Content, Settings, navigation and control panels - PIX4Dmatic
PIX4Dmatic enables users to navigate the project area and outputs in both 2D and 3D, while also working with the original images
Content Panel
Click layers to open the Content Panel:
matic_2.6-1
The content panel is dynamic and contains all the elements of the project according to the current status. All elements can be made visible/invisible by clicking on the visibility. Additionally, some elements have different settings Setting options.
settings Description
Input cameras Input accuracies: Visually represent the accuracy values of each image position listed in the Cameras table. The size factor slider adjusts the visual scale of these accuracies, making small or large differences discernible, without affecting the actual processing values shown in the Cameras table. Changing the accuracy values in the Cameras table will affect the results of the ellipsoids
Gaussian splats
  • Realistic reflections
  • Export
  • Delele
Point clouds
Depth point cloud, Dense point cloud and Depth & dense point cloud
  • Point size: change the size of the points in the point cloud.
  • Select all: Selects all points in the dense point cloud.
  • Export: Export the point cloud in different formats.
  • Delete: Deletes the dense point cloud.
Classification
  • Terrain classes
  • ASPRS classes
Disabled points
  •  All points / Disabled points
  • Restore disabled points
Mesh
  • Shaded/Textured: Sets the visual option for the Mesh
Digital Terrain Model DTM
  • Sets the desired spectrum of the relative confidence map:
    • By adjusting the toggles.
    • By setting the interval values.
  • Opacity: Sets the opacity percentage for the DSM in the 2D view.
  • Shading mode: Three visualization modes: Color map, Hillshading (Greyscale), and Combined.
  • Z factor: vertical exaggeration slider to control shading intensity.
  • Export.
Digital Surface Model DSM
  • Export.
Orthomosaic
  • Rename: change the name of the orthomosaic.
  • Apply all patches: Patches created to edit the orthomosaic.
  • Show all patch borders: To show all the patches.
  • Export
Region of Interest ROI
  • Export.
  • Delete: Deletes the region of interest.
2D Basemap
  • Map/Satellite: Sets the basemap in the 2D view
Layers
addAdd new layer
list Layer template window
more_verticalSorts layer by:
  • Creation date
  • Alphabetical order
  • Geometry count
more_verticalExports layers as:
  • DXF
  • DXF (For Autodesk
  • ZIP SHP
  • SHP
  • GeoJSON
  • CSV
more_verticalRemove empty layers
more_verticalCompute all outdated volumes
Tip: If a setting or input is modified within a project, an orange dot will appear in the content panel beside any processing steps that are now outdated due to this change. This visual cue helps to quickly identify and update any steps affected by the recent modifications. The Outdated message will also appear in the Quality Report if it's exported after the modifications.
Indication of outdated step in PIX4Dmatic
Settings
Click tune.png to open the Settings dialog:
settings_2.4.0
  Default Range Description
Size
Camera size
1 0.01 - 5.00 Changes the size of the camera thumbnails.
Tie point size 1 0.10 - 2.00 Changes the size of the tie points.
Marker size 1 0.10 - 2.00 Changes the size of the markers.
Mask size 1 0.10 - 2.00 Change the size of the mask marker.
Point size
 13
 0.5 - 200 Changes the size of the points in the point cloud.
Labels
Marker labels On On/Off Enables the labels for Markers.
Mask labels On On/Off Enables the labels for Masks.
Contour line labels On On/Off Enables the labels for contour lines.
Point cloud
Color by elevation
Off
Min. elevation - Max. elevation Changes the range of the elevation map in the point cloud.
Color by relative confidence Off 0 - 1.00 Changes the range of the relative confidence map in the point cloud.
Color by normal Off On/Off Colorization based on the X, Y, Z components of the point normals.
Color by GPS time Off On/Off Applies a rainbow gradient to the point cloud based on the GPS time.
Minimum number of matches 3 2 - 6 Select the point based on the number of matches.
Volumes
Color scheme Binary Binary/Gradient Select the color scheme for volume visualization.
Viewing options
Face orientation Off On/Off Shows the face orientation of the polygons.
Clipping box Off  On/Off Enables the clipping box tool.
Axes On On/Off Shows the axes X, Y, Z
Snapping window Off  On/Off Indicates the depth of the objects being snapped to.
Distortion-aware measurements On On/Off Enables the Distortion-aware measurements feature.
Backface culling Off  On/Off Allows backward transparency of 3D mesh.
Object occlusion* 3 0 - 25.0 Display geometries above the 3D mesh.
View Perspective Perspective/
Orthographic
Changes the view in the 3D viewer.
Viewport layouts Single view Perspective/
Orthographic
View the scene from various angles simultaneously.
Background
Sky background On On/Off Toggles on/off the sky background.
Background color Black Black/Grey/White Changes the background color.
*Object occlusion:
Lower value
object2_1.78
Higher value
object_1.78
Navigate in the 3D view
It is possible to view the sparse point cloud, dense point cloud, images, and tie points in the 3D view.
Access: To access the 3D view:
  • In the menu bar, click View > Switch to 3D, or
  • Click the 3D button on the screen Pix4Dmatic 3D view icon, or
  • Use shortcut 3.
To pan, rotate, and zoom the 3D view:
  • Left-click to pan the 3D view.
  • Hold Shift and left-click to pan the 3D view on the z-axis.
  • Right-click to rotate the 3D view.
  • Use the scroll wheel to zoom in and out in the 3D view.
  • Use Focus on selection focus_on_selection to focus on selection.
To access the predefined views, go to View on the Menu bar and click:
  • View all to zoom out the scene to the whole extent.
  • Focus on selection to zoom on the selected object.
  • Top View to view the scene from the top. The scene is zoomed out to display the entire scene.
Tip: It is also possible to use shortcuts to view the scene in predefined views.
Navigate in the 2D view
It is possible to view the Orthomosaic and DSM in the 2D view with or without a basemap.
Access: To access the 2D view:
  • In the menu bar, click View > Switch to 2D, or
  • Click the 2D button on the screen Pix4Dmatic 2D view icon, or
  • Use shortcut 2.
Since version 1.74 and newer, there is a context menu in 2D view for 3D objects with the same options as we selected the same 3D object in 3D view.
Navigate through the images
Imported images are displayed in 3D and the Image Viewer.
Important: To change the display of an individual image:
  • Left-click and drag to pan on the image.
  • Hold Ctrl and rotate the scroll wheel to zoom in and out of the image.
To change the general display of images:
  • [1] Change the number of displayed columns.
  • [2] Use the zoom slider to change the zoom level of all images, or use Alt+Scroll. Once in the full-screen mode (Ctrl+F), Ctrl+1 (minimum zoom) and Ctrl+2 (maximum zoom) are enabled.
  • [3] Filter images and display All, Calibrated, or Uncalibrated images.
  • [4] Sort images and display by Distance, Reprojection error or Name.
    • Distance: The default option is to sort images by the distance of the image to the marked point.
    • Reprojection error: After marking a point in two different images, the reprojection error is calculated. Hence, the advantage is to sort the highest errors first.
    • Name: Images are sorted based on the name of the image. It helps to detect images with similar content, as the image name typically follows a chronological order and shows neighboring images.
  • [5] Import images to import additional images to the current project.
  • [6] Maximize image viewer to display the image viewer in full screen, or use the Ctrl+F shortcut.
  • [7] Enlarge image to display an image on full screen.
  • [8] Hide all reprojection marks
  • [9] Show/hide image names
  • [10] Filter images in the image viewer by camera sensor name. If the dataset contains images from more than 1 sensor, it is possible to filter the images by sensor
    images_2.9
Tip: After the Calibration step is completed, images displayed in the Image panel have an additional icon:
  • Pix4Dmatic green check for calibrated images.
  • Pix4Dmatic warning icon for uncalibrated images.
Layout
The PIX4Dmatic interface layout can be customized and saved to match specific configuration preferences.
 layout_2.2
Find images
If images have been moved, deleted, or their storage path has changed, a notification will appear in the image viewer to help locate them. To reconnect the images:
  • Right-click anywhere in the image viewer
  • Select Find Images
  • Navigate to the folder or location of the images
  • Click OK
This action updates the image paths, restoring their access within the project.
PIX4Dmatic find images...
Control panels
 Control panels can be accessed on the menu bar View > Control panels.
The following panels are available:
  • layers.png Content: gives an overview of available inputs and results.
  • tune Settings. Display the settings of the project.
  • processing_options.png Processing: it allows users to change the processing options.
  • report_panel.pngQuality report: displays an overview of the project and assesses its accuracy and quality.
  • history.png History: displays a list of performed actions.
  • Pix4Dmatic_image_viewer.jpg Image viewer: displays imported images.
  • attributesProperties. Shows the properties of the element selected.
  • Pix4Dmatic_status_center_icon.jpg Status center: provides information on the actions and details of processing.
  • gcp.png Tie points: opens the Tie points table.
  • camera-1Cameras. Information related to the position, orientation, and accuracy of each image.
  • elevation_profile-16Section view
  • videoVideos & views
