Tie points (GCPs, CPs) import format - PIX4Dmatic
Tie points, including Ground Control Points (GCPs) and Checkpoints, can be imported using a .csv or .txt file. Each line contains either four or six columns, separated by commas (,). The supported tie point formats are detailed in the table below:
Note: The order of coordinates in the input file must match the order of axes in the coordinate system definition chosen in the import dialog.
For example, if the coordinate system definition specifies the first axis is X and the second is Y, the GCP input file must follow the same order.
For more information: How to check the order of the axes in the coordinate system definition section.
GCPs in geographic coordinates
GCPs in geographic coordinates with accuracy values
GCPs in projected coordinates
GCPs in projected coordinates with accuracy values
To check the order of axes in the coordinate system definition:
- Open the EPSG Geodetic Parameter Registry website.
- Write the name or the EPSG code in the EPSG Dataset - Text search.
- Click GO and select the correct name in the results..
- Expand the COORDINATE SYSTEM section and check the order in the AXES subsection.
After checking the order of the axes in the coordinate system definition, modify the input file to follow the same order of coordinates.
Example: For the WGS 84 / UTM zone 32N (EPSG code 32632) the order of axes in the coordinate system definition is first Easting and second Northing. The GCPs file should be formatted as:
label, Easting [meter], Northing [meter], z [meter]
