Inputs and outputs - PIX4Dfields
This article contains all input and outputs supported by PIX4Dfields.
Inputs
Extension Description
.jpg, .jpeg JPEG images.
Radiometric thermal JPEG.
.tif, .tiff Any number of channels.
Pyramid and multi-page not supported.
Embedded overviews supported.
8 and 16-bit unsigned integer.
32-bit signed integer.
Float 32.
.p4f A whole project, which contains map files used for importing into PIX4Dfields on another computer.
Note: PIX4Dfields supports processing nadir images in which the drone's camera points straight down.
Outputs
PIX4Dfields can generate these outputs, which can be exported for use outside the software.
To export PIX4Dfields outputs:
  1. Open a project.
  2. On the top right, click Export.
  3. Select the preferred output.
  • Orthomosaic (GeoTIFF file): 2D model (map) created by blending multiple orthophotos. Color balanced to be visually pleasing.
  • Digital Surface Model (GeoTIFF file): Consists of elevation data.
  • Targeted Operations maps (Shapefile, KML, GeoJSON, ISOXML, GeoTIFF, or brand-specific formats): zonation, spot-spraying, and variable-rate maps for spray drones, tractors, and field sprayers. Available formats depend on the selected machine brand. Prescriptions can also be sent directly to John Deere Operations Center.
  • Index map (GeoTIFF file):  Each index you calculate gets its own index map layer. Each pixel holds the index value calculated from the image bands; colors are applied for display.
  • Reflectance map (GeoTIFF, .data.tif): The calibrated multispectral data containing reflectance values. It can consist of one or multiple stacked bands.
  • Thermal map (GeoTIFF): Temperature orthomosaic with absolute temperature values, displayed in °C or °F.
  • Field boundaries (Shapefile (.zip), KML, GeoJSON): Allows generating or trimming a layer within a defined region.
  • Obstacles (Shapefile (.zip), KML, GeoJSON): Obstacles are needed when creating Targeted Operation maps that will be used by spraying drones.
  • Annotations (Shapefile (.zip), KML, GeoJSON): Adding annotations to areas of interest helps convey more valuable and actionable information.
  • Upload to PIX4Dcloud: upload 2D layers and annotations to PIX4Dcloud and share a link with others.
  • John Deere Operations Center connection: Share 2D layers, annotations, and TOPs. For more information:  How to connect to John Deere Operations Center from PIX4Dfields
  • PDF report: A report that aggregates all the information in your project for easy sharing.
  • Field insights (PDF ): Field insights leverages advanced AI models to estimate the health and development of your planted crops.
  • Snapshot / high-resolution image (JPEG, PNG): Exports the current map view, so it works with any combination of layers (orthomosaic, index, DSM, operations, annotations, base map).
  • XYZ (.csv): This format allows the exporting of a text file containing XYZ information derived from the Digital Surface Model (DSM)
  • Trimble Multiplane (.txt): is a Format used for field-leveling workflows based on Digital Surface Models.
  • Statistics (CSV): DSM, index layers, and their area annotations display the mean and standard deviation. Point annotations display DSM and index layer values. For more information: Exporting statistics - PIX4Dfields.
  • PIX4Dfields project file (.p4z): Compressed PIX4Dfields project to share or open it on another computer.
  • Log files: Text files that show useful information about the processing of the project. They describe the steps and substeps of processing, the actions taken, the warnings, and the errors during the processing. Log files are needed if the users experience problems and are in contact with technical support.
Note: PIX4Dfields produces two file types when exporting an orthomosaic or a vegetation index layer: .tif and .data.tif. For multispectral layers, the .tif is a false-color image for viewing and printing, and the .data.tif is the reflectance map: a grayscale GeoTIFF with the reflectance values of each band.
Warning: The export functionality is available only for commercial licenses. During the trial period it is not possible to export the results of PIX4Dfields. For more information about commercial licenses, contact our sales team here.
Tip: For some visual examples of each output: PIX4Dfields outputs.
