Technical release notes - PIX4Dcloud
Related articles:
June 26th, 2026 - UI Enhancements, Bug Fixes, and API Updates
Changes:
- When searching in PIX4Dcloud’s drive, the results no longer include datasets that are assigned to a site; instead, search for the site
- API credentials are no longer associated with a specific license.
- The Detection of the GCPs failed email will be discontinued in July 2026. More information about control points is in the Quality report after processing is complete.
Bug fixes:
Fixed the issue where one or more people could be unexpectedly removed from an organization after switching to another organization.
- Fixed the issue where inspection or marker annotations could not be selected in the web UI’s 3D editor.
- Fixed the issue where an organization member with the minimum permissions required could not generate an annotations report.
- Fixed the issue where parts of the orthomosaic sometimes disappeared or flickered in the web UI’s 2D editor when zoomed in.
April 29th, 2026 - Enhanced 3D Visualization, Improved Processing Efficiency, and UI Refinements
Improvements:
Reduced processing time for datasets with especially large number of 2D keypoint matches.
- Increased the maximum number of image marks that can be added to a dataset and processed.
Changes:
- “Volume difference” is named “Net volume”.
Bug fixes:
- Fixed the issue where the web UI’s 3D editor sometimes did not automatically zoom to the 3D textured mesh after clicking Focus on 3D Textured Mesh in the layers list.
- Fixed the issue where SLPK point clouds were rendered at an unexpected elevation when the PIX4Dcloud dataset’s coordinate reference system did not have a vertical component.
- Fixed the issue where reconstructions were sometimes unexpectedly cropped vertically when generating Gaussian splats with a region of interest and a non-metric coordinate reference system.
- Fixed the issue where compare more rendered DXF design overlays on both sides of the slider.
- Fixed the issue where annotations snapped to hidden annotations while holding Shift.
- Fixed the issue where a volume measurement was not rendered when it was behind a transparent IFC design overlay or 3D textured mesh.
- Fixed the issue where annotations snapped to a marker annotation’s icon, annotation measurements, or annotation labels.
- Fixed the issue where the web UI’s 3D editor sometimes did not render the highest level of detail available for a 3D textured mesh.
February 16th, 2026 - SLPK projection support for ArcGIS Online
What's new:
- ArcGIS Online integration now supports projecting SLPK 3D textured meshes to WKID: 3857 - Web Mercator, allowing proper alignment with ArcGIS Online’s default global scene basemaps.
February 13th, 2026 - Support for new server cluster (Switzerland)
What's new:
A new cluster of servers is available in Switzerland.
Bug fixes:
Fixed the issue where DXF design overlay layers could be reordered in the web UI’s 2D/3D editor layers list.
- Fixed the issue where it was not possible to open or download individual images with the web UI.
January 21st, 2026 - Support for new server clusters
What's new:
New clusters of servers are available in Australia, Brazil, Singapore, and the United Kingdom.
Improvements:
More comprehensive and clearly defined 2D background maps.
Bug fixes:
Fixed the issue where the Transfer to ArcGIS Online integration sometimes failed to transfer especially large files.
- Fixed the issue where the point cloud sometimes flickered or reloaded in the 3D compare mode.
- Fixed the issue where the web UI’s 3D editor sometimes rendered Autotags in front of Gaussian splats.
- Fixed the issue where the web UI’s 2D editor sometimes displayed triangle-shaped artifacts while rendering orthomosaics.
January 16th, 2026 - Enhanced 3D Editing, Seamless Credit Processing, and Improved Layer Alignment
Improvements:
The web UI’s 3D editor does not render points that were disabled and then uploaded with PIX4Dmatic.
Bug fixes:
Fixed the issue where annotations created with PIX4Dcatch while collecting a dataset were not consistently aligned with other layers.
- Fixed the issue where some orthomosaic GeoTIFFS could not be downloaded during the retention period.
- Fixed the issue where processing would not start automatically after buying credits.
- Fixed the issue where PIX4Dcloud Pro Professor license owners could not access Pro features.
