How to download the results from PIX4Dcloud
This article explains how to download the results of a project in PIX4Dcloud.
Video: The following video tutorial explains step-by-step how to download outputs from a PIX4Dcloud project.
Licenses: This article is valid for PIX4Dcloud Starter and PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can download outputs from a datasets in PIX4Dcloud.
After processing on PIX4Dcloud, the results can be downloaded singularly or as project folders.
To download results:
- Open an already created dataset.
- Go to Files & Reports > Results to display the list of downloadable items.
- Click Download on the desired output.
- If asked, specify the format to export the output locally.
- The requested output starts downloading.
Type of outputs
Available downloadable files can be the following.
OUTPUT
FORMAT |
| Orthomosaic (transparent or opaque) |
GeoTIFF GeoTIFF bundle (.tif+.prj+.tfw) |
| DSM | GeoTIFF |
| NDVI | GeoTIFF |
| Reflectance maps (*) | GeoTIFF (of each band) GeoTIFF bundle (all bands) |
| Point Cloud | .LAZ, .LAS, or .SLPK (**) |
| Mesh |
.OBJ or .SLPK(*) (Zipped folder containing the .obj, .mtl, .jpg mesh files together with the offset.xyz file to georeference the mesh in third-party software) |
| Gaussian Splat (*) | PLY (The file includes centered coordinates. The offset.xyz included in the 3Dmesh download can be used for a correct georeferentation of the file) |
(*) PIX4Dcloud generates scalable 3D textured meshes by default, if an OBJ file is needed it has to be requested as a single file in the processing options project wizard.
(**) The .slpk file format is only available with PIX4Dcloud Pro licenses.
Important: When using a share link, the download of outputs is not possible.
Download reports
In the Reports section, available reports show the label PROCESSED.
Quality report / Processing log
Processing log
LOG
Annotations report
To download a report:
- Click Download on the desired report.
- The requested report starts downloading.
Download input images
In the Bundles section, available results show the label PROCESSED or AVAILABLE.
Input images
ZIP (Zipped folder containing the input images)
To download the input files:
- Click Download on the Input Images. A notification will appear indicating that the .zip file is being generated. As soon as the .zip file is ready for download, an email will be sent to the license account's email address.
- Open the email and click Download your Input Zip.
- Unzip the file and save the folder in the desired directory.
