What is PIX4Dinspect?
How do I obtain a license for PIX4Dinspect?
Is PIX4Dinspect available for desktop?
Which internet browsers and operating systems support PIX4Dinspect?
In which languages is PIX4Dinspect available?
Is my data secure?
Where are my datasets processed and stored?
I am using a proxy/a firewall. How should I configure them?
What are the inputs/outputs of PIX4Dinspect?
Which cameras are compatible with PIX4Dinspect?
Can images without geolocation be processed in PIX4Dinspect?
How many projects can I create?
What happens if I am not satisfied with the results?
How many images can I process using PIX4Dinspect?
Does PIX4Dinspect include 2D and 3D visualization?
How can I change the unit of measurements?
Does PIX4Dinspect generate a report?
What happens to my projects when my license expires?
What is the price of PIX4Dinspect?
How can I get technical support for PIX4Dinspect?
PIX4Dinspect is a cloud-based software generating 2D maps and 3D models and offering visual inspection and asset management capabilities for professionals in the infrastructure sector. It includes new artificial intelligence-based capabilities to detect potential failures in infrastructure, along with specific tower inspection tools.
PIX4Dinspect is a discontinued product, so you can not get a trial or a license.
We encourage you to try PIX4Dcloud.
PIX4Dinspect is a Cloud-only platform.
The following browsers can be used to work with PIX4Dinspect on Windows 10+ and MacOS:
- Chrome (latest version)
- Firefox (latest version)
- Microsoft Edge (latest version)
- Safari (latest version)
PIX4Dinspect is available in English, French, German, Italian, Japanese, Portuguese, and Spanish. To change the language:
- On the top right, click the user icon and select Language.
- Select the desired language.
Is my data secure?
Pix4D cares about your privacy and does not claim any ownership of your data. Find more information in our Terms of Use.
A cluster of servers is assigned to each account for processing and storage. This cluster can be changed in the Account Settings. More information in Where are my datasets processed and stored.
I am using a proxy, a firewall. How should I configure them?
If a proxy server is used or a firewall exists, some exceptions should be added. Read more at Proxy/firewall configuration - PIX4Dinspect
Using PIX4Dinspect, you can import RGB images (.jpg, .jpeg) or videos from Parrot Anafi (.mp4). More information in: Inputs. PIX4Dinspect outputs include a 3D Model, Elevation map, Image map, and reports. For more information: Outputs.
PIX4Dinspect supports geolocated JPEG images from the most popular DJI drones and drone manufacturers' cameras providing the recommended XMP tags (for position and orientation).
It is not possible to process images without geolocation in PIX4Dinspect.
The number of projects that can be created depends on the purchased license.
In case of bad quality results for a project, you are allowed to upload a new dataset under the same asset for maximum other two times during a 15-days interval after the first upload. In this case, the total uploads (maximum 3 per project) will count as just 1 consumed project.
There is no limitation regarding the number of images to process. However, for an optimal experience with our servers, and for technical limitations, the maximum number of images that can be processed per project is 4000. Keep in mind that we expect our users to respect our fair usage policy.
What is PIX4Dinspect fair usage policy?
According to our fair usage policy, the average on a yearly basis of all the uploaded projects must not exceed 15 PGPs.
PGPs = number of images * image resolution [MP] / 1000
For example: 750 images of 20MP = 15 PGP.
Yes, the project's process can be a combination of 2D, 3D and image viewers. For more information: 2D/3D view and Image annotations.
Web measurements calculated on the results are displayed in metric or imperial units. To change the unit system:
- On the top right, click the user icon and select Account settings.
- In the panel Solution preference, select the measurement unit.
Yes, PIX4Dinspect is able to generate a report, which includes the information derived from the Image annotations and the Antenna tool.
Once a license expires, the projects are kept on our servers and can still be accessed before their deletion according to our Retention policy.
Without a valid PIX4Dinspect license, the projects can still be accessed to create manually added inventory items, measurements, and annotations. Such changes will be saved automatically, but the PDF report can not be regenerated, and it is not possible to create new projects unless a new license is purchased.
For information about PIX4Dinspect’s pricing, contact our sales team here. Data storage is included in the first year of subscription. Contact our Sales team for additional storage options.
For technical questions about our products contact our support team.
