Outputs - PIX4Dcloud
The outputs of PIX4Dcloud consist of photogrammetric results and of post-processing outputs, such as annotation files.
Licenses: This article is valid for all PIX4Dcloud licenses.
Roles: Only Owners, Managers, and Editors can export outputs from a datasets in PIX4Dcloud.
Access: The generated outputs (point cloud, 3D mesh, DSM, orthomosaic, quality report, log file, and other outputs and formats) are accessible once processing is complete in Files & Reports > Results.
Project processed via project wizard in PIX4Dcloud
When creating a new dataset to process on PIX4Dcloud/ or PIX4Dcloud Pro, the following standard outputs (with default formats) can be generated and made available for their web visualization, according to the  Processing options selected in step 4.
Output Extension  Description
Orthomosaic .tif Orthomosaic file.
DSM .tif DSM file.
Point cloud .laz, .las, or .slpk (**) Point Cloud file(s).
Gaussian Splat .ply 3D object
3D mesh .obj or .slpk (*) OBJ 3D Mesh with texture files.
Quality report .pdf Quality report of the project.
Log file .log Application logs, generally used for troubleshooting.
(*) PIX4Dcloud generates scalable 3D textured meshes by default, if an OBJ file is needed it has to be requested as a single file in the processing options project wizard.
(**) The .slpk file format is only available with PIX4Dcloud Pro licenses.
Note: The Point Cloud will be available in either .las or .laz format natively, depending on the specific export format selected during Step 4 ("Processing options") of the PIX4Dcloud project wizard.
Project processed via PIX4Dcatch
When processing a project via PIX4Dcatch to be processed with PIX4Dcloud/or PIX4Dcloud Pro, the following standard outputs (with default formats) can be generated and made available for their web visualization.
DSM .tif DSM file.
Point cloud .laz
3D mesh .obj OBJ 3D Mesh with texture files.
Gaussian Splat (*) .ply Photorealistic 3D model
(*) It has to be required by the user when uploading images for processing from PIX4Dcatch. See Using PIX4Dcatch to generate a Gaussian Splat model for more information.
Outputs uploaded to an empty project in PIX4Dcloud
When uploading results to a project in PIX4Dcloud/or PIX4Dcloud Pro, the following output formats can be downloaded afterward.
DSM .tif DSM file.
  NDVI .tif NDVI index.
Point cloud .laz / .las Point Cloud file(s).
Outputs uploaded via Share to PIX4Dcloud
When uploading results to a PIX4Dcloud project via Share to PIX4Dcloud, the following output formats can be downloaded afterward.
Pix4D product Output Extension  Description
PIX4Dmatic/PIX4Dsurvey Orthomosaic / DSM .tif Orthomosaic file / DSM file
  Point cloud .laz Point Cloud file(s).
PIX4Dfields/PIX4Dreact Orthomosaic / DSM / Index .tif Orthomosaic file / DSM file / Indexes (BNDVI, GNDVI, CLI, NDVI)
Post-processing results and workflows
Annotation files
After the dataset is processed on PIX4Dcloud and/or available for its web visualization, annotations can be added and later on exported to third-party software or to other PIX4Dcloud datasets.
More information on how to export annotations and which formats are supported for their export in How to export/import annotations.
Download/Export results
Outputs from PIX4Dcloud can be downloaded individually or as a results folder. More information on how to export outputs in Download/Export. When accessing the project via share link, this feature is not available.
Share
Outputs from PIX4Dcloud can be shared for collaboration purposes. For more information: Share.
Note: Outputs and project files generated by PIX4Dcloud are kept under the PIX4Dcloud account according to the terms of the PIX4Dcloud storage expiration policy.
