 - Bug fixes and improvements
Improvements
  • [PIX4Dcloud Advanced] Timeline performance improvements for large sites (+200 datasets)
  • [PIX4Dcloud only] Add icon for new dataset button
  • Improved text visibility for projects that are processing in light theme mode
  • Improved spacing for elevation profile measurements
  • Improved user menu access for small mobiles
  • [PIX4Dcloud Advanced + CraneCamera] Added link to support article when a project is not well-aligned
  • [PIX4Dcloud Advanced] 3D view is preserved when changing from one day to another. When a user is looking at the 3D view on Day1 and goes to Day2 through the timeline, Day2 will also show the 3D view
Bug fixes
  • Persists the chosen language by the user
  • Fixed the issue when creating a project in a folder (it was created in the root level)
  • Empty folders could not be deleted despite they did not contain any project or site. Now it is possible to delete them.
  • [PIX4Dcloud Advanced] Fixed the issue where invalid characters in the file imported as overlay broke the processing and the overlay was never displayed.
August 3rd, 2020 - Bug fixes and improvements
Improvements
  • [PIX4Dcloud Advanced] Added help button in the volume comparison
  • Added link to support article when selecting the processing template
  • Pop up message when a user is reaching the end of the allowance
  • [PIX4Dcloud only] Direct access to PIX4Dcloud Advanced trial license through the account menu for users with access to PIX4Dcloud
Bug fixes
  • [PIX4Dcloud Advanced] Fixed the issue with having decimals in the GCP target size (it did not process)
  • Fixed the issue where units were not properly taken when sharing a project
  • Fixed the issue with the start process button which could be clicked more than once and that was causing projects to fail.
  • Fixed the issue with importing a zipped point cloud. The uploader got stuck.
  • [PIX4Dcloud Advanced] Fixed the issue when going back to the editor after using the compare mode, two orthos and two DSMs were displayed in the same project
Changes
  • [PIX4Dcloud Advanced] Disable annotations in compare mode
July 3rd, 2020 - Processing templates, bug fixes and improvements
What's new
  • Processing template selection
Improvements
  • [PIX4Dcloud Advanced] Overlay import allows zooming as much as needed
  • Welcome dialog has been removed and a new login icon has been added
  • Better support for Microsoft Edge browser
  • User interface improvements: better contrast in the uploader, better contrast in the drop area in the wizard, improved files view for mobile users
  • PIX4Dcloud favicon added
Bug fixes
  • [PIX4Dcloud Advanced] Compare mode: fix to show the compare button in shared projects, fix to solve an issue with the second project not refreshing correctly
  • [PIX4Dcloud Advanced] GCP report can be opened in Acrobat Reader
  • Fixed the issue where units were not taken properly from the account settings
  • Fixed the export button in the Virtual Inspector
  • Fix to inform the user when a .zip file is being prepared for download
June 9th, 2020 - Launch release
What's new
  • PIX4Dcloud and PIX4Dcloud Advanced are standalone products and can be purchased separately from PIX4Dmapper.
  • New UI with respect to the old Cloud platform
  • PIX4Dcloud Drive to better organize, view and filter the projects
  • Guided procedure for project and site creation
  • 2D and 3D synchronized views displaying DSM, orthomosaic, NDVI map, Point Cloud and 3D Textured Mesh
  • Markers, measurements, volume calculations exchangeable between projects and third-party software
  • Adjustable layer hierarchy
  • Sharing functionality with view and measure or edit and save rights
  • Dedicate view for downloadable input and output files
  • [PIX4Dcloud Advanced] Visualization of the evolution of the site through a Timeline.
  • [PIX4Dcloud Advanced] AutoGCPs detection functionality. Our AI algorithm finds and marks the GCPs for you during the processing phase
  • [PIX4Dcloud Advanced] CAD overlays to easily import and overlay design plans and maps. The as-built can be quickly compared with the as-designed to easily check progress and identify as-built errors
  • [PIX4Dcloud Advanced] 2D comparison (shareable) view
  • [PIX4Dcloud Advanced] Volume comparison and monitoring report
