Exporting statistics - PIX4Dfields
This article explains how to export statistics from PIX4Dfields in .csv file format.
Annotation-statistics.csv
Layer-statistics.csv
How to open the .csv files
PIX4Dfields allows for annotation and raster layer statistics to be exported in a .CSV (comma separated values) format.
Process:
- Click Export.
- On the Export Menu, click
Statistics.
- Select the
Layer/s where annotations are, choose decimal separator (comma or point).
- Click Export, choose
Folder of destination.
Two files will be exported:
annotation-statistics: Calculates the zonal statistics within the annotation.
layer-statistics: Calculates basic statistics of the entire raster layer.
Information: When setting a custom minimum and maximum value in the histogram, the following is exported:
- The statistics of the whole layer or the annotation area.
- The statistics of the visible values set with the histogram.
Important: When viewing the histogram, the "visible" statistics will be all the pixels with values between the min/max sliders.
This file contains statistics about each annotation or plot.
- Mean index value: Refers to the average value of the pixels inside every specific plot that has been calculated using the bands of the corresponding vegetation index.
- Index value SD: Refers to the Standard Deviation (SD), which describes how spread out the dataset is. It is a measure of the amount of variation or dispersion of the plot. A low SD indicates that the values tend to be close to the mean of the dataset, while a high SD indicates that the values are spread out over a wider range.
- Mean index value (visible): Refers to the average of the pixels inside each plot within the range selected in the histogram.
- Index value (visible) SD: Refers to the SD of data within the range selected in the histogram.
- Area: Refers to the surface covered by the plot and it does not take into account changes on the histogram range.
This file contains statistics about the selected layers. The example below describes an NDRE index and Digital Surface Model.
- Area: Refers to the surface covered by the layer.
- Area (visible): Refers to the surface only covered by the pixels within the range selected in the histogram.
- Min-Max: Refers to the minimum and maximum values present on each layer.
- Min - Max (Visible): Refers to the minimum and maximum values within the range selected in the histogram for each layer.
- Mean index value: Refers to the average value of all pixels in the layer, that has been calculated using the bands of the corresponding vegetation index.
- Index value SD: Refers to the SD of data present in the whole layer.
- Mean Height: Refers to the average height present in the layer, it will be present if Digital Surface Model (DSM) was selected when exporting.
- Height SD: Refers to de SD of the DSM.
- Mean index value (visible): Refers to the average value of all pixels within the range selected in the histogram.
- Index value SD (visible): Refers to the SD of data within the range selected in the histogram.
- Mean height (visible): Refers to the average height value of all pixels within the range selected in the histogram.
- Height (visible) SD: Refers to the SD of height data within the range selected in the histogram.
If the data appears garbled after double-clicking the .csv file, please follow the instructions below.
Microsoft Excel
- Open the Excel app.
- Click Data.
- Click from Text/CSV.
- Import the file.
- Under File origin, choose Unicode (UTF-8).
- Set Delimeter to Comma.
Google spreadsheets
- Click File, Import.
- The Import file menu appears
- Set separator type to Detect automatically.
- Activate Convert text to numbers, dates, and formulas.
- Click Import data.
