A new project from A-Z - PIX4Dcatch
This article provides instructions for using PIX4Dcatch, covering everything from initial setup to capturing and processing your 3D scanned projects.
PIX4Dcatch is a mobile application designed for terrestrial 3D scanning. It uses your mobile device's integrated sensors (camera, LiDAR, IMU, and GPS) to capture high-quality spatial data, which can then be processed into accurate 3D models using photogrammetry.
Requirements
  • A mobile device compatible with PIX4Dcatch. See the list of compatible devices here.
  • The PIX4Dcatch application.
  • A valid license.
  • An internet connection.
Follow the next steps to get started:
1. Download and install PIX4Dcatch
To download the latest version of PIX4Dcatch, visit the Apple Store
For more information on downloading and installing click here.
2. Log in
It is necessary to have a valid license or obtain a trial license to log into PIX4Dcatch.
For information about the trial license, click here and for detailed instructions on logging in, click here.
3. PIX4Dcatch Overview
To navigate and understand the PIX4Dcatch layout, click here.
4. Capture a project
To capture a project using the device's built-in GPS location,  select Integrated GPS Sensor. Note that the accuracy of this method is typically within a few meters. For more information on how to capture a project, click here.
Recommended Capture Practices:
  • Maintain a slow and steady pace.
  • Tilt the device to ensure all surface details are captured.
  • Avoid capturing in low-light environments.
  • Avoid retracing identical paths.
5. Process the images
Once the project is saved, the images can be processed in PIX4Dcloud or exported for local processing with PIX4Dmatic Standard or PIX4Dmatic Pro.
PIX4Dcloud
Use the upload button Upload to upload your project for fast, shareable 3D reconstruction. For more information on how to process, click here.
Important: A PIX4Dcloud license is required. For more information on license types, click here.
PIX4Dmatic
PIX4Dmatic Standard or PIX4Dmatic Pro allows local processing of PIX4Dcatch projects.
Important: A PIX4Dmatic license is required for processing locally PIX4Dcatch projects, momre information here.
How to process in PIX4Dmatic
  1. Tap the Export  icon and select Export All Data - PIX4Dmatic (OPF). For more information, click Using OPF from PIX4Dcatch to PIX4Dmatic
  2. Double-click on the project.opf file.
  3. PIX4Dmatic will launch automatically, displaying the project name and file path.
  4. Click Start.
Professional Features
Users with a PIX4Dcatch Professional License gain access to the following premium features:
