Download/Export - PIX4Dcloud
PIX4Dcloud allows exporting/downloading inputs, outputs, and reports.
Licenses: This article is valid for PIX4Dcloud Starter and PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can download outputs from a datasets in PIX4Dcloud.
Information:
- This feature is not available when using a share link.
- This feature is not available for trial users.
To export the files:
- Open an already created dataset.
- Go to Files & Exports > Download. The list of downloadable items is displayed.
- Follow the specific workflow for the download according to the needed outputs.
Important:
The download does not start immediately for the Input files and the results folder, but an email with the downloadable folder is sent when this one is ready.
- Refer to the following article to determine which outputs are available for download based on the license type, upload method, and selected processing options: Outputs - PIX4Dcloud
The file is downloaded on the local device and can be opened in third-party software.
Warning: It is possible that trying to unzip the results with the default Windows unzip program does not let you perform this action, as is present in some project names. In that case, it is recommended to install the 7zip tool and try again.
