Index > Interface > Menu Process | Previous | Next |
This PIX4Dmapper article aims at clarifying when and how the process of reoptimizing the internal and external camera parameters should be used.
This process reoptimizes the internal and external camera parameters. It should be used when changes have been applied to the project after step 1. Initial Processing has been completed. Such changes can be:
- Adding GCPs.
- Adding Manual Tie points.
- Adding Check points.
- Changing coordinate systems.
- Disable images.
