How to customize the options for processing on PIX4Dcloud
Processing options can be customized for PIX4Dcloud processing if the project is created in PIX4Dmapper and uploaded to PIX4Dcloud, otherwise the processing options are the ones defined in the step 4 of the processing wizard.
Important: A PIX4Dmapper and a PIX4Dcloud license are needed to customize the Processing Options with the following workflow.
Customized Processing Options are useful:
- To customize settings based on specific needs.
- To generate additional outputs or additional output formats on top of the default ones.
Note: Only standard outputs can be displayed for web visualization. Additional outputs and formats can be generated and downloaded.
To select custom options for PIX4Dcloud:
- Create a project or open the downloaded project in PIX4Dmapper.
- On the menu bar, click Process > Processing Options...
- Customize the processing options. Alternatively, at the bottom of the window, click Load Template, and select the appropriate one. For more information: Processing Options Default Templates.
- Mark the Steps that need to be run.
- Click OK.
- On the menu bar, click Project > Save Project.
- Upload the project to PIX4Dcloud. For more information: How to upload project files from PIX4Dmapper to PIX4Dcloud.
