How to export a targeted spraying map - PIX4Dfields
The following article describes how to export a targeted spraying prescription map using the PIX4Dfields Targeted Operation feature, which can be used by spraying drones and ground sprayers.
Why export a Targeted Operation prescription map?
How to export
Types of operations and formats
A targeted spraying prescription enables the implementation of variable-rate applications. This method results in cost savings by allowing for the precise application of products only in the areas that need them, and in the correct amounts.
How to export?
To export the Targeted Operation map:
- Go to Export, Operations.
- Select the operation layer to export.
- Select the brand and format:
XAG
XAG's spraying drones support two types of missions:
- XAG boundary mission: it allows the definition of the field area to be sprayed along with obstacles and no-spraying zones. It only supports one fixed rate.
- XAG VRA mission: it allows a variable rate to be applied to the field area to be sprayed, along with obstacle and no-spraying zones. It supports up to three different application rates.
For more information: Targeted spraying maps for XAG P100's drones with PIX4Dfields.
DJI Agras T-Series
The formats available to export to DJI Agras T-Series are:
- DJI Agras boundary mission (.shp)
- DJI Agras VRA mission (.shp and .tiff)
For more information: Spot spraying and variable rate maps for DJI Agras T-series with PIX4Dfields.
TopXGun
The formats available to export to TopXGun drones are:
- TopXGun boundary mission (.shp)
- TopXGun VRA mission (.shp and .tiff)
For more information: How to export prescriptions for TopXGun agricultural drones - PIX4Dfields
Drones Talos
The formats available to export to Drones Talos are:
- Talos boundary mission (.shp)
- Talos VRA mission (.shp and .tiff)
For more information: How to export prescriptions for Talos spraying drones - PIX4Dfields
AMAZONE
A Spot Spraying export format for new Amazone Sprayers, compatible with the Amatron 4 displays. Formats available are:
- SpotSraying shapefile.
- ISOXML zipped file.
For more information: AMAZONE monitors - PIX4Dfields.
HARDI GeoSelect
When exporting to HARDI, there are two formats available:
- GeoSelect, a .tiff file will be created.
- ISOXML (ISOBUS), for more information: How to export ISOXML / ISOBUS in PIX4Dfields.
For more information: How to export a variable rate map to a tractor terminal - PIX4Dfields.
Generic tractor/sprayer
It can be exported as:
- .shp or .tiff, depending on the tractor/sprayer used.
