Section view - PIX4Dmatic
The Section View feature enables accurate vertical and horizontal project sections, ensuring vectorization on a single plane. The section view gives access to the creation of an orthoplane with PIX4Dmatic.
section_1.79
Section view in PIX4Dmatic.
Note: This feature is available from PIX4Dmatic version 1.63 and above
Access
To access the Section view:
  • From the toolbar on 3D view:
    • Vertical section section_vertical-16
    • Horizontal section section_horizontal-16
    • Section from polyline section_polyline-16
    • Section from planar polygon section_polygon-16
How to create a section
section_view_1.79
There are three methods available (in 3D view), depending on the use case:
  • Draw Section (vertical and horizontal section): A line is drawn to indicate the desired location.
  • Section from polyline: A polyline is selected to serve as a guide for multiple sections. This method is primarily used in terrain and road workflows, where a polyline (e.g., the axis of a road) is selected to maintain sectioning over an extended distance.
    Tip: To create multiple parallel sections, define an interval at the top of the panel and use the < > arrows to step through the sections.
    • Section form planar polygon. A section box is created with the same size and orientation as the polygon, regardless of the positions of the vertices. The polygon has to be a planar geometry.
    Note: To know the orientation of the polygon, Face orientation must be enabled. This option is found in Settings > Viewing options.
    Adjusting the section box
    The section box defines the visible area in the bottom panel. The half-transparent face represents the section plane, which faces the interior of the box. Ensure the plane is oriented towards the region intended for vectorization.
    To adjust the section box, there are two options:
    • From the 3D view: Provides a quick and rough box adjustment.
    • From the bottom panel: Allows for precise adjustments of the box's height, width, depth and rotation on the X, Y, and Z axes. The depth determines the visible area in the bottom panel, and this method offers greater control over rotation angles.
    To adjust the section plane:
    section2_1.79
    • Use the mouse scroll wheel or pinch zoom on the trackpad to zoom into the section.
      Click and drag with the mouse cursor to pan within the section.
    • To hide/display the grid, click enable or disable the Display grid background_grid button. The grid in the section can be used to have an estimation of the scale. There are major and minor lines. The distance between the lines can be seen in the bottom right corner. This value is automatically updated when zooming in or out.
    • To snap the section plane to the point cloud, click on the Snap to point cloud sanp_point_cloud button
    • Invert section direction icon swap-1 in the bottom panel.
    • To rotate the section between horizontal and vertical, click on the Rotate section 90° rotate_90 button.
    • To reset the view, click on the Reset view button Reset View Button. This will reset the section view focusing on the profile box.
    • For more information, click on the Info button info-outline.
    Note: To determine the orientation of the section box, an orientation arrow is displayed, indicating the direction in which the box is facing.
    Captura de pantalla 2025-05-21 122105
    Vectorize
    After creating the section box, the next step is to vectorize it manually or by using the Draping function.
    The Draping function automatically locates the best-fitting polyline for the terrain and applies this polyline to both the Section view and the 3D view.
    To use this feature:
    • Select a section box from the 3D view
    • Navigate to Draping
    • Click on Drape in section
    A polyline will automatically be created in the section view and the 3D view. When using Drape in section, adjust the polyline's complexity once it is visible in the scene.
    Each section is listed in the Content panel under "Sections," aiding in navigation, toggling, deletion, and export selection.
    Geometries (i.e. polylines) are stored in the vector layers along with other elements. All geometries created, manually or via the Drape in section function, are constrained to the section plane and can only be edited in the Section View bottom panel. Geometries cannot be moved out of the section plane. To break this link:
    • Delete the section from the Content Panel, which will then enable the geometries or
    • Right-click the geometry in the Section view panel and select Detach [geometry] from section
      PIX4Dmatic_detach_geometry
    Tip: For sections created from a polyline (select polyline), offset the section box by the desired amount, place it in the preferred location, or fill in the information in the pop-up and confirm.
    Orthoplane_Draping
    Orthoplane
    The Orthoplane feature generates orthomosaics for vertical and horizontal surfaces, such as building facades or floor plans.  It provides accurate, scaled 2D representations. Orthoplane is ideal for architectural surveys, inspections, and preservation projects, offering precise measurements and detailed visual information without distortion. It integrates seamlessly with existing georeferencing and photogrammetry techniques to ensure accurate mapping of vertical structures. For more information on how to use this tool: How to create an orthoplane - PIX4Dmatic.
    Note: The Orthoplane feature is available for PIX4Dmatic version 1.66 or newer.
    Export
    After creating the Section view and modifying the settings, click on Export to export the Section view to the location identified in the Destination setting. The status bar will be updated with the progress of the export.
    After the export is complete, a .dxf file will be created in the desired location for further use. The .dxf file will contain the polyline(s) created within each Section view.
