Capture a project - PIX4Dcatch
Capture a project
PIX4Dcatch allows scanning and recording video frames with positional and orientation information. It is possible to obtain an accurate mapping and complete 3D models.
Note: The maximum number of images per project that can be processed in PIX4Dcloud is 4000.
In PIX4Dcatch, there are two ways to georeference the images:
  • Standard georeferencing with meter level of accuracy using the integrated GNSS/GPS sensor in the device.
  • RTK georeferencing with an external RTK device for centimeter-level accuracy. For more information: How to use PIX4Dcatch a supported RTK device.
How to capture a project
Before starting the capture process, a capture route must be planned to ensure optimal results, which is based on the subject’s size and geometry. It is recommended to use circular and/or linear capture paths. For larger subjects, utilize multiple parallel paths (horizontal or vertical), ensuring adequate overlap between them.
Follow the next steps to capture a project:
  1. Tap the record button record icon and begin moving the device slowly. The app will automatically start capturing images according to the selected settings.
    record screen
               OS and Android devices with LiDAR or ToF sensors can use the Live Preview feature eye icon to                 gain insight into what is being captured.
          2. If necessary, tap the pause button pausa icon to pause the recording. Tap the record button to                        resume recording.
            capture screen
 Important: Use the pause button only when absolutely necessary. To ensure accuracy,     remain in a static location and limit pauses to under 20 seconds.
          3. Tap the save button play icon upon capture completion. The cancel button cancel icon may be used to                 abort a project while capturing.
          4. A capture report will be displayed for quality assurance review. The 3D tab shows the 3D                 view and in the Report tab shows information about the quality of the capture.
         tabs view
             The 3D tab displays the following information:
  • Project Name.
  • center button Tap to center the project.
  • layer button Tap to access:
    • cameras button Toggle the camera positions visibility.
    • pointcloud button Toggle Sparse point cloud. Available for devices with a TOF and/or LiDAR sensor. Tie points will be displayed for devices without these sensors.
    • close button Close the menu.
    The Report tab displays the quality of the capture before saving the project. For more information, click here.
        5. Tap Save to store the completed project locally on the device, making it available for later                   processing.
             save-2
    Best practices
    Illustration showing better practices when capturing
    • Fill the image frame with the content you wish to reconstruct:
      • Employ a slight downward tilt.
      • Point the camera to capture both near and far objects.
      • Avoid moving objects, including the shadow of the operator.
      • Capture rich textures in good lighting.
    • Move and turn slowly:
      • Do not change the orientation of the camera while standing still. e.g., turn in place.
      • Avoid sudden perspective changes or rapid, jerky motions.
      • Try to maintain a consistent distance between the camera and what it captures.
      • Plan for smooth transitions around corners.
      • It is better to raise or lower the camera height when trying to capture further detail in higher or lower regions than it is to point the camera up/down from the same height.
    • Plan:
      • Identify areas that may have limited visibility due to scene geometry.
      • Plan the image collection with consideration of lighting.
      • Consider potential locations for Autotags.
      • Distribute accordingly.
      • In difficult terrain, a practice run can be particularly helpful.
    • Try to avoid:
      • Low-light scenes. If a scene must be scanned in poor lighting, try to move slowly or use artificial light while avoiding shadows.
      • Pointing the camera in the exact direction of travel/ahead.
        • Face the camera at an angle from the direction of travel.
      • Try not to travel back exactly over the same path.
        • Change the elevation and path slightly whenever necessary to double over a previously captured region.
    • Ensure stable internet:
      • Use WiFi only if the scene has full coverage and the connection is stable.
      • Turning WiFi off is a good idea, as it may interfere with a mobile data (4G) connection, even if the WiFi signal is weak. Projects with mixed WiFi and mobile connections may fail.
    Tip: To use automatic Tag Detection during capturing, please import the Point Collection before capturing. For more information: How to use automatic Tag Detection and manual GCP marking - PIX4Dcatch RTK
    Useful information
    How to process a project in PIX4Dcatch.
    How to export a project to save or process locally  .
