Supported drones and cameras
Pix4D develops both image acquisition apps, which allow one to perform drone and terrestrial captures, and photogrammetry software that transforms images into 2D and 3D outputs for different applications and use cases.
All Pix4D software, such as PIX4Dmatic, PIX4Dcloud, PIX4Dmapper, and PIX4Dfields, is drone agnostic, meaning it can process images from almost any drone or camera provided they are of high quality and have sufficient overlap.
This article describes if and how Pix4D apps and software are compatible and support different drones, cameras, and devices. This is not the complete list of the drones that are supported.
Supported drones
| Drone | Processing | ||||
PIX4D |
PIX4D |
PIX4D |
PIX4D |
PIX4D |
| Inspire 1/2 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic Air | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic Air 2 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Air 2S | ✓ | ✓ | ✓ | ✓ | ✓ |
| Air 3 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic Mini/Mini 2 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mini 3 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mini 3 Pro | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mini 4 Pro | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic Pro | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic 2 Pro | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic 2 Zoom | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic 2E Dual | ✓ | RGB | RGB | RGB | RGB |
| Mavic 2E Adv. | ✓ | RGB | RGB | RGB | RGB |
| Mavic 3 Pro/ Classic | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic 3M | ✓ | RGB | ✓ | RGB | RGB |
| Mavic 3E | ✓ | ✓ | ✓ | ✓ | ✓ |
| Mavic 3T | ✓ | RGB | ✓ | ✓ | ✓ |
| Phantom 3/Adv. | ✓ | ✓ | ✓ | ✓ | ✓ |
Phantom 3 Pro |
Phantom 4/Pro/Pro V2 |
| Phantom 4 RTK | ✓ | ✓ | ✓ | ✓ | ✓ |
| Phantom 4 M | ✓ | ✓ | |||
| Spark | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 100 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 200/ 200 V2 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 210/210 RTK | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 210 V2 /210 V2 RTK | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 300 RTK | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 30T | RGB | RGB | RGB | RGB | RGB |
| Matrice 600 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Matrice 4/4T | RGB | RGB | RGB | RGB | RGB |
| Anafi / AI | ✓ | ✓ | ✓ | ✓ | ✓ |
| Anafi USA | ✓ | ✓ | ✓ | ✓ | ✓ |
| Anafi Thermal | ✓ | RGB | RGB | RGB | RGB |
| Yuneec | ✓ | ✓ | ✓ | ✓ | ✓ |
| AgEagle eBee series | ✓ | ✓ | ✓ | ✓ | ✓ |
| Albris | ✓ | ✓ | ✓ | ✓ | ✓ |
| Sentera | ✓ | ✓ | |||
| AeroVironment Quantix | ✓ | ✓ | ✓ | ✓ | ✓ |
| Autel Evo I | ✓ | ✓ | ✓ | ✓ | ✓ |
| Autel Evo II 8K | ✓ | ✓ | ✓ | ✓ | ✓ |
| Autel Evo II Pro 6K | ✓ | ✓ | ✓ | ✓ | ✓ |
| Autel Evo II V3/Dual/Enterprise | ✓ | ✓ | ✓ | ✓ | ✓ |
| Skydio 2 / 2+ | ✓ | ✓ | ✓ | ✓ | ✓ |
| Skydio X2/X10 | ✓ | ✓ | RGB | RGB | RGB |
| Wingtra | ✓ | ✓ | ✓ | ✓ | ✓ |
| Delair UX11 | ✓ | ✓ | ✓ | ✓ | ✓ |
| ACSL Soten | ✓ | ✓ | ✓ | ✓ | ✓ |
| MAPIR | ✓ | ✓ | ✓ | ✓ | ✓ |
| XAG M500 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Freefly | ✓ | ✓ | ✓ | ✓ | ✓ |
Supported cameras
| Camera | Processing software | ||||
| PIX4Dmapper | PIX4Dmatic | PIX4Dfields | PIX4Dreact | PIX4Dcloud | |
| Any camera | ✓ | ** | *** | **** | ° |
| Agrowing | ✓ | ✓ | ° | ||
| Zenmuse X3 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Zenmuse X4S | ✓ | ✓ | ✓ | ✓ | ✓ |
| Zenmuse X5/X5R | ✓ | ✓ | ✓ | ✓ | ✓ |
| Zenmuse X5S | ✓ | ✓ | ✓ | ✓ | ✓ |
| Zenmuse X7 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Zenmuse XT/XT2 | ✓ | ° | |||
| Zenmuse H20T | ✓ | RGB | RGB | RGB | RGB |
| Zenmuse P1 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Yuneec E90 | ✓ | ✓ | ✓ | ✓ | ✓ |
| S.O.D.A. series | ✓ | ✓ | ✓ | ✓ | ✓ |
| Aeria X | ✓ | ✓ | ✓ | ✓ | ✓ |
| S110 RGB/NIR/RE | ✓ | ✓ | ✓ | ° | |
| Sequoia / Sequoia+ | ✓ | ✓ | ° | ||
| Altum /PT | ✓ | ✓ | ° | ||
| RedEdge /P/M/MX | ✓ | ✓ | ° | ||
| SlantRange-3P | ✓ | ✓ | ° | ||
| Sentera 6X | ✓ | ✓ | ° | ||
| Sentera 65R | ✓ | ✓ | ✓ | ✓ | ° |
| La Quinta DB2-Vision | ✓ | ✓ | ° | ||
| Sony Alpha 7R IV | ✓ | ✓ | ✓ | ✓ | ✓ |
| Sony Alpha ILX-LR1 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Sony Cyber-shot DSC-RX1RM2 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Sony Cyber-shot DSC-WX220 | ✓ | ✓ | ✓ | ✓ | ✓ |
| Sony UMC-R10C | ✓ | ✓ | ✓ | ✓ | ✓ |
| Sony | ✓ | ✓ | ✓ | ✓ | ✓ |
| Canon | ✓ | ✓ | ✓ | ✓ | ✓ |
| Nikon | ✓ | ✓ | ✓ | ✓ | ✓ |
| Delair | ✓ | ✓ | ✓ | ✓ | ✓ |
| Hasselblad | ✓ | ✓ | ✓ | ✓ | ✓ |
| Olympus | ✓ | ✓ | ✓ | ✓ | ✓ |
| Panasonic | ✓ | ✓ | ✓ | ✓ | ✓ |
| Pentax | ✓ | ✓ | ✓ | ✓ | ✓ |
| Pioneer | ✓ | ✓ | ✓ | ✓ | ✓ |
| Ricoh | ✓ | ✓ | ✓ | ✓ | ✓ |
| Tetracam | ✓ | ✓ | ✓ | ✓ | ✓ |
| Fujifilm GFX100S II | ✓ | ✓ | |||
| Fujifilm | ✓ | ✓ | ✓ | ✓ | ✓ |
| GoPro cameras | ✓ | ✓ | ✓ | ✓ | |
| Other brands | ✓ | ✓ | ✓ | ✓ | ✓ |
* PIX4Dmapper has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal) that includes the required metadata. For cameras that do not exist in PIX4Dmapper's camera database, the optimal internal camera parameters can be computed in the software while processing a good dataset. For more information:
Requests to add new camera models to the database can be sent to Technical Support.
** PIX4Dmatic has an internal camera database with precalibrated models but can process images from any camera model (RGB) as long as the images contain the necessary EXIF/XMP (metadata) tags. Requests to add new camera models to the database can be sent to Technical Support.
*** PIX4Dfields has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal) that includes the required metadata.
If your camera is not listed, you can still process images using PIX4Dfields. With the release of version 2.9 and later, PIX4Dfields can handle images from unsupported cameras by utilizing the internal image metadata.
For users of PIX4Dfields version 2.8.5 or earlier, processing is still possible for drone images not included on the list, but you will need to follow the instructions provided in: Your camera is not supported at this time - PIX4Dfields
**** PIX4Dreact has an extensive internal camera database but can process nadir images from any camera model (RGB) that includes the required metadata.
For camera models and resolutions that don't exist in the PIX4Dreact's database, it is still possible to process a dataset if a file with the internal camera parameters is provided. For more information: Your camera is not supported at this time - PIX4Dreact. Requests to add new camera models to the database can be sent to Technical Support.
° PIX4Dcloud has an internal camera database but can process images from any RGB camera that includes the required metadata. Currently, it also supports thermal and multispectral images when uploaded through PIX4Dmapper. For more information visit, What are the processing options - PIX4Dcloud.
⚠️ Important Notice: After February 28, 2026, PIX4Dcloud will no longer support the processing of multispectral or thermal images, even if uploaded via PIX4Dmapper. For more information visit Decommissioning Notice: PIX4Dmapper Legacy Processing Pipeline in Cloud Products
