Note: The app is not discontinued yet. This will happen at the end of July
For now, we want to stop new users, but current users should still get support. Therefore the page about how to install an APK should still remain online.
Download the latest version of the PIX4Dcapture Pro app for iOS on the App Store and for Android on the Play Store or directly from our knowledge base for the APK download.
Step 1. Equipment setup
Step 2. Safety and Security settings check
Step 3. Create a data acquisition plan, select the mission(s), and fly
Step 4. Process the dataset
- Sign up or Log in with a Pix4D user account (internet connection required).
- Go to the area of interest.
- Turn on the controller and the drone.
- Connect the controller to the device (if no built-in screen) with the corresponding cable.
- Launch PIX4Dcapture Pro.
- Select the drone model from the Drone selector section.
- Once the status of the drone is Connected, tap Map view, New plan, or Plans.
Note: Download offline maps to either fly without an internet connection or/and to enable the Terrain awareness feature for grid missions.
Note: When selecting a drone using a smartphone or tablet, drones requiring the use of an APK installed on a controller will not appear (a compatibility list is available here: Supported drones, cameras, and controllers - PIX4Dcapture Pro).
Note: When using drones with a thermal camera (DJI Mavic 3T, Anafi USA, Anafi Thermal), only the RGB camera can be selected.
Before starting a mission, it is strongly recommended to go through the Safety and Security settings. A detailed description of the settings can be found in General Settings - PIX4Dcapture Pro.
On the top bar, tap if you are not logged in, or
if you are logged in (it shows the user's initials), to access the general settings.
- Ensure the minimum drone battery level to start a mission is correctly set.
- Ensure the signal lost action is defined correctly.
- Ensure the RTH height is set correctly.
- Ensure the maximum flight altitude and geofencing are set correctly in the vendor app.
After setting the Safety and Security checks, the user is ready to start flying.
- To creates a new plan:
- Tap
from the App ́s dashboard or from the Map View
- Tap New plan from the plans list
- Tap
- Select a Generic Mission or an Asset Type and tap Next (more info on our Mission Types - PIX4Dcapture Pro article).
Important: The Asset Types and Generic Missions are not compatible. A plan can contain a unique asset type (e.g. Cell tower or Transmission tower) or one or several generic mission(s) (e.g. Grid, Orbit, Cylinder).
When selecting Cell tower or Transmission tower:
Mission planning is done by flying the drone on the field in order to ensure that the flight plan is positioned correctly. The take-off and the point of interest definition phases are done by manually piloting the drone.
To inspect a Cell tower or Transmission tower, the steps are the following:
1. Before taking-off:
- Ensure you have a strong GP signal.
- Be aware of the tower surroundings and any potential obstacles.
- Set the take-off position at least 20m away from the upcoming mission flight path in a safe place at the same or lower elevation as the tower base.
2. Take-off manually.
3. Follow the instructions on the screen to define the point of interest references.
4. Select a 3D Model or Visual Inspection mission and adjust the parameters if needed.
5. Tap Start mission for the mission checklist to be displayed. If all the checks are passing, Tap Fly mission. The drone exits the manual mode and performs the mission. An estimate of the time remaining until completion is displayed throughout the whole mission.
6. (Optional) A mission can be interrupted at anytime. For more information: How to interrupt a mission - PIX4Dcapture Pro.
7. Repeat the steps from 4 to 6 for each mission. Multiple missions of the same type can be performed for a Cell tower asset or a Transmission tower asset.
When selecting Grid, Orbit, or Cylinder mission:
The take-off phase is handled by PIX4Dcapture Pro, but the mission can also be started from the air. The base map is used to position the flight plan and set the mission boundaries.
To perform a Grid, Orbit, or Cylinder mission, the steps are the following:
1. Place and design the mission over the basemap (spatial reference).
2. Define the mission properties. For more information: Manual - PIX4Dcapture Pro.
3. Tap Start mission for the mission checklist to be displayed. If all the checks are passing, Tap Fly mission. The drone takes off automatically, climbs up to the mission height, and performs the mission. An estimate of the time remaining until completion is displayed throughout the whole mission.
4. (Optional) A mission can be interrupted at any time. For more information: How to interrupt a mission - PIX4Dcapture Pro.
When a mission is over:
1. Tap the return to home button or manually fly the drone home for landing.
2. Switch off the drone and the controller.
The acquired images/videos are now stored on the SD card or internal storage, and they can be used to generate photogrammetric products or for visual inspection.
Upload and analyze your data on the PIX4Dcloud platform or any desktop software by Pix4D.
