How to import and mark Ground Control Points (GCPs) - PIX4Dcatch
This article provides step-by-step instructions for importing and marking ground control points (GCPs) in PIX4Dcatch. PIX4Dcatch supports collecting, importing, and marking GCPs.
Point Collection
A ground control point (GCP) is a point with known coordinates. Their coordinates have been measured using reliable surveying methods or obtained from other sources (LiDAR, older area maps, Web Map Service). GCPs are used to georeference a project. For more information about Point Collections, click here.
Measure GCPs
GCPs can be measured using PIX4Dcatch when paired with a supported RTK device.
Tip: Take reference images and add descriptions when measuring your GCPs. This detail will make it much easier to mark the correct points in the images later.
Import GCPs to PIX4Dcatch
PIX4Dcatch allows users to importing existing GCPs and creating or updating a Point Collection.
Important: If importing to an existing collection, it must use the same coordinate reference system
 Here's the instruction on importing GCPs to an existing point collection
  1. On the PIX4Dcatch home screen, tap Survey at the bottom.
    PIX4Dcatch menu box survey
  2. Select the desired Point Collection.
    PIX4Dcatch Survey point collection folders
  3. Tap the tree dots icon 9910856599453-2 in the top right and select Import.
    PIX4Dcatch import points to point collection
  4. Select the file to be imported.
    PIX4Dcatch import points to point collection select file
Here's the instruction on importing GCPs as a Point Collection:
  2. Tap + New at the bottom.
  3. Fill in the name and select Import Coordinate System.
    importar
  4. Tap Import file and select the file.
  5. Tap Create in the top-right corner.
    createeee
Mark GCPs in a PIX4Dcatch project
To mark GCPs in a project, the Point Collection must first be assigned to the project. Then, the GCPs must be manually marked on the corresponding images. For more information: How to use automatic Tag Detection and manual GCP marking - PIX4Dcatch RTK.
Processing project with GCPs
Once GCPs are marked on the images, the project can be processed to improve accuracy. For more information: Processing projects - PIX4Dcatch.
