Outputs - PIX4Dinspect
 Previous  |  Next
The outputs of the PIX4Dinspect project consist of Intelligent Digital twin, post-processing results, such as reports, and measurements and images.
3D Model
Extension Description
.las 3D Model file. (For Cell Tower assets) The downloaded 3D Model is the clipped 3D Model if the clipping radius was specified in the Options while creating the new project.
Textured 3D Model
.obj Textured 3D Model file. This output is available for all the asset types except Cell towers and Transmission towers.
Elevation map
.tif Elevation map file.
Image map
.tif Image map file.
Note: The output coordinate system of the output results, annotation, and report are in WGS84.
Post-processing results
Reports
.json Json file containing information about the process.
.pdf Pdf report.
More information on reports in Reports.
Outputs can be exported on a local device. More information on how to export outputs in: Export.
Measurements and Inputs
Measurements
.dxf  DXF file containing information about the measurements.
  • Drawing exchange format (DXF) enables vector data exchange and 2D/3D graphics drawing.
  • The files will be exported in the user's project coordinate system.
  • Export All measurements or Only visible measurements
Inputs
.zip Zip file containing all the project's images.
1 out of 2 found this helpful
