AutoGCPs detection functionality - PIX4Dcloud Pro
The AutoGCPs detection functionality in PIX4Dcloud Pro allows automatic detection of Ground Control Points (GCPs) and Check Points (CPs) within a dataset. This feature simplifies georeferencing and improves project accuracy by analyzing GCPs/CPs directly during processing.
Licenses: This article is only valid for PIX4Dcloud Pro licenses (formerly PIX4Dcloud Advanced).
Roles: Only Owners, Managers, and Editors can process a dataset using the AutoGCPs in PIX4Dcloud.
Image and GCP requirements
Images:
  • Must be high quality; blurry or low-contrast images may cause detection failure.
  • Geolocated in WGS84 (EPSG:4326).
  • Geolocation accuracy: ≤5 m horizontal, ≤10 m vertical.
  • Captured at nadir or slightly oblique angles.
GCPs/CPs:
  • Supported target types: squared, diagonal, and Aeropoints.
  • Recommended size: ≥20× average GSD of the project.
    • Example: GSD = 2.5 cm → target ≥50 cm.
  • Black and white targets preferred; other colors may work under specific conditions.
  • Minimum distance between points: 15 m.
  • Must have a projected coordinate system.
Warnings:
  • At least 3 GCPs must be detected.
  • AutoGCPs can search within a 5×5 m range of the coordinates specified in the CSV; large inaccuracies may prevent detection.
  • If detection fails, GCPs/CPs will not be considered during processing.
Upload the GCPs/CPs file
  • Create a new dataset and navigate to Step 4: GCPs automation.
  • Click Upload file and select the CSV containing GCP/CP details.
  • Optional:
    • Replace the file: Replace file.
    • Delete the file: Delete. delete.png
CSV format file
Column Required Description
1 Yes Label
2 No Type (GCP or CHECKPOINT, default: GCP)
3 Yes X coordinate
4 Yes Y coordinate
5 Yes Z coordinate
6 No XY accuracy
7 Cond. Z accuracy (required if column 6 defined)
Example: File with 5 GCPs and 1 Checkpoint in projected coordinates without accuracy values.
001_,GCP,4392829.089,5386534.037,424.524
002_,GCP,4392772.823,5386545.0894,424.582
003_,GCP,4392732.981,5386516.197,424.723
004_,CHECKPOINT,4392761.505,5386468.789,422.646
005_,GCP,4392755.707,5386431.546,426.298
006_,GCP,4392832.252,5386456.906,427.001
Defining the GCPs/CPs coordinate system
Warning: The GCP/CP coordinate system must match the output coordinate system. Selecting a different coordinate system will overwrite the previously defined output system.
Viewing and editing control points
  1. Click See and edit control points to open the Control Points Table (Step 5: GCP automation).
Control Points Table Features:
  • Verify imported coordinates.
  • Change the type of a point (GCP ↔ Checkpoint).
  • Swap Easting and Northing if values are inverted.
    Table GCPs PIX4Dcloud
Control Points Map:
  • Displays GCPs and CPs on a background map.
  • Verify that points are at expected locations. Incorrect positioning indicates coordinate or CSV issues.
  • Optional: switch a point between GCP and CP.
  • Save changes as needed.
Images and GCPs are in the same coordinate system Images and GCPs are not in the same coordinate system
Warning: GCP/CP detection fails if the output and GCP coordinate systems differ.
Start processing
  • Click Process to upload input files and start processing.
  • AutoGCPs detection runs automatically.
    • If GCPs are not found, an email is sent notifying the user that processing will continue without them.
  • Upon completion, a Quality Report is emailed.
  • In Files > GCPs, successfully detected points are displayed with their details.
For more information, see New dataset > GCPs automatization > Processing with GCPs/checkpoints - PIX4Dcloud
