Contour lines - PIX4Dmatic
terrain_filter-16
Terrain classification
points_grid
Grid of points
tin
TIN
dtm
DTM
contour_lines
Contour lines
manhole_detection
Road object detection
ground_plate-16
Surface comparison
Input
Export
The contour lines feature connects points of the same height with a polyline. Height values are extracted from a TIN (Triangular Irregular Network) or a DTM (Digital Terrain Model). This feature is also used to generate major and minor contour lines, which are visible in the images.
Note: To generate contour lines TIN or DTM needs to be generated in the project.
Captura de pantalla 2026-01-29 154220
Input
The following settings can be adjusted:
  • Interval [units]: Defines the contour line elevation interval. It can be in meters or in imperial according to the coordinate system used:
    • 1 m - default.
    • 3 ft(US) - default.
contour lines
Tip: The minimum interval value supported is 0.1. Values below this threshold are not valid and will not be accepted.
  • Discard contour loops shorter than [units]: Detects and discards contour lines with shorter length. It can be in meters or in imperial according to the coordinate system used:
    • 10 m - default.
    • 30 ft(US) - default.
Export
Contour lines can be exported from the Menu bar, click File, then Export. Alternatively, on the content panel, in the Contour line section, export.jpg Export.
The available formats for contour line exploration are DXF, zip shp, SHP y GeoJSON.
