[2025] Technical release notes - PIX4Dcloud
Note: This article includes the release updates for PIX4Dcloud Starter and PIX4Dcloud Pro (formerly PIX4Dcloud Advanced).
December 19th, 2025 - Web UI and Processing Engine: 3D Visualization, Rendering, and Stability Enhancements
Improvements:
  • Eliminated the web UI 3D editor’s rendering of internal triangles in transparent IFC design overlays.
Changes:
  • An email is sent when processing starts for a dataset created using the web UI’s dataset creation wizard.
Bug fixes:
  • Fixed the issue where the web UI’s 3D editor sometimes rendered background Gaussian splats in front of the foreground Gaussian splat.
  • Fixed the issue where processing sometimes failed after an unexpectedly long time when generating Gaussian splats and an orthomosaic with the same dataset.
  • Fixed the issue where the web UI’s 2D editor did not automatically update when DXF design overlay child layers were enabled or disabled in the layers list.
  • Fixed the issue where the state of buttons in the toolbar in the embedded 3D viewer would unexpectedly change or persist.
  • Fixed the issue where 2D reconstructions were not completely constrained by the region of interest when processing PIX4Dcatch images.
  • Fixed the issue where buttons in the web UI editor’s toolbar could be unexpectedly disabled.
  • Fixed the issue where processing would fail to generate Gaussian splats when the dataset included images with more than one type of aspect ratio.
  • Fixed the issue where it was not possible to request a ZIP of a dataset’s images during the retention period.
  • Fixed the issue where the web UI editor would sometimes freeze after changing the IFC design overlay’s transparency.
  • Fixed the issue where the dataset creation wizard’s map displayed images with initial positions with negative latitude or longitude in the wrong location.
  • Fixed the issue where the web UI’s drive did not render some elements on ultra-wide monitors.
  • Fixed the issue where the 3D editor rendered multiple gizmos while editing annotations.
  • Fixed the issue where the dataset creation wizard’s map continued to display images after they were deleted.
  • Fixed the issue where navigation in the web UI’s 3D editor became unstable while zooming in and out and rendering Gaussian splats after disabling the point cloud.
  • Fixed the issue where the layers list displayed more than one Gaussian Splat layer in compare mode.
November 4th, 2025 - UI Enhancements and Fixes for DXF Overlays, Metadata, and Annotations
Improvements:
  • Improved the status bar to highlight the current state of PIX4Dcloud’s web UI and the dataset.
Bug fixes:
  • Fixed the issue where DXF design overlay sublayer names were changed to “Dxf”.
  • Fixed the issue where images without altitude or elevation in their metadata could be uploaded for processing with the dataset creation wizard.
  • Fixed the issue where an annotation would snap to itself.
October 20th, 2025 - PIX4Dcloud Enhancements: Creator Visibility, Extended Processing Time, and Improved 3D Editor Performance
Improvements:
  • A PIX4Dcloud dataset’s details display who created the dataset.
  • Maximum processing time increased from 48 hours to 72 hours to support larger and more complex datasets.
  • Gaussian splats are compressed and reordered to improve PIX4Dcloud’s 3D editor performance and rendering quality.
Bug fixes:
  • Fixed the issue where DXF design overlays moved unexpectedly when the 2D editor was not oriented North.
  • Fixed the issue where the region of interest did not constrain the 2D reconstructions generated with drone images.
  • Fixed the issue where annotation tools remain active when switching between the 2D and 3D editor, opening another dataset, or opening compare mode.
  • Fixed the issue where the dataset creation wizard would sometimes skip all steps and create an empty dataset after pressing the Enter key.
  • Fixed the issue where the map view sometimes would not load all datasets, sites, or folders.
  • Fixed the issue where popups reappeared or got stuck after switching to a different language.
  • Fixed the issue where the ArcGIS Online integration did not transfer an annotations report.
October 6th, 2025 - ArcGIS Online Export, Gaussian Splats, and Enhanced 3D Editor Tools
What's new:
Improvements:
  • Increase maximum number of points that can be rendered with 3D editor from 20 million to 60 million points.
Changes:
Bug fixes:
  • Fixed the issue where it was not possible to download outputs when the organization owned both a trial and paid license.
  • Fixed the issue where it was not possible to download outputs after the license expired and during the data retention period.
September 17th, 2025 - Improved Processing Success Rate with Complex or Large Datasets
Improvements:
  • Improved processing success rate when processing relatively complex or large datasets.
Bug fixes:
  • Fixed the issue where the 2D editor was sometimes unresponsive when opening a site with DXF design overlays.
  • Fixed the issue where the Gaussian splats sometimes flickered in the 3D editor when specular reflections was enabled.
  • Fixed the issue where the region of interest was ignored when generating Gaussian splats.
  • Fixed the issue where 3D editor navigation was sometimes unstable when rendering Gaussian splats.
  • Fixed the issue where the 2D editor displayed JPEG-compressed orthomosaic GeoTIFFs as opaque when they were uploaded with the dataset creation wizard.
  • Fixed the issue where processing failed when a tie point was marked in one image.
August 19th, 2025 - PIX4Dcloud Drive's Search Gets a Major Upgrade
Improvements:
  • PIX4Dcloud drive’s search also searches in PIX4Dcloud datasets' notes.
Changes:
  • PIX4Dcloud dataset creation wizard no longer allows uploading multispectral TIFF or SIG images for processing.
  • PIX4Dcloud’s 3D editor and PIX4Dcatch’s PIX4Dcloud AR render Gaussian splats without spherical harmonics or specular reflections by default. They can be enabled in the Gaussian splat layer’s display settings.
Bug fixes:
  • Fixed the issue where the region of interest and requested outputs were ignored when requesting an SLPK point cloud or 3D textured mesh with a compound output coordinate reference system.
  • Fixed the issue where one or more layers would disappear from the 2D editor in some web browsers when more than 16 design overlays were enabled at the same time.
  • Fixed the issue where the 3D editor rendered Gaussian splats with the wrong color in web browsers on Android mobile devices.
  • Fixed the issue where the 3D editor in web browsers on mobile devices and PIX4Dcatch’s PIX4Dcloud AR did not render the point cloud or 3D textured mesh.
  • Fixed the issue where annotations sometimes do not snap to the center or a point in the point cloud.
  • Fixed the issue where Gaussian splats appeared to flicker in the 3D editor or PIX4Dcatch’s PIX4Dcloud AR when they were rendered out of order.
  • Fixed the issue where Gaussian splats appeared to flicker or reload continuously in web browsers on mobile devices and PIX4Dcatch’s PIX4Dcloud AR when the point cloud was enabled.
  • Fixed the issue where the point cloud appeared to flicker or reload continuously in web browsers on mobile devices and PIX4Dcatch’s PIX4Dcloud AR when the Gaussian splats were enabled.
  • Fixed the issue where navigation was sometimes unstable or the camera sometimes moved unexpectedly at short distances from the Gaussian splats.
  • Fixed the issue where the 2D editor sometimes did not render the orthomosaic.
July 24th, 2025 - Enhanced 3D Editor: SLPK Export, Better Design Overlay Visualization, and Annotation Snapping
What's new:
Improvements:
  • Request either an LAS or LAZ point cloud with the dataset creation wizard.
  • Gaussian splats load faster in 3D editor.
Bug fixes:
  • Fixed the issue where a duplicate PIX4Dcloud dataset was created when the organization had zero credits.
  • Fixed the issue where annotations were created in the 3D editor when the Gaussian splat layer was enabled and the cursor did not intersect with any layer.
  • Fixed the issue where an OBJ 3D textured mesh sometimes could not be downloaded when the PIX4Dcloud dataset was created with PIX4Dmatic’s Share to PIX4Dcloud.
  • Fixed the issue where web browsers on iOS mobile devices sometimes automatically refreshed the web page when the 3D editor loaded Gaussian splats.
July 18th, 2025 - Download and Overlay upload issue fixed in PIX4Dcloud
Bug fixes:
  • Fixed the issue where some outputs could not be downloaded without a valid PIX4Dcloud license.
  • Fixed the issue where a PDF, JPEG, JPG, or PNG file design overlay sometimes failed to upload.
July 4th, 2025 - The coordinate reference system picker supports TXT files
Improvements:
Bug fixes:
  • Fixed the issue where the web UI’s 3D editor sometimes snapped annotations to the following layers when they were disabled or hidden: IFC, Gaussian Splat, and Point cloud.
  • Fixed the issue where the opaque orthomosaic ZIP was sometimes not available for download.
  • Fixed the issue where the region of interest was not used when processing datasets with a left-handed coordinate reference system.
  • Fixed the issue where the design overlay wizard sometimes took more time than expected to upload PDF, JPEG, JPG, and PNG files.
Information: Before starting your project, carefully review our guide on the best practices and capabilities of PIX4Dcloud.
June 20th, 2025 - Live Camera Feed Now Visible in PIX4Dcatch’s AR View
Bug fixes:
  • Fixed the issue where the live camera feed was hidden by an opaque background in PIX4Dcatch’s PIX4Dcloud AR.
June 13th, 2025 - Improvements to the annotation report
Improvements:
  • The annotations report now includes 3D length for relevant annotations.
Bug fixes:
  • Fixed the issue where processing sometimes failed when AutoGCP detected only one or two GCPs in images.
May 30th, 2025 - Improvements to the images attached to annotations
Improvements:
  • Add, replace, and delete images that are attached to annotations with the web UI.
  • All accounts have access to Organization management.
  • Autotag markers are perpendicular to the target when displayed in the 3D editor.
Bug fixes:
  • Fixed the issue where the creation of an opaque copy of the orthomosaic sometimes failed.
  • Fixed the issue where someone could sometimes continue to access some information and resources after they were removed from an Organization.
May 16th, 2025 - Improvements to the names of files downloaded from a dataset
Improvements:
  • When downloading inputs, outputs, and reconstructions with PIX4Dcloud's web UI, the default file name includes the current name of the PIX4Dcloud dataset and site.
Bug fixes:
  • Fixed the issue where an account failed to join an organization when it was a member of an organization.
  • Fixed the issue where the elevation computed for an annotation created with the 2D editor sometimes was less accurate than expected.
  • Fixed the issue where the horizontal position of an annotation created with the 2D editor sometimes moved when it was created or edited for datasets with a compound or vertical coordinate reference system.
  • Fixed the issue where the dataset creation wizard sometimes crashed or froze when uploading a larger number of images.
  • Fixed the issue where the “Buy now” button was sometimes unexpectedly displayed or missing.
  • Fixed the issue where the Gaussian splat layer sometimes remained visible in the 3D editor after it was disabled.
  • Fixed the issue where the design overlay wizard sometimes froze when uploading an image or PDF design overlay.
  • Fixed the issue where calibration processing time was sometimes longer than expected for the Oblique processing options and larger datasets, and processing sometimes failed.
  • Fixed the issue where a 3D textured mesh was sometimes not generated.
  • Fixed the issue where the 3D editor sometimes failed to focus on the 3D textured mesh.
  • Fixed the issue where the 3D editor sometimes failed to center the view on the project area.
May 9th, 2025 - Improvements in Gaussian splatting
Improvements:
April 30th, 2025 - Improvements and bug fixes
What is new:
  • Support for geoid model JPGEO2024 from Japan, EPSG:6695 "JGD2011 (vertical) height".
Improvements:
Bug fixes:
  • Fixed issue where the dataset creation wizard included unnecessary steps and did not close when uploading Parrot Sequoia multispectral images.
  • Fixed issue where the dataset creation wizard could not progress after .tiff images were added to a dataset.
  • Fixed issue where compare mode sometimes did not display 2D layers.
  • Fixed issue where the dataset creation wizard could get stuck after selecting a step when uploading processed outputs to an empty dataset.
  • Fixed issue where some elements were not translated or translated incorrectly.
  • Fixed issue where custom base surface elevation for volume measurement disappeared when it was set to zero.
  • Fixed issue where it was not possible to import control points when the dataset coordinate reference system’s geoid height was set to zero.
  • Fixed the issue where the annotations report sometimes included the same detailed image for multiple annotations.
April 1st, 2025 - Attach images to an annotation in PIX4Dcatch
What is new:
Changes:
Improvements:
  • The projects uploaded from PIX4Dcatch using the Gaussian Splatting technique for processing have the following improvements:
    • Processing time has been reduced.
    • Quality of the outputs has been improved.
    • Splats are now available for annotating and measuring.
    • Focus on or zoom to Gaussian Splat layer in 3D editor.
  • The web UI’s 3D editor remains responsive while loading any type of layer.
Bug fixes:
  • Fixed the issue where the camera in the 3D editor moved to a different position when the Gaussian Splat layer was enabled.
  • Fixed the issue where the 3D editor failed to display the Gaussian Splat layer when the dataset’s name included spaces.
  • Fixed the issue where the 3D editor sometimes displayed the Gaussian Splat layer with unexpected colors.
February 10th, 2025 - Gaussian Splatting technique for projects uploaded from PIX4Dcatch
What is new:
Bug fixes:
  • Fixed the issue where sometimes the edges of the orthomosaics had significant artifacts.
  • Fixed the issue where the NDVI layer could not be deleted.
  • Fixed the issue where orthomosaics in WGS84 were not displayed
Improvements:
  • The format of an orthophoto and DSM processed from the PIX4Dcloud user interface is now Cloud Optimized Geotiff.
January 13th, 2025 - Region of interest for processing
What is new:
Bug fixes:
  • Fixed the problem of an orthomosaic not being displayed when the coordinate system is WGS84.
  • Fixed the issue with the NDVI layer that could not be deleted.
