Getting started
Inputs - PIX4Dmatic
This article lists all the available input files supported by PIX4Dmatic, including their formats and descriptions.
PIX4Dmatic's main inputs are images and text files with ground control point coordinates.
Images
PIX4Dmatic is based on image processing and is optimized for large-scale, corridor, and terrestrial projects.
Extension Description
.jpg, .jpeg JPEG images
.tiff, .tif TIFF images and depth maps
For more information about the supported cameras see: Which cameras are supported in PIX4Dmatic.
Region of interest (ROI)
PIX4Dmatic allows importing a defined area using .kml files, ensuring precise geographic coordinates for improved alignment and reconstruction of 3D models.
.kml A standard format file for storing geographic data, often used for representing points, lines, polygons, and other features in photogrammetry applications.
Image geolocation and orientation
The import of image geolocation and orientation is useful when the values are not available in the EXIF/Xmp tags or when using PPK workflows for better results.
.csv, .txt A text file containing seven or nine columns per line and a comma (,) to separate the values
  • Seven columns: ID, coordinates, Yaw, Pitch, Roll
  • Nine columns: ID, coordinates, Yaw, Pitch, Roll, Accuracy Horz, Accuracy Vert
For more information and all formats see Image geolocation and orientation import format articles.
Example: Image geolocation in geographic coordinates, Yaw, Pitch, Roll:
imagename, coordinate1 [decimal degrees], coordinate2 [decimal degrees], z [meter], yaw [decimal degrees], pitch [decimal degrees], roll [decimal degrees]
IMG_3165.JPG,46.2345612,6.5611445,539.931,38.6,3.5,8.3
IMG_3166.JPG,46.2323423,6.5623423,529.823,44.1,3.4,5.4
Ground Control Points (GCPs) file
Ground Control Points (GCPs) are used for precisely georeferencing the project.
.csv, .txt A text file containing four or six columns per line and a comma (,) to separate the values.
  • Four columns: ID and coordinates
  • Six columns: ID, coordinates, Accuracy Horz, and Accuracy Vert
For more information and all formats please see the GCPs import format article.
Example: GCPs in projected coordinates with accuracy values:
label,X [units],Y [units],z [units],Accuracy Horz [units],Accuracy Vert [units]
GCP0,2532795.105,1152094.639,395.883,0.02,0.02
GCP1,2532728.805,1152079.825,396.619,0.02,0.02
GCPs marks file
GCPs marks can be imported if they were previously marked and exported in a PIX4Dmapper or PIX4Dmatic project.
.csv, .txt
A text file containing positions of marks on individual images.
For more information please see the How to import GCP marks from PIX4Dmapper into PIX4Dmatic article.
Processing templates
Custom processing templates can be imported if they were previously saved and exported from a PIX4Dmatic project.
.json A file containing a custom processing template including the Title and a Description (Optional)
For more information: Custom processing templates - PIX4Dmatic
