- Pix4D Documentation
- RTK devices
- Downloads
Download the app
Requirements
To get started, you need the following:
- A mobile device: iPhone, iPad or Android smartphone. To check the compatibility with the Pix4Dcatch application, please refer to this guide.
- The Pix4Dcatch application
- A Pix4D supported RTK device(optional)
- An SP connector compatible with your mobile device (optional)
- An NTRIP service subscription or a GNSS base with NTRIP caster (optional)
- An internet connection
- PIX4Dmapper, PIX4Dmatic, or PIX4Dcloud license for processing. (PIX4Dmapper does not support LiDAR data)
Install PIX4Dcatch
To set up PIX4Dcatch:
- Download the latest version of PIX4Dcatch for iOS and Android.
- Start PIX4Dcatch.
- Select the
icon on the screen.
- In the Account Details, either create a new Pix4D account or log in with an existing Pix4D account.
- Once PIX4Dcatch is installed on the device, it is ready to start capturing datasets with the integrated GNSS sensor or with RTK corrections.
Go to Capturing a dataset for best practices in acquiring a dataset with PIX4Dcatch.
To achieve more precise image geolocation use an Pix4D supported RTK device. Go to Connect PIX4Dcatch to the Pix4D supported RTK devices for more information.
