Technical release notes - PIX4Dcloud
Related articles:
August 14th, 2026 - Fixes for Permissions Management, Setup Wizards, and Navigation
Bug fixes:
Fixed the issue where the dataset creation wizard showed a project group name as invalid before the field was edited.
- Fixed the issue where navigating in or out of a demo dataset on Windows redirected users to a 401 login page.
- Fixed the issue where the circle tool’s color and tag configuration was not visible before drawing a circle.
- Fixed the issue where organization-level access to a resource was shown as direct resource access, and access could not be edited.
- Fixed the issue where invitations were incorrectly created for existing users when attempting to lower their role.
- Fixed the issue where a resource’s access management list did not include users who had been granted access immediately.
August 5th, 2026 - Orthomosaic quality improvements and 3D viewer reliability fixes
Improvements:
Improved orthomosaic quality for API processing so results more closely match PIX4Dmatic.
Bug fixes:
- Fixed the issue where a volume measurement sometimes returned a significantly incorrect result when the calculation was triggered immediately after creating the volume annotation.
- Fixed the issue where the 3D editor did not update the camera position when switching between projects’ 3D views.
- Fixed the issue where the 3D textured mesh extended outside the bounds of a user-provided region of interest.
- Fixed the issue where pre-existing annotations could not be selected after switching from the 2D editor to the 3D editor.
- Fixed the issue where the 2D map’s rotation was not saved when using Save view as default.
- Fixed the issue where title font sizes in Files & Reports were inconsistent with the design system.
- Fixed the issue where opening the Access Role dropdown while inviting a user caused the Resource Invite dialog to render incorrectly over the Drive view.
- Fixed the issue where opening the URL of a dataset that does not exist or was deleted caused the web UI to hang on a blank screen.
July 8th, 2026 -Enhanced Processing Orchestration, UI Improvements, and Core Stability Fixes
What's new:
After PIX4Dcloud finishes processing a dataset, a survey about the quality of the results may appear.
Improvements:
- Improved the image selection step in the dataset creation wizard with a better balance between the image list and map, making it easier to review selected images.
- Improved Gaussian splats generation with tighter regions of interest for drone and mixed projects to reduce blurry surroundings.
- Improved processing orchestration so PIX4Dcloud can better respond to spikes in processing demand and move projects through processing states faster.
- Updated the user menu with clearer organization, refreshed icons, and easier access to documentation, demo projects, training, community, privacy settings, and the support chatbot.
Changes:
- Data retention notification emails are now sent to both Owners and Managers of an Organization, in addition to the Organization’s email contacts.
Bug fixes:
- Fixed the issue where an organization removal email was sent when someone’s access license or resource was downgraded.
- Fixed the issue where annotations could be unexpectedly deleted or the web UI’s editors could display the content of a different dataset after someone with edit permissions opened a dataset using a read-only link
- Fixed issue where annotations did not snap to IFC design overlays in the 3D editor unless another 3D layer was also active.
- Fixed the issue where processing failed when the dataset’s coordinate reference system was arbitrary, i.e., engineering CRS.
- Fixed the issue where the dataset’s location in the drive’s map was sometimes incorrect for datasets using a left-handed coordinate reference system.
- Fixed the issue where “Focus on Annotation” did not move the camera for projects created with a site-localized CRS.
- Fixed the issue where the dataset creation wizard silently failed to create a site with a name that is longer than 100 characters.
- Fixed processing failures for datasets with mixed image resolutions.
- Fixed the issue where processing failed when the dataset included blank PIX4Dcatch depth maps.
- Fixed the issue where a point cloud unexpectedly remained visible in the web UI’s 3D editor after it was replaced.
- Fixed the issue where manually uploaded 3D textured meshes could appear pixelated in the 3D editor.
July 7th, 2026 - Inspector reliability, layer visibility, and drive UI enhancements
Improvements:
- Drive action menu items now display distinct icons and labels so users can clearly tell apart moving a dataset within the directory tree and linking or assigning it to a site.
Changes:
- The field previously named “name” is now labeled “label” across the product.
- The point size of datasets uploaded from PIX4Dcatch to PIX4Dcloud has been set to 2 for better visualization.
Bug fixes:
- Fixed the issue where the inspect tool stopped working after switching between projects within the same site.
- Fixed the issue where the Virtual Inspector continued to show images from a previously active dataset after switching datasets on a site.
- Fixed the issue where the image selection header and “Add images” button disappeared when scrolling through a long image list in the dataset creation wizard.
- Fixed the issue where annotation reports displayed internal IDs instead of user-facing labels.
- Fixed the issue where some child layers (including Autotags and Annotations) remained visible in the web UI’s 3D editor after their parent layer was deactivated in the layers list.
- Fixed the issue where the Autotags layer checkbox in compare mode did not correctly control the visibility of its child checkboxes.
June 26th, 2026 - UI Enhancements, Bug Fixes, and API Updates
Changes:
- When searching in PIX4Dcloud’s drive, the results no longer include datasets that are assigned to a site; instead, search for the site
- API credentials are no longer associated with a specific license.
- The Detection of the GCPs failed email will be discontinued in July 2026. More information about control points is in the Quality report after processing is complete.
Bug fixes:
Fixed the issue where one or more people could be unexpectedly removed from an organization after switching to another organization.
- Fixed the issue where inspection or marker annotations could not be selected in the web UI’s 3D editor.
- Fixed the issue where an organization member with the minimum permissions required could not generate an annotations report.
- Fixed the issue where parts of the orthomosaic sometimes disappeared or flickered in the web UI’s 2D editor when zoomed in.
April 29th, 2026 - Enhanced 3D Visualization, Improved Processing Efficiency, and UI Refinements
Improvements:
Reduced processing time for datasets with especially large number of 2D keypoint matches.
- Increased the maximum number of image marks that can be added to a dataset and processed.
Changes:
- “Volume difference” is named “Net volume”.
Bug fixes:
- Fixed the issue where the web UI’s 3D editor sometimes did not automatically zoom to the 3D textured mesh after clicking Focus on 3D Textured Mesh in the layers list.
- Fixed the issue where SLPK point clouds were rendered at an unexpected elevation when the PIX4Dcloud dataset’s coordinate reference system did not have a vertical component.
- Fixed the issue where reconstructions were sometimes unexpectedly cropped vertically when generating Gaussian splats with a region of interest and a non-metric coordinate reference system.
- Fixed the issue where compare more rendered DXF design overlays on both sides of the slider.
- Fixed the issue where annotations snapped to hidden annotations while holding Shift.
- Fixed the issue where a volume measurement was not rendered when it was behind a transparent IFC design overlay or 3D textured mesh.
- Fixed the issue where annotations snapped to a marker annotation’s icon, annotation measurements, or annotation labels.
- Fixed the issue where the web UI’s 3D editor sometimes did not render the highest level of detail available for a 3D textured mesh.
February 16th, 2026 - SLPK projection support for ArcGIS Online
What's new:
- ArcGIS Online integration now supports projecting SLPK 3D textured meshes to WKID: 3857 - Web Mercator, allowing proper alignment with ArcGIS Online’s default global scene basemaps.
February 13th, 2026 - Support for new server cluster (Switzerland)
What's new:
A new cluster of servers is available in Switzerland.
Bug fixes:
Fixed the issue where DXF design overlay layers could be reordered in the web UI’s 2D/3D editor layers list.
- Fixed the issue where it was not possible to open or download individual images with the web UI.
January 21st, 2026 - Support for new server clusters
What's new:
New clusters of servers are available in Australia, Brazil, Singapore, and the United Kingdom.
Improvements:
More comprehensive and clearly defined 2D background maps.
Bug fixes:
Fixed the issue where the Transfer to ArcGIS Online integration sometimes failed to transfer especially large files.
- Fixed the issue where the point cloud sometimes flickered or reloaded in the 3D compare mode.
- Fixed the issue where the web UI’s 3D editor sometimes rendered Autotags in front of Gaussian splats.
- Fixed the issue where the web UI’s 2D editor sometimes displayed triangle-shaped artifacts while rendering orthomosaics.
January 16th, 2026 - Enhanced 3D Editing, Seamless Credit Processing, and Improved Layer Alignment
Improvements:
The web UI’s 3D editor does not render points that were disabled and then uploaded with PIX4Dmatic.
Bug fixes:
Fixed the issue where annotations created with PIX4Dcatch while collecting a dataset were not consistently aligned with other layers.
- Fixed the issue where some orthomosaic GeoTIFFS could not be downloaded during the retention period.
- Fixed the issue where processing would not start automatically after buying credits.
- Fixed the issue where PIX4Dcloud Pro Professor license owners could not access Pro features.
