New dataset > Dataset creation > Upload images - PIX4Dcloud
Create a new dataset to start processing imagery and create maps and digital twins of the reality or upload outputs to PIX4Dcloud.
Access: To create a new dataset, at the top left of the Drive, click New and select New dataset. The New dataset wizard opens.
Licenses:  This article is valid for all PIX4Dcloud licenses.
Roles: Only Owners, Managers, and Editors can create and process datasets in PIX4Dcloud.
1.Dataset creation    > 2. Image selection   > 3.Output coordinate system                       > 4.Processing options           > 5. GCPs automation
Upload images                            / Upload results
Video: The following video tutorial explains step-by-step how to process a project with images with PIX4Dcloud Advanced.
The images uploaded as a new dataset will be processed to generate the photogrammetric outputs defined in step 3. Processing template.
  1. Under Dataset name, enter a name for the dataset. (max 100 characters)
  2. For PIX4Dcloud Pro and higher licenses: Under Site, enter the name of an existing Site or enter a new name to create a Site.
  3. Click Upload and process images.
  4. Click Next to continue.
  5. Follow the instructions for step 2. Image selection.
  • If the user account is under the image and datasets allowance system, the system displays the remaining number of images available for processing from the quota.
  • If the user account is under the credit balance system, the system displays the number of credits available from processing.
    Dataset step 1 project wizard
