Feature per license - PIX4Dmatic
Disclaimer: this page is usually updated when a new stable version is released. Changes introduced in preview versions may not yet be reflected.
| FEATURE | Discovery (no license) |
PIX4Dmatic Analyst | PIX4DmaticStandard | PIX4Dmatic Pro |
| Welcome view | ||||
| Open old PIX4Dmatic projects | ✅ | ✅ | ✅ | ✅ |
| Import PIX4Dsurvey projects | ✅ | ✅ | ✅ | ✅ |
| Import PIX4Dmapper projects | ✅ | ✅ | ✅ | ✅ |
| Import OPF | ✅ | ✅ | ✅ | ✅ |
| File menu | ||||
| New project | ✅ | ✅ | ✅ | ✅ |
| Open project | ✅ | ✅ | ✅ | ✅ |
| Merge project | ❌ | ❌ | ✅ | ✅ |
| Open project folder | ✅ | ✅ | ✅ | ✅ |
| Open project export folder | ✅ | ✅ | ✅ | ✅ |
| Save | ❌ | ✅ | ✅ | ✅ |
| Save copy | ❌ | ✅ | ✅ | ✅ |
| File -> Import | ||||
| - Images - Images from folder - Image geolocation and orientation - GCPs - Marks - Region of Interest |
- Point clouds |
Volume base surface as LandXML |
Animation trajectory |
Drag and drop imports |
Importing images to an existing project |
- Point clouds |
| Selection tools |
| Simple selection | ✅ | ✅ | ✅ | ✅ |
| Rectangle selection | ✅ | ✅ | ✅ | ✅ |
| Polygon selection | ✅ | ✅ | ✅ | ✅ |
| Color selection | ✅ | ✅ | ✅ | ✅ |
| Object selection (AI) | ❌ | ❌ | ✅ | ✅ |
| Road selection | ❌ | ✅ | ❌ | ✅ |
Vectorization tools |
Marker |
Polyline |
Polygon |
Polygon hole |
Circle |
Arc |
Catenary |
Road detection |
Roof detection |
Wall detection |
Measurement tools |
Distances |
Volumes (base polygon to point clouds) |
Volumes (base polygon to TINs) |
Stockpile detection |
Scale constraint |
Orientation constraint |
Region of Interest (ROI) |
Region of interest (ROI) |
Import/export ROI |
Sections & orthos |
Section creation |
Orthoplane |
Export orthoplane |
Export section geometries |
Orthomosaic editor |
PIX4Dmatic processing |
Calibration |
Gaussian splats & point cloud |
Depth point cloud |
Dense point cloud |
Depth & dense point cloud |
Outlier removal |
DSM |
Orthomosaic (RGB and thermal) |
Mesh |
AI tools |
Export section |
- Quality report |
- Gaussian splats |
- Dense point cloud |
- Point cloud from mesh |
- Mesh |
- DSM |
- Orthomosaic |
Importing processing template |
Exporting processing template |
Survey processing |
Terrain filter |
Grid of points |
TIN |
Digital Terrain Model (DTM) |
Contour lines |
Road object detection (AI) |
Surface comparison |
Videos & views |
Save views |
Create animation |
Add logo |
Export animation |
Import the animation trajectory |
Content panel |
Display classes Terrain (switch) |
Display classes ASPRS (switch) |
Add custom classes |
Export layers |
Export point clouds |
Grid actions: change color, rename, delete |
Grid actions: export |
TIN actions: change color, delete |
TIN actions: export |
DTM actions: delete |
DTM actions: export |
Contour lines actions: change color, delete |
Contour lines actions: export |
Export point clouds with the terrain filter |
Importing layer template |
Exporting layer template |
Cameras panel |
Camera internals (open) |
Edit externals |
Edit internals |
Save to database |
Load optimized parameters |
Import geolocation and orientation |
Export geolocation and orientation |
Sort cameras |
Set image CRS |
Imports |
Importing Mapper projects |
Tie points panel |
GCP CRS |
Import GCPs |
Import marks |
Export GCPs |
Export MTPs and ITPs |
Export marks |
Edit GCP data |
Edit a tie point name |
Convert a tie point into a GCP |
Convert a tie point into a checkpoint |
Add tie point |
Delete all tie points |
Remove tie point |
Convert tie point to vertex |
Remove marks |
Merge tie points |
Copy WKT |
Sort |
Reports panel |
Summary (stats) |
Quality report export |
Custom report export |
Settings |
Camera size |
Tie point size |
Marker size |
Mask size |
Point size |
Marker label |
Mask label |
Contour line label |
Min nº matches |
Color ATPs |
Color by elevation |
Color by normal |
Color by GPS |
Face orientation |
Clipping box |
Snapping window |
Distortion aware |
Backface culling |
Object occlusion |
Perspective/orthographic view |
Viewport layouts |
Background (sky and color) |
Preferences |
Language |
Project handling |
Theme |
3D viewer background color |
2D viewer (basemap) |
Email notification |
Properties |
Software updates toggle |
Release notes toggle |
Hardware (GPU) |
Mesh rendering |
Point cloud rendering |
Layer templates |
Processing template |
Network |
Offline license |
Image viewer |
Auto mark |
Auto mask |
Mark MTP |
Mark mITP |
Create mask |
Center and re-sort |
Filter/Sort |
Maximize/enlarge |
Import images |
Hide/show all reprojection marks |
Edit ortho patch camera or projection type |
Open Photogrammetry Format (OPF) |
Import |
Export |
Overwrite OPF |
PIX4Dcloud interactions |
Process in PIX4Dcloud |
Share to PIX4Dcloud |
Download from PIX4Dcloud |
Other |
Point cloud registration |
History panel |
Export undistorted images |
Reclaim seat |
AutoGCP |
Export image based site calibration |
Automatic boundary detection |
2D/3D interactions |
Disable point cloud points |
Restore point cloud points |
Assign to ASPRS class |
Assign to Terrain class |
Delete grid points |
Delete vertices |
Move to layer |
Convert polyline<>polygon |
Convert polygon<>volume |
Convert polyline<>volume |
Join/split/continue/offset |
Convert to VTP |
Drape polyline |
Set to planar/non-planar |
Create clipping box from selection |
Reset clipping box |
Flip face |
Invert selection |
Edit ortho patch (add/move/remove vertex) |
